Reload this Page >
TF FW190 GIANT ARF
TF FW190 GIANT ARF
Old 07-07-2014, 09:41 PM
  #3051
kwik
kwik's Avatar
Jimmy, I liked the sound of the engine. Is it the Roto 85 inline , two cylinders ? Or is it the boxer?
Old 07-08-2014, 01:37 PM
  #3052
n8622t
My Feedback: (8)
Go to post #1451
Old 07-08-2014, 06:02 PM
  #3053
BearBow
Well, I'm officially a part of this thread now....the Sierra retracts and tailwheel, etc., are on the way...got the last Saito 84cc Radial fm Chief, it's here tomorrow, and ordered 11 Savox servos....Have been a die hard HiTec fan, but unless you get the $180 93xx Brushless series, which are awesome, I'm just tired of noise and centering issues, and pricing....a brushless Savox is $75 to $85 cheaper, and more torque....I'll see if I like them, but decided to try them.
I'm going to use a Spektrum 12 ch Failsafe, an IBEC for only 2 batteries, maybe a Booma RC touchpad on/off switch, under the hatch, and basically looking for any advice as i go....I'll read through this so I don't ask questions already covered, but like the comments on the baffling....those looked great for the Saito. Any discussions on the mod to mount the Sierra's....seems like a fairly straightforward modification to the ribs to mount the mains. Also, anyone here use the Sierra tailwheel retract vice the Robart....I'm going to use the Sierra for Scale looks and quality. Also, I see the kit fuel tank is a close fit. Those of you that have the Saito did you use the fuel tank in the kit, or something else? Is the 16oz enough for a 10min flight, or what, using the Saito 84 Radial? Thanks much,
Retired Navy Pilot.
Old 07-08-2014, 06:58 PM
  #3054
sparky4lawndart
My Feedback: (10)
sparky4lawndart's Avatar
I promised some pics from the weekend...
First I've got to limber up with my yoga!
now, here are some pics of Heimlich
now.. I bet you that Jug pilot is thinking he's safe... Guns, Guns, Guns!!! or more aptly - Pistolen, Pistolen; Pistolen!!!!
ID:	2012724   Click image for larger version
ID:	2012725   Click image for larger version
ID:	2012726   Click image for larger version
ID:	2012727   Click image for larger version
ID:	2012728   Click image for larger version
Old 07-09-2014, 02:08 AM
  #3055
kwik
kwik's Avatar
Originally Posted by n8622t
Go to post #1451
Found it, and started re-reading the thread again, hehe.
Old 07-09-2014, 01:21 PM
  #3056
n8622t
My Feedback: (8)
Bearbow I'm running a 32oz but a 24 would be plenty. I know plenty of guys running 16oz on DA 50 but with the big 84cc I would want at least the 24
Old 07-09-2014, 01:43 PM
  #3057
n8622t
My Feedback: (8)
Bearbow go to post #2896 and watch the video... Something you might consider on your new saito 84 radial
Old 07-09-2014, 01:48 PM
  #3058
n8622t
My Feedback: (8)
I had both of these done ��
Old 07-09-2014, 03:57 PM
  #3059
captainron
captainron's Avatar
Sparky............You just quack me up. I got a pic just like yourin..............Can't wait to fly witch yuh in Octoba.......
pic is of me and my buddy flying formation at our field last month............He likes to get really close.
Name:	FW 190 FORMATION.JPG
Old 07-10-2014, 04:22 PM
  #3060
BearBow
n8622t: Thanks for the advice....as it turns out, I talked with Kelvin at Keleo, and he turned me on to Fred Culbertson (Condor60) and then Ray English who does the intake manifold and conrod bearings for oil flow etc. My motor came today and i turned it right around and sent it to Ray for his internal modifications, Which after seeing their 2-3 videos, either you do the mods, or you don't buy the Saito 84...it's that bad....I wouldn't buy it without having Ray fix it. And he'll fit/mount the Keleo exhaust on it and return it in 10 days....I'm stoked. Huge power increase, but the main thing is this video....talks about the different cylinder head temps and lack of proper lubrication. I think it's the same one you sent me....I would not buy this engine without doing this; you're just a ticking time bomb waiting for the connecting rod to seize on the crank.
https://www.youtube.com/watch?v=ffUehgpp8Ug
Here's a couple more related videos that are really cool...same guys....Fred and Ray and Keleo: http://www.rcgroups.com/forums/showthread.php?t=2071116
http://www.youtube.com/watch?v=zkb-Uvim1qk
I certainly thank everyone for getting me smart before my maiden....anyone know of 3 blade 23x10 or 23x12 props?
Old 07-10-2014, 04:26 PM
  #3061
BearBow
Anyone know where to get the correct size prop spinner, high quality, but with the white circular spin painted on? Also want to run a 3 Blade.
Old 07-10-2014, 05:09 PM
  #3062
sparky4lawndart
My Feedback: (10)
The 3 blade aluminum spinner is available from Tower for the TF GS FW190... there's videos on YouTube for how to on painting your spiral.. not hard at all... some tape, an exacto blade, and Rustoleum White matte primer.
