Reload this Page >
FiberClassics P-51 now Comp-ARF P-51
Old 10-13-2015, 02:08 PM
  #2276
chisep51
Thanks Dave
You got it, I have one other person in line first. Should have a fully working set in a couple weeks, all you would have to do is glue canopy to the carbon frame and mount the rails. I have finally completed the CAM program to produce them. Will keep you posted.
Charlie
Old 10-13-2015, 08:27 PM
  #2277
LtMash1A
Looking forward to hearing from you, Thanks
Old 10-16-2015, 07:11 PM
  #2278
LtMash1A
Really nice. What paint did you use for the metal? Sorry, I don't know why this ends up here. I was replying to an earlier post.
Old 10-16-2015, 07:14 PM
  #2279
LtMash1A
Nice, what paint for the metal part? Can't delete it.
Old 10-16-2015, 07:38 PM
  #2280
LtMash1A
Originally Posted by DrScoles
Got a tracking number this morning! yes, the 135 with 270 degree timing. keleo scale exhaust. Hans makes a baffle kit specifically for the carf. Electric start as well. I'll be honest, I am a corsair and FW 190 fan, never really been into mustangs, but after seeing video of the Kolm, I had to have one. Greg Wright happened to be selling his right about that time, so it worked out. As soon as I get the motor and mounting kit, I should make good progress. I have the taylor made decals for this plane, and it will be painted with liquid metal… I will post pics of the motor as soon as it arrives! Its not going to be super scale, just a cool sounding plane with a nice paint job...
Where is the liquid metal paint abailable? Thanks, David
Old 10-25-2015, 07:36 AM
  #2281
luckymacy
Lucky, give me a few weeks and I will dump all these photos at once and they will answer 90% of your questions!
Hi Mike, did you ever dump the photos? I'm still very curious where/how you mounted your main batteries and the 3 pounds of tail weight, etc.
Are you going to make a winter project to bring the mustang back to life? You just can't leave that Kolm engine unemployed!
Old 10-25-2015, 08:03 AM
  #2282
luckymacy
I'm pretty sure a high end car paint shop could hook you up.
http://www.tcpglobal.com/PPGVM4201-PT.html#.Viz9K2eFOoAhttps://www.youtube.com/watch?v=mXgcww5J4LU
https://www.google.com/search?q=liqu...MRVxUo-04aM%3A
Old 10-25-2015, 09:14 PM
  #2283
LtMash1A
Thanks, I had talked with Dr. Scoles about it and you would really need a paint booth and equipment to paint urethane . One person painted with Latex, metallic silver and I was wondering about the feasibility of using latex. I have done a lot of models using it with good results, but they were all built up components that were fiberglassed. Not a lot flex. I can paint in my garage using latex in any kind of weather. Klass Kote, I have to paint outside, so weather and drying times are a concern. Its great paint though.
Old 10-27-2015, 10:51 AM
  #2284
luckymacy
This info below was posted literally just over 6 years ago in a prior post. It'd be awesome if builders could chime in with updates to it.
Pilots
www.axels-scale-pilots.de
http://www.aero-accessories.com/
[email protected]
http://www.perfectpilots.com
Cockpit
www.scale-specials.de
http://www.noll-modelltechnik.de/cockpits_warbirds.htm
http://004edc4.netsolhost.com/BAcock...pitorders.html
http://www.dbalsa.com/cockpits/p51.htm
http://www.aerocockpit.com/complete-cockpit-kits
http://www.propagteam.cz/home_en.asp
http://www.kmp.ca/product_info.php?c...53e3304116d55f
http://www.hobby-lobby.com/1_4_scale...QueryId=221219
Graphics
http://www.kirbysgraphics.com/
Water slide/Pressure transfer decals
http://www.mcgpaper.com/decals.html
Engine
Dessert Aircraft
http://www.chiefaircraft.com/rcmsec/...raft.html#da85
Mufflers MTW TD110
http://www.mvvs.nl/MTW/Mufflers.htm
http://www.carf-models.com/public_ca...=16&linkId=@16
Engine fittings
http://www.krumscheid-metallwaren.de...op.php?lang=EN
Darrel @ Sierra 440-476-4885
[email protected]
Sierra do make extensions and standoffs
Retracts
WABO retracts from Germany
[email protected]
http://www.wabofahrwerke.de
Sierra
http://www.sierragiant.com/products.html
Main wheel tires 6"
Tail wheel tire 3"
http://www.igmustang.ch Paul Haller from switzerland
Spinner 6 1/4"
Scale Prop
http://www.aerotechmodels.com/Static%20Propellers.htm
SoloProp 4 Blade
http://www.soloprops.com/Default.htm
18 / 11-14
20 / 8-11
22 / 7-10
Control Valves
Ultra Precission UP2 Retract Valve with Automatic Door Control "doors closed when down"
UP4 Secondary Control Valve
http://electrodynam.com/rc/up/index.shtml
Gas Tank
Dubro 32 oz. tank
Servos
Elevator + Ailerons 100/130oz
Flaps 130/170oz
Rudder 130/170oz
Strobe light
http://homepage.ntlworld.com/vogonaj Paul
Reduction Gear
Joe
http://warbirdpropdrives.com/30601.html
[email protected]
Mike Reeves
http://www.mickreevesmodels.co.uk/~m...ccessories.htm
Flashlight
http://www.brinkmann.net/Shop/Detail...=L.E.D.&id=134
Real Metal
Aluclad
http://www.flairmodels.co.uk/Finishing/Aluclad.htm
http://www.flairmodels.co.uk/Dealers...portframes.htm
Flite-Metal
http://flitemetal.com
MetalCoat
Other Links
http://www.fc-scaleparts.de/mustang.html
http://www.aero-accessories.com/Builders.html
http://www.pacific-scaled-aircraft.com
Old 10-30-2015, 12:13 PM
  #2285
peter w h
peter w h's Avatar
Not sure who took this one.
