Reload this Page >
CARF SPITFIRE ASSEMBLY and SCALE DETAILING
Old 08-11-2016, 10:13 AM
  #51
nicoladestro
..Any news ?!?
Old 08-15-2016, 02:18 PM
  #52
RAMMJETT
RAMMJETT's Avatar
Hello I am posting this for my close friend and flying buddy (Krazy Kanuk) I am sorry to say Brian lost his battle with cancer July 29 / 16 .God bless you Brian , Fly high buddy .
Old 08-15-2016, 02:30 PM
  #53
DrScoles
My Feedback: (18)
DrScoles's Avatar
Very sorry to hear that. Cancer takes far too many good people.
Old 08-15-2016, 03:28 PM
  #54
BobH
Oh man. So sorry to hear this news.
Old 08-16-2016, 03:26 AM
  #55
DraganRi
Rest in peace
Condolences to family
Old 08-16-2016, 11:52 AM
  #56
nicoladestro
Rest in peace. I was following him from Italy...
Old 08-18-2016, 11:20 AM
  #57
jamie_wram
Oh no...I'm really sorry. I was following him from NY. Condolences to your family. Best to you Brian-
Old 08-18-2016, 11:27 AM
  #58
jamie_wram
Hi Nicoladestro. I just read the very sad news about Brian. Sorry for not getting back to you sooner. To answer your question--Kolm sells an install kit for the 150 with a wooden cut out/silhouette of the engine. This makes centering the engine with a small offset quite straightforward.
ID:	2177463   Click image for larger version
Old 08-18-2016, 12:59 PM
  #59
nicoladestro
Thank you.
I am evaluating the dla116 in line engine. It is cheapest than kolm. I will try to make a fake wood engine with my cnc machine in order to centre everything.
Thanks again.
Regards.
Old 01-24-2018, 10:08 AM
  #60
RAMMJETT
RAMMJETT's Avatar
Well I am going to pick up where Brian left off, After his passing he left me the spitfire to finish . It's taken me a while to get to it but I will post some of my progress . he purchased a Kolm 77 for the spit but I did not think it enough so I purchased a Valach 120 inline .
ID:	2252089   Click image for larger version
ID:	2252090   Click image for larger version
Old 01-24-2018, 10:20 AM
  #61
RAMMJETT
RAMMJETT's Avatar
You can see in the above pictures I started the functional exhaust , the cooling system is done and I mounted a 60mm cooling fan to help things out. Brian wanted the tropical version because that is the plane the Canadian ace flew" Buzz Burling" . The carf spit really has poor detailing on the cowl and I though it looked terrible with the top of the hood being cut in half so I removed the upper front portion of the fuse and joined it to the cut off portion of the top of the cowl , it now has a much smoother look , also the awful raised screw heads that carf had molded in will all be ground off and replaced with aluminum fasteners made to look like the dzus fasteners that were used on the spit . this also gave me great access to the inside of the fuse
ID:	2252092   Click image for larger version
ID:	2252093   Click image for larger version
Old 01-24-2018, 10:29 AM
  #62
RAMMJETT
RAMMJETT's Avatar
I also had to redo the sliding canopy as Brian was having trouble with it . what I did was make a lightweight brass frame and screwed the plastic parts to it . works fine now . he also had the fuel filler mounted to far forward . he mounted the fueller at the front of the fuse ,this is actually in the middle of the top of the engine cowl . So I made a new more realistic looking filler and recessed it into the fuse as the real spit was ,this time locating it in the fuel tank.
ID:	2252095   Click image for larger version
ID:	2252096   Click image for larger version
ID:	2252097   Click image for larger version
ID:	2252098   Click image for larger version
ID:	2252099   Click image for larger version
ID:	2252100   Click image for larger version
Old 01-24-2018, 12:39 PM
  #63
jamie_wram
Default Nice work! Love the joined cowling.
Love the cowling idea. I may have to copy you 😉. Solid choice in engine too! Looking forward to seeing more updates. Best James.
Old 01-24-2018, 02:14 PM
  #64
RAMMJETT
RAMMJETT's Avatar
Yeah to me the best part of the spitfire is that long sexy hood , It just looked all wrong with the thing cut in half and a row of misplaced frankenstien bolts running through it . Even the sides look better now . I would like to think of a way to make the side panels full length also but it seems the best I can do is grind of the fake screw heads and make the join as hidden as possible . I went for the Valach for 3 reasons . first it has a single carb to help with setup/reliability , secondly it's a bit lighter ,and thirdly it was easier to run functional exhaust . you would have to use the tropical filter to run the Valach because there needs to be a small hole cut for clearance .
