Top Flite Giant Scale Spitfire ARF
#127
My Feedback: (8)
RE: Top Flite Giant Scale Spitfire ARF
Working on the tailwheel. I modified it with some pieces I had lying around. Not exactly like the full scale but better than the wire. Here is also a possible substitute ( http://www3.towerhobbies.com/cgi-bin...?&I=LXRWW9&P=7 ). I also don't like the wire looped around the ball links so I used Actual ball links. All hooked up and working great.
#131
My Feedback: (157)
ORIGINAL: raptureboy
Would have loved to see this Mk IX version. It's a shame they don't offer it unfinished like the Mustang
I'd have to strip this however and place a few access pnls and what ever else the aero detail offered.. It would give me something to do until the corsair comes in from Hanger 9
#137
My Feedback: (8)
Won't know about the muffler until it can be tried on the Spit. They are still on BO. Love the tailwheel unit. Who sells it? I discovered that the pictures showing the fuse servo installation are mislabeled and incorrect. The way the tubes were installed in my plane put the rudder servo on the outboard edge. Very careful attention is required during servo install to insure they do not interfere with each other. I also had to cut some of the bulkhead away for the rudder travel.
#139
ORIGINAL: Capt G
#140
My Feedback: (8)
The tail feathers are now glued on and hooked up. No issues. The cowl is mounted and reinforced per the manual. The only issue was the spinner screw needed a little machining to fit well. The bottom will be opened up some more to accommodate the muffler pipes when I get one.
#141
ORIGINAL: Ramstein44
How well did it fly, look and so on?.. This is my first pick scheme..
You wouldn't do that to a Spitfire would you....................[X(]. Never mind, I know the answer to that question...........LMAO ! ! ! ! !
Take care,
David
#142
My Feedback: (157)
LMAO.. Yeah, I would... But I'd like to do the low altitude version. It'll all depend on what I see when I pull it out of the box and remove the covering. I'll have to make my exhaust stacks from scratch as I'll be doing the MKV but if it's a pain.. their will be a swastika on it..
#143
#144
My Feedback: (60)
AZ
#146
My Feedback: (8)
This might open up ,a can of worms , but it appears that TF has depicted the aircraft Sq markings incorrectly. My brief research has revealed that this particular aircraft was probably assigned to No. 57 Operational Training Unit at RAF Eshott Dec 40 - Jun 45. As such, the Sq letters "JZ" should appear fwd of the roundel on the left side and aft of the roundel on the right side. The aircraft letter "W" should appear aft of the roundel on the left side and fwd of the roundel on the right side. Any comments?
#147
I don't think a small detail like that detracts at all from how the Spitfire looksAs good as they are, these TP warbirds are more sport scale than an exact replica of the real thing.
There is always the option to make new markings, that is what i am doing with my P-40, the Chinese star markings don't really smoke my tyres
#148
My Feedback: (60)
AZ
Yeah, I considered that one. You'd have to modify the tail also..
Many, many Mk.IX's were built with clipped wings and the original short chord, rounded rudder as well. In fact you can find almost any combination of wing/rudder/canopy if you look hard enough!
#150
My Feedback: (157)
ORIGINAL: Chad Veich
