Reload this Page >
Seagull Spitfire 26- 38 cc
Old 04-18-2016, 09:32 AM
  #101
Prekin
My Feedback: (19)
Prekin's Avatar
The fibreglass tube in the wings was too tight. It was necessary to sand the inner space.
Finally I decided to put elevatorīs servos into the stabilizer, so I bought two Hitec HS 225 MG
ID:	2157949   Click image for larger version
Old 04-19-2016, 09:20 AM
  #102
Prekin
My Feedback: (19)
Prekin's Avatar
Gear bays I make from piece of hard paper.
ID:	2158088   Click image for larger version
ID:	2158089   Click image for larger version
Old 04-20-2016, 02:50 AM
  #103
Francis L M
Francis L M's Avatar
Are you going to fiber glass the wheel well?
and by the way she is really looking great well done.
Old 04-20-2016, 07:48 AM
  #104
Prekin
My Feedback: (19)
Prekin's Avatar
No, Iīm not Francis, only paint it. I think it would be useless to glass the bay.
Old 04-21-2016, 07:35 AM
  #105
Prekin
My Feedback: (19)
Prekin's Avatar
First shots of my Seagull Spitfire with JP cowl, for now in the silver covering and without the chin scoop and exhausts. The paint is coming soon.
ID:	2158327   Click image for larger version
ID:	2158328   Click image for larger version
ID:	2158329   Click image for larger version
ID:	2158330   Click image for larger version
ID:	2158331   Click image for larger version
Old 04-22-2016, 09:12 AM
  #106
Prekin
My Feedback: (19)
Prekin's Avatar
Today Iīve done the detailing of the fuselage. During next days I want to add the resin exhaust stubs to the cowl.
ID:	2158460   Click image for larger version
ID:	2158461   Click image for larger version
Old 04-23-2016, 09:36 AM
  #107
Prekin
My Feedback: (19)
Prekin's Avatar
Cockpit is finally done. For painting I used acrylic Tamiya paints. Base of cockpit painting is preshading, last layer is the cockpit green. I glued all cockpit details and fit the panels to fuselage. Then I glued the instrument panel and gunsight. Here you can see the result.
ID:	2158620   Click image for larger version
ID:	2158621   Click image for larger version
ID:	2158622   Click image for larger version
ID:	2158623   Click image for larger version
ID:	2158624   Click image for larger version
ID:	2158625   Click image for larger version
ID:	2158626   Click image for larger version
ID:	2158628   Click image for larger version
ID:	2158629   Click image for larger version
ID:	2158630   Click image for larger version
ID:	2158631   Click image for larger version
ID:	2158632   Click image for larger version
ID:	2158634   Click image for larger version
ID:	2158635   Click image for larger version
Old 04-26-2016, 04:15 AM
  #108
G T
Your Spitty is really coming together nicely, a great build thread you have showed us all here. Funny how we start off with a standard build with just a few mods so we have a new plane to fly, and then we just start making it better and adding more as the build progress's along. Great work thanks for sharing the build..��
Old 04-26-2016, 07:04 AM
  #109
Prekin
My Feedback: (19)
Prekin's Avatar
Thank you for the kind word G T. I think thatīs good, we can share our threads. Because our projects could be an inspiration for the others. But the important is, I donīt know everything, so the other guys can give some solution or their opinion when I have any problem during the build.
Old 04-29-2016, 10:15 AM
  #110
Prekin
My Feedback: (19)
Prekin's Avatar
New wheels for my Spitfire. Now the are at the aribase in Afghanistan, so I will have them in my hand during July.
ID:	2159933   Click image for larger version
Old 04-29-2016, 11:29 AM
  #111
Prekin
My Feedback: (19)
Prekin's Avatar
Distance nuts for tail wheel strut are done. Now I can add and connect the control lines.
ID:	2159937   Click image for larger version
ID:	2159938   Click image for larger version
Old 04-30-2016, 07:43 AM
  #112
Prekin
My Feedback: (19)
Prekin's Avatar
In the following shots is visible how work my distance nuts. In each of them I drilled holes and threads for the locking screws. In the bigger one I also drilled holes for the arms.
ID:	2160086   Click image for larger version
ID:	2160087   Click image for larger version
Old 05-01-2016, 10:06 AM
  #113
Prekin
My Feedback: (19)
Prekin's Avatar
Tail wheel strut is done. You can compare which one is better. The mine has a half weight of the Seagullīs one.
