Reload this Page >
Seagull Spitfire 26- 38 cc
Old 03-14-2016, 10:48 AM
  #76
Prekin
My Feedback: (19)
Prekin's Avatar
Mountings for fuel tank and throttle servo are done. The fuel tank is too close to C.G. so the impact of the full or empty tank will be insignificant.
The throttle servo is more forward, so the bar will be shorter and wonīt a hidrance to other stuff.
ID:	2152602   Click image for larger version
Old 03-15-2016, 08:30 AM
  #77
Prekin
My Feedback: (19)
Prekin's Avatar
Anybody wants to see what is under the covering? Ribs are made from some plywood. Probably the same plywood as cockpit. Problem is in the aileron axle. It is already glued, so I canīt to take it out and recover ailerons.
ID:	2152719   Click image for larger version
ID:	2152720   Click image for larger version
ID:	2152721   Click image for larger version
Old 03-15-2016, 11:17 AM
  #78
Prekin
My Feedback: (19)
Prekin's Avatar
Today I decided to make a imitation of radiators in the oil coolers. I found very small-grained fibreglass net. Made a balsa radiator frame and glued one piece of the net from both frameīs sides. Now I thinking is I should other "radiator" to the rear part of oil cooler.
ID:	2152734   Click image for larger version
ID:	2152735   Click image for larger version
ID:	2152736   Click image for larger version
ID:	2152737   Click image for larger version
ID:	2152738   Click image for larger version
ID:	2152739   Click image for larger version
Old 03-15-2016, 12:34 PM
  #79
Prekin
My Feedback: (19)
Prekin's Avatar
Some pictures of real oil cooler.
ID:	2152752   Click image for larger version
ID:	2152753   Click image for larger version
ID:	2152754   Click image for larger version
Old 03-16-2016, 09:35 AM
  #80
Prekin
My Feedback: (19)
Prekin's Avatar
Both of the oil coolers are done.
ID:	2152852   Click image for larger version
Old 03-19-2016, 05:37 AM
  #81
Prekin
My Feedback: (19)
Prekin's Avatar
The weight of one 3-blade spinner is only 126 grams (4.4 oz). Diameter is 115 mm (4.5 inch), I think this one is suitable also for ESM 50 cc Spitfire and Fliteskin Spitfire Mk VIII.
ID:	2153109   Click image for larger version
Old 03-19-2016, 07:10 AM
  #82
ForcesR
It's too small, the ESM 50cc Spitfire is 119mm (4 & 11/16 inch) diameter.
Roger
Old 03-19-2016, 09:08 AM
  #83
Prekin
My Feedback: (19)
Prekin's Avatar
OK, thanks a lot.
Old 03-20-2016, 12:54 AM
  #84
Prekin
My Feedback: (19)
Prekin's Avatar
When I was removing the stripes on the wing, I found out that the black stripes are stickers. I thought that the same will be on the fuselage. But all the stripes on the fuselage (black, white and the last blue) are film. There is a big contrast between the colours, so not good for painting. Probably I will remove these stripes or all fuselage covering.
Rudder, stab and elevator are uncovered.
ID:	2153224   Click image for larger version
ID:	2153225   Click image for larger version
Old 03-22-2016, 08:38 AM
  #85
Prekin
My Feedback: (19)
Prekin's Avatar
I made new tail wheelīs leg. But I suppose, that 4 mm welding wire isnīt strong enough. I must buy some spring or stainless steel.
ID:	2153725   Click image for larger version
Old 03-22-2016, 11:15 AM
  #86
Prekin
My Feedback: (19)
Prekin's Avatar
New H9 wheels just ordered. Unfortunately Iīll have them in July. So maiden flight and I hope next flights will be with another wheels.
Old 03-24-2016, 02:31 AM
  #87
Prekin
My Feedback: (19)
Prekin's Avatar
Inner parts of oil coolers are painted.
