Reload this Page >
Hangar 9 60cc Corsair
Old 05-23-2019, 02:01 PM
  #2651
heirmeistr
Both are excellent ideas! Thank you so much
I was not expecting a response this quickly - awesome
Old 05-24-2019, 02:49 PM
  #2652
heirmeistr
Originally Posted by heirmeistr
I have a new in the bag Dummy Radial Engine if someone needs one. The list price was $18, so how about $15 plus shipping?
The Dummy Radial Engine has found a new home. I am glad someone was able to use it.
Old 05-30-2019, 04:36 PM
  #2653
spitfire66
spitfire66's Avatar
I received my Robart wheels that I ordered, which were for the TF Hellcat. I liked the dips in the wheel and opted for those instead of the corsair wheels. It also came with a tailwheel that was way too big for the corsair retract. Although the website says the hellcat wheels are 5", the packaging says 5", and the robart tire says they are 5", they are actually 4.5"! I fly off grass and need the bigger wheels, not to mention bigger is more scale. Also worth mentioning was that they were hard as a rock! So I decided to send them back for a refund.
My question is are the H9 Robart Corsair 5" wheels actually 5"? If so I need to get some ordered up, which are backordered until late July. If anyone has a set to sell I'm interested as well.
Old 05-30-2019, 05:30 PM
  #2654
Corsair Bill
Yep, you’re right there is some confusion regarding the Hellcat wheels. There is an addendum to the Hellcat instructions that the scale wheels will be 4.5” instead of 5”. When I received the scale wheels the packaging stated 5” but they were 4.5. I’m sure the downsize in diameter is due to the tight tolerances when the gear is retracted into the wheel well. HH and Tower need to change description on their website and packaging.
Bill
Old 05-30-2019, 05:34 PM
  #2655
Chris Nicastro
Chris Nicastro's Avatar
For comparison the TF Corsair tires are 4.5in dia. And it has a 1in. longer wingspan than the H9. The Robart 5in aluminum wheels set for the P-51 are actually very close to 5in so it’s strange the set you bought are that far off.
Take a look at Sierra Giant Scale for wheels if you want something better than Robart.
I dont one like the look but I’m kind of interested in the inflatable Dubro 4.5in wheels because you can run them at low pressure. The same wheels in solid foam are pretty stiff. It would be cool to take the gray plastic ugly wheel out and replace it with an aluminum one so you have the best combination.
Old 05-30-2019, 05:47 PM
  #2656
camss69
My Feedback: (46)
camss69's Avatar
Originally Posted by ForcesR
Found this photo in another forum.
That was mine, it was mounted on a removable tray. There’s a second bulkhead you have to go through which was kind of a pain but everything fit nice when I was done.
Old 05-31-2019, 05:31 AM
  #2657
spitfire66
spitfire66's Avatar
I have 5” Sierra wheels on my p51 and I really like the robart tires that are installed on the wheels, so that is what I was expecting. (Yes Sierra wheels use robart tires). I really like the powder coat of the hellcat wheels. They look better than what I can Do with paint. I’m trying to finish my Pitts and start my Corsair all before our second child arrives. The pressure is now haha
Old 06-05-2019, 05:09 PM
  #2658
heirmeistr
My next stumbling block with installing the FG90 radial is with the gas tank. There is not enough room with Carburetor sticking in the fuselage so far. What did others do to relieve this problem?
Old 06-05-2019, 07:27 PM
  #2659
DUCMOZ
please post your e-mail address or pm me and I can send you pictures.
Behzad
Old 06-05-2019, 11:02 PM
  #2660
Marguet28
Old 06-06-2019, 03:45 AM
  #2661
BarracudaHockey
BarracudaHockey's Avatar
Anyone have a spare cowl they are willing to part with?
Old 06-06-2019, 10:16 AM
  #2662
Steve Haas
That one is still available on Flying Giants. He just replied to it today $50.00
  #2663
Steve Haas
Here is is
Hanger9 60cc Corsair Cowl - FlyingGiants
Old 06-06-2019, 11:04 AM
  #2664
BarracudaHockey
Yep, funny story, thats a guy from my old club that taught me to fly powered planes back in 1988 or so LOL
I tracked him down and grabbed that cowl.
Old 06-06-2019, 11:08 AM
  #2665
Steve Haas
I bought a spare cowl a few months ago and paid $75.00 for it. Have not seen anyone selling the gear doors would like a set for spares also.
Old 06-08-2019, 01:49 PM
  #2666
heirmeistr
Thank you DUCMOZ and Marguet28L Not sure why I didn't think of using smaller tanks and setting them off to the side! But that is what I am going to do.
Old 07-11-2019, 01:59 PM
  #2667
spitfire66
spitfire66's Avatar
I've been looking at this new UMS 125cc 5 cylinder radial. It measures a 265mm diameter and rated at 8 horsepower. I see the saito fg90 measures around 250mm. For those of you that have installed the saito radial, do you think there is any more room to fit this engine? I've been day dreaming. Another option is their 90cc 7 cylinder rated at 6hp and 230mm diameter which should fit without too much of an issue, but may be too small later down the road for another airplane.
Old 07-11-2019, 02:21 PM
  #2668
rslstft
My Feedback: (10)
rslstft's Avatar
The Saito just barely fits inside the cowl without any cutouts for the valve cover. I doubt anything with a larger diameter could be made to fit without major surgery on the cowling.
Old 07-11-2019, 02:24 PM
  #2669
DUCMOZ
not even 1mm to spare for Saito so 265mm would not fit.
Old 07-11-2019, 06:52 PM
  #2670
heirmeistr
I finally have the FG90, throttle servo, and gas tanks mounted. Tomorrow I am hoping to weigh the plane and check the CG. Those that have this same setup, did you have to add nose weight, and if so, about how much? I would like to compare with what I come up with.
Old 07-12-2019, 08:42 PM
  #2671
heirmeistr
Looks like I need to add about 2 lbs at the firewall to make the 120mm CG point.
I have an old cowl that was cut for a DLE-55 side exhaust. I then cut it for my FG90 Keleo exhaust. I will probably toss it unless someone thinks they might want it. Just pay for shipping.
I can post pictures if anyone is interested.
Old 07-27-2019, 12:15 PM
  #2672
hmauldin
Hey there Harry, don't chuck it yet! Could you post a picture?
Thanks, Hoyt M
Old 07-27-2019, 01:24 PM
  #2673
Todd D
My Feedback: (51)
Todd D's Avatar
where are you located? I’d be interested if shipping isn’t outrageous to 53051.
Old 07-29-2019, 09:13 PM
  #2674
heirmeistr
I just did a maiden flight on the Corsair this weekend. Sorry to those that expressed an interest, but I have decided to hang on to the old cowl, just in case.
Old 07-30-2019, 02:55 AM
  #2675
spitfire66
spitfire66's Avatar
Probably a good idea to hang on to it. Patch and paint when/if needed. How did the maiden go?
