Reload this Page >
NEW Legend Models 79.5" F8F Bearcat!
Old 08-28-2016, 08:59 AM
  #76
JohnVH
My Feedback: (38)
JohnVH's Avatar
Not exact, but 3.5lbs ish
Old 08-28-2016, 09:26 AM
  #77
Lifer
Lifer's Avatar
The reason I asked was I wondered if a 55cc engine might have been a better choice? Assuming the firewall was strong enough and there was clearance for a 22 inch prop. (Or a 20 inch 4-blade.)
Old 08-28-2016, 09:34 AM
  #78
JohnVH
My Feedback: (38)
JohnVH's Avatar
Maybe. I'll have an exact number soon. Stores are closed here on Sunday to go buy weights.
Old 08-28-2016, 12:05 PM
  #79
Gmann6843
Seems that putting a DLE55RA and maybe another feature like EME Autostart would solve the problem without just adding dead weight.My thinking is better to add features of preformance in wieght than dead wieght.But this is the problem with short nosed fighters.......................................... ........................
Old 08-28-2016, 12:32 PM
  #80
Lifer
Lifer's Avatar
Does the 35cc engine cylinder project very far out of the cowl?
Old 08-28-2016, 12:43 PM
  #81
Gmann6843
This is a pic he posted earlier doesn't seem to project much at all..................
Old 08-28-2016, 03:00 PM
  #82
Lifer
Lifer's Avatar
So, with a 55 you would have additional weight up front, and the head fins would be out in the breeze.
Old 08-28-2016, 03:13 PM
  #83
JohnVH
My Feedback: (38)
JohnVH's Avatar
a 55 with electric start would be pretty cool, and a heavier 4 blade prop!
Old 08-28-2016, 03:39 PM
  #84
JohnVH
My Feedback: (38)
JohnVH's Avatar
Ok, went to bellingham and bought 1/4" solid lead, got that all zip tied onto the firewall, need to assemble for a final time and do a gear swing check to get the inner doors completed, then I can put in the fuel tank and cover up that servo. I have all the wiring done, I think its all done other than double checking the inner door servo and the balance, see how much it will really need! Ofcourse it started raining, and I have no room inside to do it properly, so Ill finish that after work tomorrow, or tonight after the kid goes to sleep.
Old 08-29-2016, 08:12 AM
  #85
Gmann6843
You know the EME autostart will fit on a DLE35RA .........Here is a Youtube of one fitted on a Hanger 9 Beaver which is about the cowl diameter as your Bearcat. https://www.youtube.com/watch?v=998wXEOqMJs
ID:	2178807   Click image for larger version
Old 08-29-2016, 08:16 AM
  #86
JohnVH
My Feedback: (38)
JohnVH's Avatar
Yep, itll be in the future.
Old 08-29-2016, 08:45 AM
  #87
Lifer
Lifer's Avatar
What does the starter weigh?
Old 08-29-2016, 10:02 AM
  #88
baronbrian
My Feedback: (13)
baronbrian's Avatar
DLE 55ra is about 500g heavier with muffler and everything, and about .5 inches taller and longer. I dont see any downsides here. I want to know his AUW with the 3.5lbs of ballast before I buy one! any idea on the shipping charges?
Old 08-29-2016, 10:05 AM
  #89
JohnVH
My Feedback: (38)
JohnVH's Avatar
I did weigh it in pieces last night, the total combined weight was right at 20lbs RTF, But Ill confirm that tonight after I see how much weight I can take back off, need to put it together outside for the final W&B check.
Old 08-29-2016, 10:20 AM
  #90
Gmann6843
Specs:Total Weight - EME 35cc starter 19oz. (19 oz.) Controller (2 oz.) and the Lipo between 3.5 oz. & 4 oz. give or take 1.5 pounds ,Most of this weight a little over a pound would be as far forward as possible just behind the prop. Here is a web site that sells the EME autostarter http://www.milehighrc.com/EME_E_Start_30_35.html
Old 08-29-2016, 10:23 AM
  #91
JohnVH
My Feedback: (38)
JohnVH's Avatar
That would be awesome! Ive been spending too much money lately, but in the future Ill be adding one!
Old 08-29-2016, 12:24 PM
  #92
Gmann6843
You are definitely running heavy according to the spec's of the plane. I wonder how the retract are going to handle the extra weight if you need to change out the retracts you might look at this one from RC Aerodyne all medal says it supports up to 22 pounds but I believe it would handle more weight with no problem and it is a local company for you and I based in Kent Wa.shipped to you for about
$161.06.here is a web page and a youtube of the retract showing the innerworking of ithttp://www.scaleflying.com/Electric-Retracts-60-120-size-90-Degree-Pair_p_2881.html
https://www.youtube.com/watch?v=Px_SpW9gJFU&index=11&list=PLK2BNwGTZOBerWfE2VEK-J5LthC8m6nH3
Legend Models 79.5" F8F Bearcat 30cc EG ARF
Model LMF8F
  • Material: Laser cut balsa and ply
  • Wingspan: 79.5" (2020 mm)
  • Length: 60.6" (1540mm)
  • Weight: 15.6 - 16. lbs (7.1 - 7.3Kg)
  • Radio: 8 channel, 9 standard servos
  • Engine: 30cc -40cc gas
Old 08-29-2016, 12:35 PM
  #93
JohnVH
My Feedback: (38)
JohnVH's Avatar
I dont see any way to lighten it up, that just has to be what it is. Not sure how the factory got their number. I didnt add hardly any tail weight.