ID:	2153944   Click image for larger version
ID:	2153945   Click image for larger version
Old 03-25-2016, 08:58 AM
  #88
Prekin
My Feedback: (19)
Prekin's Avatar
New mounting desk for elevator servos. There will be some bigger push rod, this one which you see is because of direction.
Old 03-26-2016, 11:14 AM
  #89
Prekin
My Feedback: (19)
Prekin's Avatar
Mounting blocks for the cowl.
Old 03-27-2016, 02:19 AM
  #90
Prekin
My Feedback: (19)
Prekin's Avatar
A naked fuselage. There are some places with strong layer of filler. I will little bit sand the fuse and then cover it.
ID:	2154377   Click image for larger version
ID:	2154378   Click image for larger version
Old 03-27-2016, 08:08 AM
  #91
Prekin
My Feedback: (19)
Prekin's Avatar
I must make a radius between the wing and fuselage, because there is a hole in the rear part of cowl. But these holes could be good for hot air outflow. But this out flow space I want to have in the belly around the chin scoop.
Cowl is particulary attached by small screws.
ID:	2154442   Click image for larger version
ID:	2154443   Click image for larger version
ID:	2154444   Click image for larger version
Old 03-27-2016, 12:46 PM
  #92
Prekin
My Feedback: (19)
Prekin's Avatar
Maybe better shots.
ID:	2154618   Click image for larger version
Old 03-28-2016, 09:54 AM
  #93
Prekin
My Feedback: (19)
Prekin's Avatar
As TerryW said, the nose is still too long. I had to said, he was right. Now the nose is 50 mm (cca 2") shorter.
The firewall as you it in following shot is 46 mm (1.8")/ 44 mm (1.7") long.
Old 03-29-2016, 08:16 AM
  #94
Prekin
My Feedback: (19)
Prekin's Avatar
Finally the right wing and stab are covered. Maybe it doesnīt look it, but I used a HK solid silver film. Elevators and rudder are covered by solartex.
For those who doesnīt know what the solartex is... Solartex is covering film, which looks like a fabric.
ID:	2154957   Click image for larger version
ID:	2154958   Click image for larger version
ID:	2154959   Click image for larger version
Old 03-30-2016, 08:46 AM
  #95
Prekin
My Feedback: (19)
Prekin's Avatar
Iīve already put the rivets on the top side of stabilizer. The botton part will be with preshading but without the rivets. I found good picture of the rivets details on the stab. But I put only seven lines of the rivets on the each half of stab.
ID:	2155127   Click image for larger version
ID:	2155128   Click image for larger version
Old 03-31-2016, 08:30 AM
  #96
Prekin
My Feedback: (19)
Prekin's Avatar
New tail strut frame is done. I donīt know the weight now, because the scales didnīt show me any figure. Probably it is less than 20 g (0.7 oz).
ID:	2155273   Click image for larger version
ID:	2155274   Click image for larger version
Old 04-02-2016, 07:54 AM
  #97
Prekin
My Feedback: (19)
Prekin's Avatar
Today have better scales. The weight is 16 grams (0.6 oz).
ID:	2155566   Click image for larger version
Old 04-11-2016, 09:51 AM
  #98
Prekin
My Feedback: (19)
Prekin's Avatar
Fuselage is covered. Itīs not in the best quality, but the biggest mistakes will be covered by paint and wear out.
ID:	2156914   Click image for larger version
Old 04-16-2016, 12:08 PM
  #99
Prekin
My Feedback: (19)
Prekin's Avatar
Finally done the elevator and rudder. I made a covering of sutures on the ribs. Last day I attached some rivets on the wingīs top skin.
ID:	2157633   Click image for larger version
ID:	2157634   Click image for larger version
ID:	2157635   Click image for larger version
Old 04-17-2016, 08:55 AM
  #100
Prekin
My Feedback: (19)
Prekin's Avatar
Some rivets on canopy added, mold for cannon blister is almost done.
ID:	2157752   Click image for larger version
ID:	2157755   Click image for larger version
ID:	2157757   Click image for larger version
