Reload this Page >
New Hangar 9 P-51 60cc
Old 06-17-2015, 01:06 PM
  #976
nsyracuse
Just wanted to update on the cooling issues. I added a spoiler just in front of the rear cooling exit that is in front of the firewall. I flew today in 95° Georgia heat just wanted to update on the cooling issues. I added a spoiler just in front of the rear cooling exit that is in front of the firewall. I flew today and 95° and temps never spiked over 205° in-flight. It was running 30-40° cooler than it ever has even when it was cooler outside. Win-win. I may even try the rec90 unleaded again after this tank.
Old 06-17-2015, 03:09 PM
  #977
GR7Racer
nsyracuse....
I'm glad the spoiler seemed to help you out. It's a simple concept but some people either don't get it, reject it out-of-hand and keep trying bigger and bigger holes in their cowling, or believe in the great pumpkin!
Can you detail how you have your temp sensor installed? Maybe a pic?
KennyMac
Old 06-23-2015, 09:55 PM
  #978
kochj
Does anyone have a (firewall --- to--- backplate) measurement, so I could know what engines I could place in this plane????
The manual doesn't say anything about it.... only "use the engine that DOESN"T exist" LOL>....
Old 06-24-2015, 03:27 AM
  #979
185skywagon
Well I have had first flights success today. Beautifully flying aircraft.
ID:	2105467   Click image for larger version
Old 06-24-2015, 05:24 AM
  #980
CRG
160-161mm.
Old 06-29-2015, 07:07 PM
  #981
fhollahan
A couple of weeks back I discussed the mods with pics of the changes to my cowl to allow more air to flow thru and cool the engine. Well I finally got out today and took a few flights. I am happy to report that the extra cooling due to the changes worked great. I am very thankful for all the helpful tips on this thread in getting the airflow/cooling worked out! Here are some pics from the field today.
Name:	IMG_20150629_162948757 (1024x576).jpg
ID:	2106490   Click image for larger version
Name:	IMG_20150629_163000084 (1024x576).jpg
ID:	2106491   Click image for larger version
Name:	IMG_20150629_163011739 (1024x576).jpg
ID:	2106492   Click image for larger version
Name:	IMG_20150629_163021252 (1024x576).jpg
Old 07-09-2015, 11:25 PM
  #982
scubaozy
I am seeking a GS warbird with 2/3 piece wing such as this mustang and would like to have 4 stroke gas. I was looking into different engine options and bumped into torqpro 70. Do you think this will fit into the cowl without major surgery? Dimensions are here.
Last edited by scubaozy; 07-09-2015 at 11:35 PM. Reason: added link with dimensions
Old 07-10-2015, 05:36 AM
  #983
CRG
See attached for cowl protrusion, 36mm at the front of the valve cover.
Name:	TP70 in HAN P-51D 60cc.jpg
Old 07-10-2015, 07:11 AM
  #984
scubaozy
Awesome, thank you very much for that. I think 36mm is not too bad. I am much more concerned whether carburetor will clear lower firewall.
Old 07-10-2015, 07:56 AM
  #985
CRG
Looks like it but you'll at least need shorter standoffs.
Name:	TP70 in HAN P-51D 60cc 02.jpg
Old 07-28-2015, 11:53 AM
  #986
Shaun Evans
Shaun Evans's Avatar
Hi,
How much ballast did people add? Where did you put it?
Old 07-28-2015, 12:50 PM
  #987
old p47
right on top of the motor box under the muffler. I used a DLE 61. Get the aeroworks muffler to clear the side of the cowl. Or you will need someone to trim the muffler at the exhaust port and weld it up. My took 15 oz of lead to put it in the middle of the CG range.
Mike
Old 07-28-2015, 03:22 PM
  #988
quist
My Feedback: (198)
quist's Avatar
I molded 18 oz of lead mounted above the motor.
ID:	2111542   Click image for larger version
Old 08-11-2015, 11:31 PM
  #989
Stevedavy
Stevedavy's Avatar
Dear Kevin,Kalzone,
Hi guys, I have been reading your posts on the conversion to electric on this kit. I'm in the UK and would like to convert the model to electric but would really appreciate your help on how you positioned the batteries to get the C of G correct. I noted in your video you removed the cowl, hopefully to be able to swap out the batteries. I would be very grateful if you could take a picture or describe your battery arrangement so I could be confident that I get this correct. thanks for your help and to the thread for a lot of good Gen...
