TopRCModel FW-190
Old 04-05-2019, 07:13 AM
  #376
scottme262
That's not my dog
Old 04-05-2019, 02:07 PM
  #377
Chris Nicastro
Chris Nicastro's Avatar
Originally Posted by scottme262
Lt. Thank you for the specs. That is exciting that it fly's fast with that prop. Initially I was looking at the 28 diameter prop since that's closer to a scale size for its wingspan, but sounds like a 28 is way too big for the engines that fit. :-)
I have a lot of IMAC guys that fly at our new club so I'm starting to talk to them. Only one other guy does big Warbirds but he is only there once every few months. I do have a Jet guru that is there every time im there so i have been picking his brain as well.
Elmshoot, the Power Safe RX is what has been recommended and its nice to see you are doing the same thing. good to hear about total weight being workable. thanks for the input.
Scott
(Nicknamed "Inspector Clouseau" back in 84' because I asked too many questions)
Careful with the advice and help you get from IMAC pilots because they are trained to fly high performance sport RC planes that do not fly like warbirds. They may be technically proficient pilots but just as in full scale you should be cross trained or "rated" on big RC warbirds. I have seen this many times where a great IMAC pilot cannot handle a warbird well and in some cases have crashed the model. I have also seen this in my own flying skill set because I flew a hot rod Ultimate pipe for a couple seasons and noticed it was effecting how I flew my warbirds. I sold the bipe just to stay true to my war bird interests. If you trust a pilot who flies a variety of plane types well and you have seen him handle a war bird like yours then I would trust the pilot enough to fly and advise me on the plane.
Just my experience and advice...
Old 04-05-2019, 06:49 PM
  #378
elmshoot
Also the IMAC guys set up the control linkages for their planes much differently than the more conventional setup that is desired on a warbird. 3D isnt what you are looking for.
Sparky
Old 04-05-2019, 07:03 PM
  #379
scottme262
That is great to know.
We do have a lot of IMAC guys,
The jet guy is pretty proficient with everything, does inverted 100mph flybys 15' off the deck with his Violet F16 at our airfield (old paved ranch airfield). I will be having him do the maiden and checkout. He has saved a few of my foamies that were un-flyable until he got them onto the ground and made adjustments. I will trust his judgement and I really appreciate your advise guys
Old 04-05-2019, 07:04 PM
  #380
scottme262
Sparky
I was planning on setting everything up based on what i am reading from you guys.
Scott
Old 04-07-2019, 01:58 PM
  #381
HiCurrent
I have questions for those who have the saito fg90.
I have not maiden mine yet. Still trying to adjust the engine. I just ran almost a gallon of fuel to break it in. I have a 40oz fuel tank and it seems like it doesn't last very long. I have not ran the engine at full throttle for too long because I'm still trying monitor the engine temperature in the cowl.
My question is:
1. what size of fuel tank you have and how long is your flight time.
2. what temperature do you get with the cowl on and do you have baffle.
3. what size of ignition battery are you using and how many flights do you get with it.
4. what size of prop do you use and what rpm are you getting out it it.
I have 3 blades 22x10 fw190 scale prop and it seems like it is over-prop. I could only get about 4500rpm and the engine is a bit overheating (200 F).
A 2 blades 24x10 mejzlik turns at 6500rpm at about 185F
#1. I found out the reason for the fast drainage of fuel. I have a Tee on the fuel line and I didn't take it out during the engine test. I thought that the electric fuel pump would prevent the fuel from cyphoning back into the tank but I was so wrong. After I realized that, my problem #1 was solved.
#2. I'm seeing 192 F with the 24x10 2 blades mejzlik. I have baffle but I didn't do it right. I put the baffle in front of the engine and not in the middle of the engine. I will have to cut the baffle out and redo it.
#3. I was using the 2s life battery and it wasn't good enough. The engine was running horrible. One cylinder got overheated (up to 250F) and the other 2 stayed cool at 100F. At low end, it sounded like only 1 cylinder was running. I checked the manual for the ignition battery range then tried it with the lipo 3s. It made the huge difference. The engine came alive.
Please, I still need the information on the rpm and temperature. Please share if you have it. Thanks
Old 04-10-2019, 11:09 AM
  #382
AV8ATOR
AV8ATOR's Avatar
Anyone have experience with this 22-12 Three Blade Semi-Scale Fokke Wulf Style propellor made by "Biela Propellors". Supposed to work well with Saito FG90R or any engine in this size range.
Old 04-10-2019, 05:57 PM
  #383
LtMash1A
Attachment 2263967
I use it on my Zero and FW190, 84 and 90RG. Works great.
Old 04-10-2019, 10:28 PM
  #384
michael16tsx
Hi guys,
I am going to buy this plane in the near future, and would like to go fly it with the saito FG 90.
As i read this thread, this plane looks really good.