Old 08-29-2016, 01:39 PM
  #94
Gmann6843
I dont see any way to lighten it up, that just has to be what it is. Not sure how the factory got their number. I didn't add hardly any tail weight.
More often than not I see that's what you get with planes from overseas. No worries just more forward and kept in mind that you need to kept the landing as smooth as you can until you find out just what the durability of everything ends up to be.As it is now I will undoutidly go with a DLE55RA with EME Autostart and maybe jump up to a next size retracts and a retact tailwheel .Here are the things I think I would order for this bird ...The sound card is a exstra but it is amazing to hear a P&W Double Wasp sound in the air in addition it has a machine gun and a clear prop auido track too............................................... .................................................. .................................................. .............................................
Name:	DLE-55RA REAR EXHAUST GAS ENGINE W EI & MUFFLER.jpg
ID:	2178836   Click image for larger version
Name:	DLE Engines Opto Gas Engine Kill Switch V2.0.jpg
ID:	2178837   Click image for larger version
Name:	EME 50-60 Class E-Starter.JPG
ID:	2178838   Click image for larger version
Name:	Fourtitude 16oz ARF V2 Fuel Tank w Mount.jpg
ID:	2178839   Click image for larger version
Name:	JTCDL55RP DLE 55 REAR EXHAUST PITTS STYLE.jpg
ID:	2178840   Click image for larger version
Name:	MORPOWER Scale Modeling Carbon Fiber Propellers A.jpg
ID:	2178841   Click image for larger version
Name:	RC aerodyne   Electric Retracts 60-120 size 90 Degree A.jpg
ID:	2178843   Click image for larger version
Name:	Turnigy All Metal Retractable Tailwheel Assembly for 2-2.5m Wingspan Warbirds.jpg
Name:	Turnigy dlux 10A Linear Voltage Regulator.jpg
ID:	2178845   Click image for larger version
Name:	MrRCSound ASPIRE RC Aircraft Sound System.jpg
ID:	2178900   Click image for larger version
ID:	2178901   Click image for larger version
Name:	MrRC Sound Bass Transducer.jpg
ID:	2178902   Click image for larger version
Name:	MrRC Sound TT-25 Sound Transducer.jpg
ID:	2178903   Click image for larger version
Name:	Turnigy Servoless Actuator for Gear Door for the choke DLE55RA.jpg
ID:	2178904   Click image for larger version
Name:	660DB GEAR DOOR MOUNT BRACKETS 440 SERIES.jpg
ID:	2179047   Click image for larger version
Name:	663L LH ROBOSTRUT 3- 3-4-4in WHEEL 7-16in.jpg
Name:	663L RH ROBOSTRUT 3- 3-4-4in WHEEL 7-16in.jpg
ID:	2179049   Click image for larger version
ID:	2179050   Click image for larger version
ID:	2179051   Click image for larger version
Name:	Servo Arm Half Arm 1 5-8 in Blue Color Turnigy.jpg
ID:	2179052   Click image for larger version
Name:	Servo Arm Half Arm 3-4in Blue Color Turnigy.jpg
ID:	2179053   Click image for larger version
Name:	TGY-777MG Turnigy Ply Servo Mount for Slim Wing Servo.jpg
ID:	2179054   Click image for larger version
Name:	Turnigy TGY-778MG Slim Wing DS-MG Servo 5.5kg -0.10sec - 23g Geardoor.jpg
ID:	2179055   Click image for larger version
Name:	Turnigy TGY-5521 MDHV HV-DS-MG Servo 24 kg - 0.11sec - 60g Ruder Elevator.jpg
Name:	Turnigy TGY-A55H Slim Wing Alloy Case DS-MG Servo 8.6kg -0.12sec -28g aileron and flap.jpg
Old 08-29-2016, 08:52 PM
  #95
baronbrian
My Feedback: (13)
baronbrian's Avatar
I don't see a wing area listed, but based on the wingspan, if the wing shape is fairly close to scale the wing should yield close to 1260 sq."
Wing loading at 20# would be 36.6 oz/sq' , Cubic loading at 20# would be about 13. With those flaps, landings should be uneventful.
Interested to see how much ballast your model with the 35ra requires, if it is at least 20oz, the 55ra would not increase AUW of the plane.
Old 08-29-2016, 08:59 PM
  #96
Gmann6843
Here is a link to JB Hobbies looks like for you it's $60.00 shipping https://www.jb-hobbies.com/presta/wa...cc-eg-arf.html
Old 08-29-2016, 09:33 PM
  #97
JohnVH
My Feedback: (38)
JohnVH's Avatar
Rtf weight minus fuel is just over 20lbs,
Old 08-29-2016, 10:48 PM
  #98
Gmann6843
Do you have any pic's of her yet?
Old 08-30-2016, 05:33 AM
  #99
JohnVH
My Feedback: (38)
JohnVH's Avatar
Throws, rates and servos are set, my gear door sequencer isnt listening to me, but Ill try some other methods to make them work.. But the bear is balanced, and the DLE35RA runs like a watch! Now I have to suffer through another day of work before I can play with it again.
ID:	2178913   Click image for larger version
Old 08-30-2016, 06:16 AM
  #100
Lifer
Lifer's Avatar
I predict that you will have a very successful test flight. WW 2 radial fighters have been some of the best flying models I have flown. Please keep us posted!
