Reload this Page >
CARF SPITFIRE ASSEMBLY and SCALE DETAILING
Old 02-10-2018, 11:29 AM
  #76
BobH
I'm guessing you added the Frame around the canopy and windscreen as well?
Looks good
Old 02-10-2018, 11:39 AM
  #77
RAMMJETT
RAMMJETT's Avatar
I built the brass frame inside . the outside frame comes as a complete fiberglass canopy
that you cut out to the shape of the frame . it's like a fiberglass overlay that sits on top of the canopy
I will post pictures later as I still have a spare set.
Old 02-10-2018, 05:33 PM
  #78
RAMMJETT
RAMMJETT's Avatar
Here is a couple of pictures of the canopy and fiberglass cover . I took a picture of the one I had to sacrifice .
same with the clear you have to sacrifice one .you can just make out the very narrow band between the
windshield and the canopy cover . far to narrow to cut down the middle.
ID:	2254140   Click image for larger version
ID:	2254141   Click image for larger version
Old 02-10-2018, 05:43 PM
  #79
RAMMJETT
RAMMJETT's Avatar
I have just about finished the fairing that cover the landing gear mounting bolts . Also been fitting
the rad , I am making the rad cover the flap linkage , also applied some of the access panels to the bottom
of the wing for a little added detail (from clark industries) I have ordered the hardware to replace the
temp cap head screws holding the retract covers in place (will be using flush mounted screws so they look
like rivets . Really starting to take on the look and feel of a real machine rather then a fiberglass shape..
Soon I will be hitting the lathe and machining up the 20mm cannons ,have the lighting kit so you can see the
muzzle flashes on the strafing runs.. .
ID:	2254143   Click image for larger version
ID:	2254144   Click image for larger version
Old 02-11-2018, 03:44 AM
  #80
f4u1 pilot
Fairing covers turned out nice! what material are you making cannon's out of? Have seen people 3d printing them.
Old 02-11-2018, 08:27 AM
  #81
RAMMJETT
RAMMJETT's Avatar
The covers are not scale but I just can't live with those big holes . I wish I could do 3D printing ,
I am more of the hammer and chisel type of builder , I would be lost programming a printer .
I was planning on using aluminum or plastic . what I need is a good picture of the cannons ,I will take
a look through my stuff ,but if anyone has a nice shot of the cannons please post it .
Old 02-11-2018, 09:15 AM
  #82
BobH
Supermarine Spitfire Mk. IX in Detail - Wing & Undercarriage details
Take a look there. Good details on the Spit.
Old 02-11-2018, 09:58 AM
  #83
f4u1 pilot
How's this.
Old 02-11-2018, 10:03 AM
  #84
f4u1 pilot
Old 02-11-2018, 10:54 AM
  #85
RAMMJETT
RAMMJETT's Avatar
thanks guys that't great . Wow measurements to boot .
Old 02-11-2018, 11:19 AM
  #86
RAMMJETT
RAMMJETT's Avatar
Quite impressed with the fairings once installed .
ID:	2254252   Click image for larger version
Old 02-11-2018, 11:35 AM
  #87
f4u1 pilot
Smile
I was hoping your lathe skills were better than mine and you could make 2 sets. Iwas looking at my documentation looks lik wheel door screws were round headed with straight slot screw blade.
Old 02-11-2018, 04:15 PM
  #88
RAMMJETT
RAMMJETT's Avatar
Yeah I have the hardware on order , I've ordered all aluminum screws to help with weight , when it comes in
I will replace all hardware except wing bolts and engine mounts . after seeing the pictures of the cannons it think it will be hard to machine
them inside to get enough weight out . so I will try vacuum forming some ,I turned up a balsa blank on the lathe and painted it with epoxy
when it hardens I will split in two and try to use them for vacuum forming , if it works out I will gladly make a couple more .
I cant be that exacting with balsa but they will look close..
ID:	2254323   Click image for larger version
Old 02-11-2018, 05:01 PM
  #89
BobH
That will look just fine.. nice work!
Old 02-12-2018, 02:49 AM
  #90
f4u1 pilot
They look great!! You are fast. Will gladly pay you for them. Just let me know how much. Mine could be made out of lead.I am using a DA 85, need lots of weight up front.
Dave
Old 02-12-2018, 07:02 AM
  #91
RAMMJETT
RAMMJETT's Avatar
Ok have the cannon split , when vacuum forming I like to cut slots into the backing block
for the plug so the vacuum will pull tightly into the corners ,as this is a tight radius . Mama is gone
to work so the oven is free .LOL. I just noticed F4u you are in Windsor , if they turn out ok
I will try to get some sent to you. I will also be Vacuum forming a fairing (fillet)that the cannon
goes into to mount it to the wing .
F4U do you have a build thread for your spitty
ID:	2254395   Click image for larger version
Old 02-12-2018, 07:45 AM
  #92
f4u1 pilot
No I don' t have a build thread Ram just watch others. Typing skills poor wouldn't have time to build. As it is this is 3 yr's on this build.😵 will try and post some pic's.Having trouble right now on my phone cant find attach icon?
Dave
Old 02-12-2018, 06:48 PM
  #93
RAMMJETT
RAMMJETT's Avatar
Ok so the vacuum forming went pretty well for my first attempt , I find with the tight curves you need to use thin material .030"
I think they are just to light and would damage easily . I am going to try to fill them with spray foam and when it
sets trim off the excess and epoxy them together . if that does not work I will be making balsa cannons .
ID:	2254445   Click image for larger version
ID:	2254446   Click image for larger version
Old 02-12-2018, 10:20 PM
  #94
Chad Veich
My Feedback: (60)
3d printing is an option to consider. May not be the cheapest option but they can be made very light and still plenty rigid.
ID:	2254464   Click image for larger version
Old 02-13-2018, 03:10 AM
  #95
f4u1 pilot
Nice work to both of you!
ID:	2254478   Click image for larger version
ID:	2254479   Click image for larger version
Old 02-13-2018, 05:49 AM
  #96
RAMMJETT
RAMMJETT's Avatar
Very nice work so far . love the flaps . with that amount of work you should be running a four cycle .
Old 02-13-2018, 05:59 AM
  #97
RAMMJETT
RAMMJETT's Avatar
If I could 3D print I would give it a shot because they do look good .How much do they weigh.
I tried injecting mine with foam and trimmed them on the belt sander and they came out great ,
they are now quite solid and super light @ 14g . next I will be installing the machine gun kit to
give the cannons muzzle flashes on the low passes . after that I will glue the two halves together
and move onto the cannon fairings .
ID:	2254481   Click image for larger version
ID:	2254482   Click image for larger version
ID:	2254483   Click image for larger version
Old 02-13-2018, 06:05 AM
  #98
RAMMJETT
RAMMJETT's Avatar
Forgot the picture of the weight, very strong for only weighing 1/2 oz .
trying to keep the weight of the scale details down ,as they start to add up
after a while .
Old 02-13-2018, 07:57 AM
  #99
f4u1 pilot
Love to but way out of my price range. cannons look great! These are early pic's a lot more detailing has been done. Will post some more recent shots but don't want to hijack your thread.
Old 02-13-2018, 09:34 AM
  #100
RAMMJETT
RAMMJETT's Avatar
I can pm you my email .