But there seems to be a big problem with the gear!
the only solution i see is to buy a sierra gear, but im not a big fan of air retracts.
Is there anyone who is flying this plane with electro rectracts, like the electron ?
Greetings,
Michael
Old 04-11-2019, 05:35 AM
  #385
elmshoot
Down and Locked makes awesome gear, his are electric he has had a booth at Toledo. But not this year along with a bunch of other MFG skipping the big show.
Tell him Sparky sent you from RCSB
The workmanship on the struts is on par with Sierra.
If I didn't already have a set of Sierra gear I would get mine from him.
I will be buying a set from him in the next 90 days for a 80" Sea Hornet.
Sparky
Old 04-11-2019, 07:25 AM
  #386
AV8ATOR
AV8ATOR's Avatar
Thank you for the response LtMash1A.
Old 04-11-2019, 08:16 AM
  #387
ZB
Has anybody used the Robart gear for this model? Struts looks strong but air-cylinders seems to me small.
Sorry no idea about needs for this size of the gear.
Old 04-11-2019, 09:51 AM
  #388
LtMash1A
Using the Robart gear for this plane will be your worst nightmare.
Old 04-11-2019, 07:40 PM
  #389
HiCurrent
Stay away from Robart. I rather fly the plane without any gears and belly land it.It'll take less damage
Old 04-12-2019, 02:01 AM
  #390
michael16tsx
Thanks for the answers!
I think i got the solutions:
I heard that in May TopRc will release an electronic gear set for this plane.
As i know, it will be a Robart set.
So i will order from Robart: legs and wheels
Retracts wil be Electron er50evo
That should work great!
Hope to get the plane early june. Does anyone have any tips about the FG-90R3 ?
Does it REALLY still needs an upgrade ?
Old 04-12-2019, 08:23 AM
  #391
scottme262
I would urge you take some time and read the horror stories of anything related to Robart in the TOPRC FW190. the legs and support structure are the problem not the air cylinders, so bolting them to electric actuators wont solve the problem of their design.
Old 04-12-2019, 10:39 AM
  #392
LtMash1A
I agree,.. Scott., There is no cheap way around your problem. Sierra Gear and live with air, or Sierra Gear and send to Mitch at Down and Locked for conversion to electric. I would add that the TopRC tail wheel will work fine but you have to cut the tabs off and make the pull pull wires come out about a half inch above the the mounting bracket. The exit holes that come with the kit will not work as they will stretch the wires when the tail wheel cycles.The exit holes are too low. Springs will not solve this problem from my experience. If you use the Sierra tail wheel, in my opinion the 1/4.5 are a little too big. I prefer the Vally, Sist 1/5 th size, but that is a matter of opinion. The struts on a 190 are long and you need a healthy gear to stand up to the stress. Im sure some of the better pilots on the forum could make any gear work, but I'm not that good. So just trying to keep you form throwing good money after bad.
Old 04-12-2019, 05:16 PM
  #393
ZB
OK, looks like plane B, Monday calling Sierra Gear, my gear does not operate smoothly, the trunnions get stuck in up position.
Over the weekend I will install servos and start working on electric motor. New Elite E105/20 motor with telemetry is going to this machine.
E105/20-185 w/Jeti Spin Pro 200
10,000 12S Li-poly
3-Blade 23x12 Fiala prop
6200W/140A/7250
Old 04-12-2019, 07:03 PM
  #394
LtMash1A
Looking forward to seeing the set up. Since all electric fly ins are becoming more and more popular, fI did the TopRC Spitfire in electric and really love it.
Old 04-12-2019, 07:44 PM
  #395
HiCurrent
You can't go wrong with Sierra. It will be worth the money. If you can get a fix tail gear, I think you'll be happier. Less nose weight, less trouble installing the retractable tail gear and less money.
I couldn't find a fix tail gear for it; otherwise, I would use it instead.
Old 04-13-2019, 07:46 PM
  #396
HiCurrent
For those of you having the Saito FG90. Do you guys baffling the engine ? what is your running temperature ?
thanks
Old 04-14-2019, 05:03 AM
  #397
flypilot
flypilot's Avatar
Here is the video, hope you like it, subscribe to stay updated on new videos from my channel..thanks
Old 04-14-2019, 09:39 AM
  #398
LtMash1A
Great job! Thanks for posting.
Old 04-14-2019, 11:54 AM
  #399
flypilot
flypilot's Avatar
Thanks, im sorry I posted in the wrong thread
Old 04-14-2019, 10:32 PM
  #400
michael16tsx
Thanks for the feedback about Robart! i will let it go
The point of a fixed tail gear sounds good to me, i'm going to find something out to get that done
Is there anyone who has a video of their FW-190 flying with a FG-90R3 ?
I read a lot about it, but can't find a good video so i can see how it flies with this engine.