During fitting the cowl I found a 5 mm space between the fuselage and the cowl. It will be good for flow rate.
ID:	2160369   Click image for larger version
ID:	2160373   Click image for larger version
ID:	2160374   Click image for larger version
ID:	2160375   Click image for larger version
ID:	2160376   Click image for larger version
ID:	2160377   Click image for larger version
ID:	2160378   Click image for larger version
Old 05-02-2016, 08:46 AM
  #114
Prekin
My Feedback: (19)
Prekin's Avatar
All Spitfire models have one common problem- cooling of the engine. There are no much places where we can make holes for air intake. Do you know what is the ejection effect? This effect use small airbrushes. During flight the holes behind the engine will create this ejection effect, it takes out some hot air from the engine area.
ID:	2160516   Click image for larger version
Old 05-03-2016, 10:00 AM
  #115
Prekin
My Feedback: (19)
Prekin's Avatar
Some last days I engaged with scale pilot painting. The head Iīve partly done. I canīt sleep because of my nightmare- pilotīs glasses. This next task is closer and closer.
ID:	2160656   Click image for larger version
ID:	2160657   Click image for larger version
Old 05-03-2016, 11:30 AM
  #116
Prekin
My Feedback: (19)
Prekin's Avatar
Here are shots as a result of my seeking of the glasses detail.
ID:	2160671   Click image for larger version
ID:	2160672   Click image for larger version
ID:	2160673   Click image for larger version
ID:	2160674   Click image for larger version
ID:	2160675   Click image for larger version
ID:	2160676   Click image for larger version
ID:	2160677   Click image for larger version
ID:	2160679   Click image for larger version
ID:	2160680   Click image for larger version
ID:	2160681   Click image for larger version
ID:	2160682   Click image for larger version
Old 05-05-2016, 10:44 AM
  #117
Prekin
My Feedback: (19)
Prekin's Avatar
Small progress on pilotīs head. Iīve done the leather helmet. Now Iīm going to play with glasses and earphones.
ID:	2161095   Click image for larger version
ID:	2161096   Click image for larger version
Old 05-06-2016, 10:43 AM
  #118
Prekin
My Feedback: (19)
Prekin's Avatar
Here is my exhaust set in the cowl. For the comparison some shots of the real exhausts.
ID:	2161216   Click image for larger version
ID:	2161217   Click image for larger version
ID:	2161218   Click image for larger version
ID:	2161219   Click image for larger version
ID:	2161220   Click image for larger version
Old 05-08-2016, 08:47 AM
  #119
Prekin
My Feedback: (19)
Prekin's Avatar
The tail is finally done.
Old 05-11-2016, 08:14 AM
  #120
Prekin
My Feedback: (19)
Prekin's Avatar
Today I received new struts.
ID:	2161997   Click image for larger version
Old 05-13-2016, 11:03 AM
  #121
Prekin
My Feedback: (19)
Prekin's Avatar
I had some remainder of epoxy, so I put one layer of epoxy into gear bays. The exhaust slats are done, so Iīm going to paint them.
ID:	2162275   Click image for larger version
ID:	2162276   Click image for larger version
ID:	2162277   Click image for larger version
Old 05-14-2016, 10:50 AM
  #122
Prekin
My Feedback: (19)
Prekin's Avatar
Cowl and chin scoop set. In the bottom part of cowl I cut of part of the cowl as a doors for engine. There is not many space to attach the cowl on the engine with the spark cylinder.
ID:	2162422   Click image for larger version
ID:	2162423   Click image for larger version
Old 05-15-2016, 11:18 AM
  #123
Prekin
My Feedback: (19)
Prekin's Avatar
Here is result of my last day. Pilot is almost done. The battle dress is not completed, because the blue paint is very bright and light.
ID:	2162540   Click image for larger version
ID:	2162541   Click image for larger version
ID:	2162542   Click image for larger version
Old 05-16-2016, 07:22 AM
  #124
Prekin
My Feedback: (19)
Prekin's Avatar
Body and head are done. Now will paint legs.
ID:	2162786   Click image for larger version
ID:	2162787   Click image for larger version
ID:	2162788   Click image for larger version
Old 05-18-2016, 09:14 AM
  #125
Prekin
My Feedback: (19)
Prekin's Avatar
Here is the composite cannon blister on the Seagullīs Spitifre wing.
ID:	2163091   Click image for larger version