Old 02-01-2018, 07:49 AM
  #65
RAMMJETT
RAMMJETT's Avatar
a little more work , mounted the landing gear ,was a little tricky because of the angles used on the spitfire . I am thinking of converting the gear to electric (dose anyone have experience with LADO products ,they make actuators for conversions) anyway I am am making new gear doors as the Carf ones are big heavy ugly things (big flat piece of plywood with glass on both sides ) I will be making the new doors from aluminum and they will actually weigh 20g less each , yeah hard to believe that a composite part is actually heavier then the real material LOL. anyway I also have the formed inner liners for a little more detail .
ID:	2253044   Click image for larger version
ID:	2253045   Click image for larger version
ID:	2253046   Click image for larger version
Old 02-01-2018, 08:05 AM
  #66
RAMMJETT
RAMMJETT's Avatar
took a couple of shots of the front of the plane to give you a idea of the access to the front of the plane with the hood removed . you can see I have the throttle and choke servos in place . also I machined a better looking fuel filler and recessed it into the fuse like the real spitfire .next will be to mount the fuel tank under the filler , the fuel pump and fuel filter will be mounted inside the plane on the back side of the firewall , the ignition will be mounted on the tray beside the the throttle and choke servos . I will wire the cooling fan direct to the receiver output . the fuel pump and ignition I will feed off the ultra IBEC . this way the fuel pump will only run when the ignition is on and the cooling fan will run until the receiver turns off . fan draw is 20mah the pump draw is 30mah so not much sense having extra batteries .I have been running my ignitions through a ultra IBEC with no trouble for years .
ID:	2253048   Click image for larger version
Old 02-09-2018, 12:26 PM
  #67
RAMMJETT
RAMMJETT's Avatar
Well I tell ya, you have to want gear doors real bad to install them on this kit , I would say this kit is a total botch job as far as the landing gear blocks and
the shape of the supplied gear doors , not to mention the gear mounting blocks were at different heights in both wings . thankfully the landing gear blocks were
1/4" too low to even let the landing gear lock in the up position , the blocks also need to be ground to allow the wheel to be pushed forward in the well.
quite shocked at the poor alignment of these items, for the price of the kit I think they could do a bit better job. I have decided to go electric on the landing
gear and have the actuators on the way .I have also mocked up some fairings to cover the landing gear Mounting bolts . I can't believe that CARF would have
you leave the holes wide open??? anyway this is how far I have gotten..
ID:	2254007   Click image for larger version
ID:	2254008   Click image for larger version
ID:	2254009   Click image for larger version
ID:	2254010   Click image for larger version
Old 02-09-2018, 12:49 PM
  #68
BobH
Ramm,
Is this a newer Kit from CARF?
Old 02-09-2018, 07:54 PM
  #69
RAMMJETT
RAMMJETT's Avatar
The kit was purchased 2016 . I don't want to get to down on Carf ,there is a lot of nice detail and most of the parts are really nice .
So far I have found if you want the canopy to open you will need a spare canopy . The landing gear block alignment is out to lunch .
cowl detail is way off scale , they actually have star screw heads sticking out 1/8" all over the cowl. The spitfire used Dzus that
sat flush . With a kit like this, it begs for detail ,I would rather CARF omitted some detail then use details you have to spend
hours grinding off to fix. Anyway all problems are fixable but totally unnecessary .Would not cost any more to do it right .
Old 02-09-2018, 07:59 PM
  #70
RAMMJETT
RAMMJETT's Avatar
starting the fairings
ID:	2254039   Click image for larger version
ID:	2254040   Click image for larger version
Old 02-09-2018, 09:04 PM
  #71
BobH
I agree. It's easier to make something right the first time. I have no idea why manufacturers produce such stupid stuff when its totally unnecessary.
I asked if it was a new kit because I've been looking at the CARF Spit for a while.
Sorry to hear of the issues.
Old 02-10-2018, 07:21 AM
  #72
RAMMJETT
RAMMJETT's Avatar
Don't be scared off by my comments ,it's still a very complete kit and well worth doing , I just don't understand why one would not make the canopy
so it could be cut without buying another very expensive canopy . I don't mind fabricating but having to repair problems that are build in is a bit
disappointing .
Old 02-10-2018, 08:20 AM
  #73
f4u1 pilot
What is the issue with the canopy that you need two?
Old 02-10-2018, 10:22 AM
  #74
RAMMJETT
RAMMJETT's Avatar
They made the frame joint between the windshield and canopy cover so thin you need to sacrifice one or the other
or there will be no flange on one side . . stupid really for such a detailed plane that begs for a sliding canopy .
Even when using 2 canopy's it a bit of a problem because you are extending the overall length .
if you look at my canopy picture the sliding part of the canopy has the full frame on it and its very thin , the front windshield is another
canopy set with the full frame left on the windshield side. on the windshield side I also used a bit of scrap from the cowl trimmings to make
a flange that the canopy can slide under . hopefully this makes sense .
Old 02-10-2018, 11:03 AM
  #75
f4u1 pilot
Yes i see what you have done.I am also working on one of these trying to get the canopy fitted .Very frustrating.thanks for posting your pic's they are helpful!