Old 07-10-2014, 05:30 PM
  #3063
sparky4lawndart
My Feedback: (10)
OK.. it's not perfect but at 7000 RPM nobody will notice.. hehe
ID:	2013280   Click image for larger version
ID:	2013281   Click image for larger version
ID:	2013282   Click image for larger version
ID:	2013283   Click image for larger version
Old 07-10-2014, 05:40 PM
  #3064
sparky4lawndart
My Feedback: (10)
I think it took me 11 minutes to do this as soon as I saw your post... Given that I'm a shlep with no abilities, and the quality is pretty low, I'm guessing the normal modeler would spend 30 minutes, after checking references on what the spiral should look like, and have a perfect spinner!
Old 07-11-2014, 06:27 AM
  #3065
BearBow
Cool, Thanks
I'll try it.
Brad
Old 07-11-2014, 09:32 AM
  #3066
n8622t
My Feedback: (8)
No problem bearbow... You might also consider having Ray drill your prop hub for a multi bolt pattern so you won't have to crush the prop with a single nut. Not sure if you noticed that in the pic I posted
earlier ..you still have to use the original nut but not with the same torque
Old 07-11-2014, 09:55 AM
  #3067
kwik
kwik's Avatar
Which after seeing their 2-3 videos, either you do the mods, or you don't buy the Saito 84...it's that bad....I wouldn't buy it without having Ray fix it. ....I would not buy this engine without doing this; you're just a ticking time bomb waiting for the connecting rod to seize on the crank.
Well, well.
Do you realise that you have just watched a promotion for a product, and that you are now coming up with conclusions based on that promotion video?
People are trying to sell us stuff all the time. That's okay.
You fell for it, and thats okay too.
Since the beginning of time there has been engine gurus telling us they have a fantastic fix to some engine.
The bronze bearing;
If you follow the manual, and fill some oil onto the crankcase, who are you to say that the bearing isnt good enough for this engine?
The somewhat erratic running;
If the engine is running good enough for us rc-modelleres, it actually is good enough. Stuff can allways be made better,
but 100% excellence will stop any progress.
Here is mine under testing;
https://www.youtube.com/watch?v=J-gq...cfjQKyisx5bArw
Is it a timebomb? I dont think so. ( time will tell. hehe )
Can it be used in my plane as is? Yes, I think so.
Old 07-11-2014, 10:12 AM
  #3068
captainron
captainron's Avatar
well said Kwik..........It's the same thing we used to do with our 56 chevy's.........install headers, bigger carbs, four speeds on the floor.......but if you install a bigger cam, bigger dome top pistons, now your talking baby.........MORE HOREPOWER.........GO FASTER. Both make very good points.
GOD ....I LOVE THESE FORUMS...................... CAPTAIN RON
Old 07-11-2014, 04:29 PM
  #3069
n8622t
My Feedback: (8)
Ok dip stick..... I have two saito radials identical .... One locked up 20 seconds after the initial start up, is it a time bomb? Maybe but you obviously don't know who Ray English is or you wouldn't be talking smack right now. When you have enough money to ever buy one of these radials I would strongly recommend you send it to him otherwise don't tell me about getting sucked in because you don't know me Kwik
Old 07-11-2014, 04:52 PM
  #3070
sparky4lawndart
My Feedback: (10)
Wow... Jimmy... he wasn't pointing a finger at you...you guys are both good guys and lots of modeling experience. Ray English is a legend. yes! He's been around engines a very, very long time and what he does with the Saito is amazing (engineering brilliance). but many, many people run that engine having never done anything except put gas in it and saw on the throttle.
Kwik is pretty good at this and just made a comment that folks think there's something fundamentally wrong with that Saito and bought wholesale into the video describing a mod to make it better. I've failed to read instructions before and learned a failure could have been prevented had I done some thing or other (kinda like oiling a bering, etc). I actually bought a EVO 77 and wrecked it running it out of the box and failing to check valve clearances (something in the manual). I've also run a DLE out of the box for 2 years and I've never touched the needles. You never know on these models.. Sometimes the stars align and it's all smiles and sunshine
No hard feelings, please... you guys are awesome!
Old 07-11-2014, 05:01 PM
  #3071
SrTelemaster150
SrTelemaster150's Avatar
Or shave 1mm from the case deck of an FA-450R3 , slap FA-180B cylinders on top W/FG-84 pistons for 12.2:1CR, do the Ray English mod, port the intake for 12mm alky carb & run glow fuel. A 5.12 cu. in. nitro methanol fire breather. Ought to be good for about 8HP.
Old 07-11-2014, 07:06 PM
  #3072
captainron
captainron's Avatar
LOL.........outstanding Sr Telemaster.
Old 07-13-2014, 06:06 AM
  #3073
JGrc
My Feedback: (29)
JGrc's Avatar
Excellent Sparky! No hard feelings
JG
Old 07-13-2014, 07:46 AM
  #3074
kwik
kwik's Avatar
JG
+1
Probably because I don't know what a "dip stick" is anyway.
hehe.
Who knows, I might order the parts from Ray English this winther for a better gasoline distribution myself, we will see? I am sure he is an excellent engine man.
But saying that it is either doing the mods, or not buying the FG-84 is a bit over the top. Mine is running just fine, but I still need to run it perhaps
15 minutes on full throttle on the ground, just to check cooling.
Old 07-13-2014, 12:26 PM
  #3075
Chris Nicastro
Chris Nicastro's Avatar
Whats the charge for the mod on this engine?
