TopRCModel FW-190
Old 01-01-2019, 07:08 AM
  #301
Hello,
I am building the TopRCmodel FW-190 and here is some pictures reg installing the Satio FG90R3 radial gas engine with Keleo exhaust.
I just marked up the drill holes.
Used 4,5 cm standoff (blue) for a start since it is close fit.
Cutout for the carb/gas lever.
Cut approx 14 cm long under the cowling for sliding in exhaust area. (Later finish work)
I might reduce the standoff with 1 cm then the cowling is flush with engine spinner plate.
A very nice fit without any major modification for engine install.
Old 01-01-2019, 08:04 AM
  #302
Is there any thrust offset built into the plane?
I am using three views that show color schemes and wonder if the full size has any thrust offset, my drawings don't show one way or the other.
Sparky
Old 01-01-2019, 08:14 AM
  #303
Old 01-01-2019, 05:29 PM
  #304
Please excuse my ignorance but I do not know how to send a PM. I would like to purchase a fan unit from the Reverend and do not know how. Could someone help?
many thanks.
john
Old 01-01-2019, 08:29 PM
  #305
John,
go up a few posts to one of reverands posts and click on his name in the left box and it will show a drop down menu of things in there and one will be send a PM. Click on it and another screen will open and you send him the PM.
Sparky
Old 01-02-2019, 03:43 AM
  #306
Reverend's Avatar
many thanks.
john
John,
just drop me a mail at pa(at)chello.at and we will sort it out.
Rgds
Rev
Old 01-02-2019, 06:13 AM
  #307
Default PM sent to Rev
thanks for the instructions on how to send a PM. I think I got it right. Reverend please check.
Old 01-02-2019, 03:31 PM
  #308
Chris Nicastro's Avatar
@ Totto,
just for your reference, I flew a Hanger 9 Corsair with the Saito FG84 and a 3 blade scale looking prop like you have there on your build. I just wanted to say the engine was not loaded properly and it flew poorly as a result. The top end RPM was high and the plane flew slowly because the pitch was too low. Landing the plane required a high throttle setting, etc..
I’m just saying check the engine is pulling hard like a 24x12 prop would do. I’ve tested the FG90 with a 24x12x2 blade on the ground and the RPM was right on target.
Old 01-02-2019, 10:20 PM
  #309
Originally Posted by Chris Nicastro
@ Totto,
Iím just saying check the engine is pulling hard like a 24x12 prop would do. Iíve tested the FG90 with a 24x12x2 blade on the ground and the RPM was right on target.
I have a TopRC Zero with the 22X12 FW prop on it. 90 RG engine and it flies great! Fast enough for me and pulls hard through a big loop.
Old 01-03-2019, 06:32 PM
  #310
Rev,
email sent i hope hope you got it
Old 01-04-2019, 10:49 AM
  #311
Thank you Chris Nicastro and LtMash1A for your info !
Old 01-07-2019, 01:26 PM
  #312
Reverend's Avatar
So a quick question... I have been fooling around with an Idea and it seems to work very well.
Just curious, is there any requirement for some FW-190 wheels? They are ball raced (for a 1/4in axle), 5,3in in diameter and weigh 6,9oz. Theres still some detail cleaning to do to remove some printing flush (like with plastic model kits).
I can enlarge them to some extent if needed.
I also have an idea on how to get the rear to look a bit nicer but apart from that they are ready to go...
Rev
Old 01-11-2019, 08:22 AM
  #313
Hi all,
I have bought the Sierra retracts as I am not satisfied with the standard TopRc gear.
Can anyone of you, who have already installed it, please tell me, how thick plywood you have put under the retract-flanches/mounts (or what you call them)? It seems they have to be raised a bit?
Old 01-11-2019, 08:35 AM
  #314
Originally Posted by maddog-RCU
Wingspar, can you post a picture with the Sierra mains installed in the wings?
Think I found it
Old 01-11-2019, 12:30 PM
  #315
Originally Posted by Kh@n
Hi all,
Hello,
This is what i did and seems to be ok on my Sierra gear FW190
Wing front: Insert raised to 6 mm (original 10 mm so total 16 mm)
Wing back: Insert raised to 3 mm (orginal 10 mm so total 13 mm)
I cut off also about 5 mm in to get the big scale wheels better position in the wheel rest.
Old 01-11-2019, 01:18 PM
  #316
Thank you very much Totto, exactly what I needed!!
Old 01-11-2019, 05:58 PM
  #317
My Feedback: (8)
you guys lost me on those shim measurements...I need shims for dummies
Old 01-12-2019, 06:35 AM
  #318
Hello,
For the retract cover i have done it this way:
Changed out the original screws with longer 3 cm length. (4 pcs)
Insert nuts inside/outside.
Then adjusted accordingly for best fit.
Took off the top fastening so there is no conflict with the legs. Not needed.
The cover will not come in conflict with the spring as it is free from the movement.
I might cut the cover in bottom area since i think its rather long, but will see.
Old 01-12-2019, 08:35 AM
  #319
Totto,
take a look at countersink flat head srcrews and install them on the doors for a flush surface finish. Then assemble the last locknut on the strut.
The full scale doors had a tape cover over the nut as seen in the photo below
Old 01-12-2019, 08:38 AM
  #320
Default Door detail
Old 01-12-2019, 09:34 AM
  #321
Totto,
Hi Chris,
Nice job !
It was the plan to use flat head, but i don't have those at the moment since this is "American" treads, and we use M3 M4 measurements etc. Will be done better at a later stage :-)
Old 01-14-2019, 11:44 AM
  #322
Oh no! That is a photo of the real plane! not my work!
Old 01-16-2019, 07:11 PM
  #323
Just a suggestion...with about 20 flights on my winter 190 I would suggest a single layer of 1/2 ounce fiberglass on the inside of the gear doors and a second horizontal strip across the bolt holes. the hollow nature of the doors will fatigue in heavy grass like one of the fields I fly at. The fiberglass added all the strength I needed. Both of my gear doors started to fatigue around the bolt holes due to the heavy grass. I've had no problems flying off of paved runways. Check out grass in post # 229.
Old 01-17-2019, 05:41 AM
  #324
Hi everybody
In order to make a few finishing touches, do you know the colors of heller or humbrol (code or name) corresponding to the color scheme ?
Especially de light blue
Old 01-17-2019, 06:02 AM
  #325
Here is a link for paint made the right colors for the FW190
https://warbirdcolors.com
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
