ESM ZERO BUILD
#103
I got this scale shaped alum spinner from SDS. Just need to repaint it to the Zero's spec.
SDS said they make the three bladed kind if i want to. Ill order that next.
#105
#107
Spinner from SDS hobby. Its nicely made aluminum which is already bored for DA-50 and DLE-55.
Its painted for a Focke Wulf but its also shaped for the Zero. Ill paint it to scale with the prop.
SDS will make me one for 3 bladed prop
#111
Balanced! 19.8 lbs total weight. No nose dead weights. I had to take off the 5 cel "C" cell ignition batteries I initially installed to weigh the nose down. Turned out I dont need it. Back to 4.8 NiMh 2000mah.
#113
Thanks of course
#114
Temp Install of the Main Landing Gear Covers.
The brackets that holds the cover are Robarts. So they perfectly match the Robart struts. The only different thing I did was instead of the music wire that robart recommend to use in mounting the covers i just use 4-40 screws which are perfect in replacing the bracket's allen set screws So those srews also locked in place the covers for me.
#118
Thanks Gents! Just waiting for that perfect maiden weather. 5mph headwind on the runway
#123
Put on the strut cover stripes. Anyone knows what they're really for? I like to think theyre for the ground crew to see from a distance how much the struts are collapse to on the real plane cause theyre right where the split /sliding part of the covers were.