Name:	Mustang in Kitchener.jpg
Old 10-30-2015, 07:18 PM
  #2286
Rick F
Aerotech models is no longer selling planes. They closed there doors in 2008. If you are in need of props scale specialties web site sells prop blade kits for Aerotech planes & others.
Rick Frane
Old 11-14-2015, 09:01 PM
  #2287
BoomerSooner
My Feedback: (80)
Any one received a kit lately? How's the quality? Considering building one of these
Old 11-14-2015, 09:58 PM
  #2288
LtMash1A
Yes, I have. I think the kit is night and day way better than the earlier ones I have read about on this thread. If you check the website you can see that all the new hinges preinstalled. Also there are no seams or join lines to repair. Everything straight. I would have loved to see them take it a step further and pre-installed all the hatches and servo mounts and done all the cut outs for it. At any rate I was very happy with it. And, Andy Kane my CARF rep. was very helpful with my questions and supplying parts to make the build easier when I get started this winter. Hope this helps. Dave
Old 11-14-2015, 10:59 PM
  #2289
Chris Nicastro
Chris Nicastro's Avatar
Plus 1, nice new light parts and clean seams
Old 11-17-2015, 08:54 AM
  #2290
BoomerSooner
My Feedback: (80)
If one of y'all with a newer airframe have pics that would be great. Curious to see how they got by not having the seam to finish. Unless they are finishing them at the factory. My ultra flash had the seam cleaned up and painted from the factory. How's the fit of the wings and stabs on the new ones?
Old 11-17-2015, 09:23 AM
  #2291
Greg Wright
Greg Wright's Avatar
Loads of pics from one i had 2 yrs ago. The seam is still in the fuselage as always but the parts fit is much better than the Fiberclassics one. The detail of the wrinkles in the skin was removed in the new mold so it took a lot of the character away from the plane.
ID:	2131077   Click image for larger version
ID:	2131078   Click image for larger version
ID:	2131079   Click image for larger version
ID:	2131080   Click image for larger version
ID:	2131081   Click image for larger version
ID:	2131082   Click image for larger version
ID:	2131083   Click image for larger version
ID:	2131085   Click image for larger version
ID:	2131086   Click image for larger version
Old 11-17-2015, 01:41 PM
  #2292
Chris Nicastro
Hey Greg did you go with the suggested mini servos on the stabs or what did you use?
Old 11-17-2015, 05:07 PM
  #2293
Greg Wright
Chris,
I don't remember what i used. I sold the plane to Dr Scoles a year or so ago.
I want to say i put some Spektrum 6150 HV's in the stabs. They were rated at 180oz of torque at 7.4 volts. If not then they were the 5060's rated at 118oz at 7.4 volt.
I would think that the latter would be plenty of torque for each elevator.
Old 11-17-2015, 09:43 PM
  #2294
Chris Nicastro
Ok thanks.
I read the manual and just couldn't believe they suggest such small 75 oz servos. Plus we're installing a Kolm 150 so it's got to be tough.
Old 11-18-2015, 04:50 AM
  #2295
Greg Wright
Chris,
The engine isn't the problem it's usually the guy at the controls. I would think the 75oz torque servos would be just fine.
Old 11-18-2015, 09:41 AM
  #2296
LtMash1A
Hope this is not a double post. But, recommendations from the CARF rep. Ailerons and flaps: Spektrum 6270 or JR 8911. For elevators: JR 3421.
Old 11-18-2015, 01:22 PM
  #2297
Chris Nicastro
The guys flying these big CARF models with Kolm 135 & 150 & and the 200 have been using 300-500oz servos Im told. The question Ive had is how they solved the elevator installation issue because these servos are wider than the stab chord thickness.
On our Mustang we are considering epoxying the stabs on the fuse because we have no need to remove them for travel. So an access hatch on the bottom and a single or dual servos is the basic plan right now. Similar to the other werbirds from CARF currently.
I'll probably end up designing something
Old 11-18-2015, 01:59 PM
  #2298
Hello82
Hi
I hid both the elevator and rudder within fuse...tons of room....both servos accessed through tail wheel door and one hatch cover
and also just glued on stab for good
M
Name:	Miss Ethel tail inners.jpg
Old 11-18-2015, 02:26 PM
  #2299
Greg Wright
Chris,
I just did a test with my FibreClassics mustang and it looks as if a JR 8911HV would just fit into the stab if it was done with a hatch to access the servo. Just like i did in the pictures above. They are a standard size servo with like 500oz of torque at 7.4 volts. I still don't think it's really needed though.
If you were going to pylon race the plane with the kolm engines then i could see it being needed but i don't think thats what you will be doing.
Old 11-18-2015, 03:52 PM
  #2300
Chris Nicastro
Thanks M
No not racing it but mainly having the built in margin of safety because this plane will live on a grass field. I want tough servo transmissions on the larger control surfaces for extra strength and longevity.
Chief is gaving a servo sale on Hitec servos so we ordered the HS 7980 and 7950 servos for the wings. The higher torque servo for the flaps.
I did use one of the online servo calcs and for the flap area at 60-80 mph for example it spit out a 400 ounce estimate.