Steve.
Old 08-16-2015, 07:33 PM
  #990
kalzone
hi Steve i have some pics of what i did but its a pain to upload them on here if you would PM me your email and ill send them over along with the prop adapter info i have.
kallin
ID:	2114832   Click image for larger version
ID:	2114833   Click image for larger version
Old 08-17-2015, 04:10 AM
  #991
Stevedavy
Stevedavy's Avatar
Hi Kallin,
Thank you very much that would be brilliant. I'll PM you my email
Looking forward to getting the project finished.
Regards
Steve .
Old 08-17-2015, 05:17 AM
  #992
BarracudaHockey
BarracudaHockey's Avatar
Had mine out this weekend for our National Model Aviation Day event, it ended up on the local news, the reporter guy loved it.
Old 08-17-2015, 09:29 AM
  #993
Shaun Evans
BH,
Got any video?
Old 08-17-2015, 09:32 AM
  #994
BarracudaHockey
I was flying at the time, I'll check FB and see if anyone posted anything. We had a big crowd, it actually made me nervous.
Old 08-17-2015, 12:07 PM
  #995
quist
My Feedback: (198)
quist's Avatar
I had to fix my top nose sheeting so I took the opportunity to change markings. I used Callie Graphics.
Old 08-17-2015, 01:27 PM
  #996
BarracudaHockey
Yea, all due respect for the reason they are that way, I had Callie Graphics make the correct kill flags for mine as well.
Old 08-18-2015, 04:35 AM
  #997
Eddie P
Eddie P's Avatar
kallin
Hi Kalzone, have you flown your E power Mustang, yet?
Old 08-18-2015, 02:03 PM
  #998
kalzone
hi steve
i am using eflite 5000mah 30c 6s lipos. i was only able to fit the eflite and poteza batteries.the potenza are from flex innovations the thunder powers are to long by 5mm. what i did for the motor standoff was i drilled the firewall using the da50/60 pattern then i bought 4 bolts that were way long and put them through the motor mount and threaded them in until the spinner was about 1/8" to 3/16" off the front of the cowling. on the cowling i built a frame the held the cowling to the correct shape i used 4 canopy latches from seacraft. in the battery bay i put a wall that is just at the back of the batteries and at the front i built the door to hold them from moving forward. the door moves up and a magnet holds it up. the door has a spring latch on the bottom. i didnt have to use lead because i used the rx batteries and the landing gear batteries the get c/g right.
let me know if i can help anymore
kallin kimball
ID:	2115280   Click image for larger version
ID:	2115281   Click image for larger version
ID:	2115282   Click image for larger version
ID:	2115283   Click image for larger version
ID:	2115284   Click image for larger version
ID:	2115285   Click image for larger version
ID:	2115286   Click image for larger version
ID:	2115288   Click image for larger version
ID:	2115289   Click image for larger version
ID:	2115290   Click image for larger version
ID:	2115291   Click image for larger version
ID:	2115292   Click image for larger version
ID:	2115293   Click image for larger version
ID:	2115294   Click image for larger version
ID:	2115296   Click image for larger version
ID:	2115297   Click image for larger version
ID:	2115298   Click image for larger version
ID:	2115299   Click image for larger version
ID:	2115300   Click image for larger version
ID:	2115301   Click image for larger version
ID:	2115302   Click image for larger version
ID:	2115304   Click image for larger version
ID:	2115305   Click image for larger version
ID:	2115306   Click image for larger version
ID:	2115307   Click image for larger version
ID:	2115308   Click image for larger version
ID:	2115309   Click image for larger version
ID:	2115310   Click image for larger version
ID:	2115312   Click image for larger version
Old 08-18-2015, 02:06 PM
  #999
kalzone
hi eddie
yes ive got about 30 flight on her now. i guess i forgot to post a vid of it on here so ill post a link. im getting around 148mph and pulling 147+- amps at full power.
Old 08-18-2015, 02:12 PM
  #1000
kalzone
https://youtu.be/F2msBdr9P0g
this is from joe nall
