Hangar 9 60cc Corsair
#1401
My Feedback: (51)
Those bomb drop mecanisms are very susceptible to rf noise. I had one on a stuka with an electric siren on it and whenever I turned the siren on the mechanism started cycling all by itself. I used several capacitors to isolate the rf coming off the brushed siren motor to finally correct the problem. So, you'll need to identify the source of the noise, then figure out how to isolate it. I'm sure there are some rf gurus out there that can provide some guidance.
#1403
My Feedback: (41)
Zeeb,
I understand there’s no need to take it apart. Would you be willing to show some pictures of the fuel tank/servo area and cowl?
Does the one rocker arm cover show through the cowl? I see that the Saito is a very tight fit. Any help regarding the Saito/cowl/firewall offset would be helpful.
Thanks Tom
Thanks Tom
#1404
Russ
Thanks again for the information, my plans are to install the G84 without cutting the Cowl. Still deciding if I'm going to use the stock flex pipes or install the Keleo exhaust ring.
Zeeb
The pictures you sent are very helpful. I'll probably have some more questions in the future.
I ordered the plane from my LHS and should be here sometime mid to late January.
So here’s my list:
Saito FG-84
Robart Air retracts/Alum. Wheels
JR Servos
Ail / Elev 8231
Rudder 8411
Throttle/ Retracts 821
JR 370 Gyro (rudder)
12-Channel DSMX X-Plus PowerSafe Receiver
Pilot from Warbird Pilots
I’m looking forward to the project ..
Thanks Tom
Zeeb
So here’s my list:
Saito FG-84
JR Servos
Ail / Elev 8231
Rudder 8411
Thanks Tom
#1406
need help im trying everything to hing the rear doors but when i open the doors the hing pops off hing doesnt follow the door please can anybody post some pics or give me an idea on how to. im not very good at this door hinging thanks
#1410
My Feedback: (41)
Not precisely, as I've said I didn't assemble the model so I only have a vague idea of what they had to do as the guys didn't really seem like they wanted to talk about it a lot so I didn't press the issue.... lol
They said something about having to move the gear mounts forward to get the upper struts in, and then they said something about, and I'm guessing here, the oleo portion of the struts being 1/2" shorter than the Robarts. It wasn't real clear to me exactly what they did and the put the gear doors on the model so I don't really see anything obvious that would indicate what they did. Darrell said the gear is actually for a P-40 and should basically "drop in" if the holes in the wing for the mounting plates were "just moved forward". I haven't talked to Darrell since I ordered the gear as it's installed and I figure there's no point in me trying to chase it further.
If I get a chance to ask the guys, I'll see if I can get a better idea of what exactly they had to do. They're taking a bit of a holiday break but they've also started putting a Shockwave together for me so their minds are kind of off the Corsair now...
#1411
Roger
#1412
My Feedback: (41)
The guys that put my Corsair together both have one of these Corsairs and both have the Evo engine on them. They both run two blade props but I cannot tell you what size and pitch....
#1413
Ashworthb, just a heads up concerning the Evolution 777. Every 777 I seen with a 3 bladed prop, the performance on takeoff was very poor, barely enough ground speed achieved for takeoff. The Evo 777 does not perform well with a 3 bladed prop and a 4 bladed prop would be totally out of the question. All of the owners switched to a 2 bladed prop and it made a world of difference during takeoff speed and flight speed.
Roger
Roger
#1414
Hmmm, I purchased a 3 blade Biela (http://www.aircraftinternational.com...5/Default.aspx) and over in the EVO radial thread there's another guy using a 3 blade prop (although it's the Xoar, not Beila) and he says it flies great for his taste anyhow. I think he has the 7-70 as well which is the smaller capacity Seidel/UMS version.
Hopefully mine works out OK, might buy a 24x10 2 bladed prop as well just in case.
#1415
How can you tell if it's a Biela prop? I just purchased a 3 blade prop that was sold as a Biela and it looks nothing like the one you purchased at http://www.aircraftinternational.com...5/Default.aspx. Your prop looks much more scale than the one I got. Should it have Biela stamped on it anywhere? Any help appreciated. Sorry if this is a little off topic.
#1416
hopefully you didn't get ripped off gary! The one I bought has Biela on all 3 of the 'scale' Hamilton prop logo -circular logos in the middle of the blades-. Though I think there are 'standard' 3 bladed props, and semi-scale props like the one I purchased. Mine is the Corsair style semi-scale propellor. Looks great! Don't know how well it performs yet as I'm waiting on my 7-77 to be converted to CDI ignition at the moment.
#1417
My Feedback: (41)
Biela makes two (that I know of) types of three bladed props as chorner mentioned. I think one of the really interesting/funny things about the semi-scale and the Hamilton decals is that, from what I understand, there was a copyright issue about the decals so instead of saying "Hamilton Standard", they say "Hamilton Biela".
garyFL; you ordered the wrong prop. If you have not drilled the one you have or in any way modified it, Gerhardt is usually pretty good to work with, he might exchange it for you.
#1424
