Reload this Page >
Hangar 9 60cc Corsair
Old 04-01-2018, 12:56 AM
  #2551
Marguet28
New gaz link..more rigid than the previous one. It is more precise now
Old 04-01-2018, 03:32 PM
  #2552
Mein Duff
Mein Duff's Avatar
Good Idea on that reinforcement ! I will have to look into that also...
Old 04-01-2018, 06:48 PM
  #2553
shrek514
anyone having trouble aligning the wing with the carbon fiber dowls.the holes dont aligne.
Old 04-01-2018, 07:19 PM
  #2554
Mein Duff
Mein Duff's Avatar
Mine seemed to line up OK, although there was quite a gap between wing and fuse when all locked down, filled all that in with balsa sheets.
Seems like everybody has had bad flap hinge point alignment issues....also not happy about the minimal alu flange contact connecting the flaps together....mine only extend about 3 mm into the next flap slit....this maybe enough in practice though and doesn't seem to be an issue for others so far.....but could be better designed by protruding further out.
Old 04-02-2018, 09:14 AM
  #2555
shrek514
Default Flap
Mine was too short i had to heat the glue and cut out and reposittion it. U can see the line were i had to pull it out
Old 04-02-2018, 10:08 PM
  #2556
Mein Duff
Mein Duff's Avatar
Wow !!! How did you reheat the glue ?? with a torch or soldering iron ..or ??
And " Cut it out " ....you mean with a sharp razor saw right around the metal flange ?
Good job....I may have to rework mine now !!
Old 04-03-2018, 06:26 AM
  #2557
shrek514
Default Flap
i used my heat gun
Old 04-10-2018, 06:55 PM
  #2558
shrek514
Is anyone running the saito 90 radial in there corsair. If so how big is your tank and how much flight time do you get. Also some pics of were you guys put your tanks Thanks
Old 04-10-2018, 09:33 PM
  #2559
Marguet28
I have two 12oz Dubro. I can fly 8/10 min
Old 04-11-2018, 10:28 AM
  #2560
[email protected]
Default help with CG
can any one with a hanger 9 f4u saito 90 r tell how your cg came out
thanks
bp
HGV (01-25-2022)
Old 04-11-2018, 10:39 AM
  #2561
[email protected]
Default f4 u CG
can some one help me with info on how your cg came out on a hanger 9 f4u with a saito fg90r3
i just finished mine this cg don't look right how much lead did you use if any
thanks
bp
Old 04-11-2018, 11:41 AM
  #2562
shrek514
Sorry im not at that stage yet
Old 04-11-2018, 12:46 PM
  #2563
[email protected]
Default tank
i ran a 22 0z tank on the test stand. it rand for 30 min about half thro
i installed a 16 oz in the aircraft,have not flown yet
Old 04-11-2018, 02:55 PM
  #2564
shrek514
Thanks for your input wperry. Let me know when you get her in the air
Old 04-14-2018, 06:39 AM
  #2565
kevarc
thanks
bp
I have saito 90r in mine and had to fill the ring at the front of the cowl with lead shot.
Kevin
Old 04-30-2018, 04:09 PM
  #2566
spitfire66
spitfire66's Avatar
Here is how I plan to make sure the center section will be bullet proof. The front wing dowels will be replaced by aluminum rods that will be run through the front spar. They will be about 8-10" and a hole will be drilled through the spar and hysol will be used. The wire shows the front spar where the hole will be drilled. The center section front mount on the fuselage will also be reinforced.
Old 05-12-2018, 10:20 AM
  #2567
rafim
Default Saito 450 r3
I searched the entire thread and did not find anyone flying this bird with a Saito 450 r3. It looks like at 5.5 HP the Saito 450 will have just the right amount of power to fly the plane scale and have reserve power when you need it. With all the hassles around the FG84, low power issues withe EVO 77, and excess power with the FG90, I would have thought the Saito 450 and the H9 Corsair would be a popular combo. Can anyone testify to this?
Old 06-24-2018, 06:45 PM
  #2568
ForcesR
Check this video out, the Saito 450 R3 in a Corsair, looks to be plenty of power!
Old 06-25-2018, 03:36 AM
  #2569
BarracudaHockey
BarracudaHockey's Avatar
Lets take the buying/selling to the marketplace or PM's
Old 06-25-2018, 10:35 AM
  #2570
Steve Haas
Just finished mine with an EME 70cc twin with a starter and it took 3.5lbs of lead to balance it at 5.250". Weighed in at 34.5lbs and it flew great.
Old 06-25-2018, 04:55 PM
  #2571
Doomking
My Feedback: (38)
Doomking's Avatar
Video or it didn’t happened.....lol , congrats on the flight ..
Old 06-25-2018, 04:58 PM
  #2572
Doomking
My Feedback: (38)
Doomking's Avatar
Question....
the torque rod that goes in the flap, one of the it’s a little sloppy .
there is about a 1/4” play when holding the servo arm and moving the flap up and down.
Short of cutting the hardwood out around the torque rod, is there a less invasive way to fix it?
Thanks for the help.
Old 06-25-2018, 05:29 PM
  #2573
Steve Haas
Did not get a video of the flight but her is a pic of the engine run-up.
Old 06-25-2018, 05:35 PM
  #2574
Steve Haas
This is after the flights
Old 07-01-2018, 03:12 PM
  #2575
Doomking
My Feedback: (38)
Doomking's Avatar
Looks great Steve....did you glass it or it is just covering from original art?
Also for those of you that fly this plane, is a gyro needed?
I fly currently Top Flite Giant P47 and P51 without gyro and such with no problem.
Never flown a Corsair so I am not sure.
thanks for the help.
