FiberClassics P-51 now Comp-ARF P-51
#2251
yeah, pretty much all do it yourself scale stuff is a PIA if you aren't on a retiree's schedule (LOL) so I've avoided it since my last serious scale mustang build 25 years ago! I'm leery of just winging it on this plane because of what it's made out of and I don't want to frack it up by making stupid cuts here an there I'll regret later. So, where/how did you mount the fuel tank around all the other things piled in there? And how did your final battery install go? As to your earlier question, if you have to add tail weight and to help eliminate flutter, a place to do it that's value added is to the elevator's counterbalance area, just like we do on real planes like my Van's RV-8 I built. Gotz is doing the same static elevator balancing to his CARF Spitfire that's getting the same Kolm engine, BTW.
#2252
My Feedback: (18)
No, thats for the power to the plane. The electric starter adds quite a bit of complexity to the whole thing. You need an ESC, then a 3s lipo, and I purchased a high voltage electronic switch for $90 that will turn it on/off separately. It will stay on during flight, be nice to restart if it happens to die :-)
I used an emcotec magnetic switch and hid it in the scoop under the wing. I bought another magnetic switch, but it was the wrong one and I am getting impatient.
#2254
#2255
Question to anyone who has flow there mustang. I feel like there is too much slop in the elevator. I thought it was the linkage, but I think its the rod that runs through with the phenolic hinge holes being a little large?? We already have a problem with fitting a full size servo on each side, leary of flutter and overpowering the servos. Anyone else concerned? Have a fix?
Craig B. - AA++ on the hinge repair technique.
Latest pic. ready maiden.
Doc. - I am in Toronto, I will meet you in the middle and we'll maiden together.
P.
P.
#2257
My Feedback: (18)
Craig, I tried thin CA into the holes and kicker, but didn't think to put the rod back in. I will try it. I'm used to the hinges on our jets, zero slop. Thanks!
Peter, I might maiden this weekend. A few stars have to align, but I'm going to a fly-in that has an amazing field, just need to find the time this week to fine tune and add some weight in the tail.
#2258
Hi Mike,
Yeah must use green zap with the hinge pin in place. This job takes all of 5 mins and makes a world of difference. Just make sure not to have excess oil on hinge pin...just a very thin smear and make sure there is no rust on the hinge pin. I usually go over it with some 1200 grit first to get it nice an shiny.
#2260
Rick- Yes it is a Hyde mount, cancels out most of the vibration, only down side is the engine moves and shakes.
Extra clearance around the muffler is still needed.
Found these two pictures on the Flying Giants site.
#2263
I'm trying to find the tail wheel door hinges as well as some other hardware and I'm convinced I didn't get the right hardware for this kit and enough hardware. This is the extent of my hardware that came with the kit minus one set of pull pull cable/links. The one for the rudder is missing. Did everyone else get two sets of pull pull? One for tail when steering and the second for the rudder?
I'm curios what others got in recent kits. Anyone know what the dark phenolic material is for? My manual does not show that nor did I see versions of that in this thread. If it is what they are putting in for hinges these days it'd be nice if they put in some instructions...
Three rubber bands?
There's a lot of threaded clevises and nuts but no push rods. Anyone else get pushrods? There's also those two brass covered, spring loaded canopy type latches in the picture. Again I don't see any reference to them in the manual and in this thread. Everyone else get these? What did you use them for?
If anyone has a source for more conventional tail wheel door hinges or detailed pictures on how to make these things in the picture work, if indeed that's what the are, I'd like to see them!
thx,
lucky
Three rubber bands?
thx,
lucky
#2264
Hi Lucky,
You can find miniature door hinges on these sites...
http://www.meister-scale.com/Accesso.../LVhinges.html
http://www.micromark.com/miniature-b...-in,11074.html
http://www.phoenixmodeldevelopments....nge_Range.html
http://www.mackproductsrc.com/7127_piano_hinge.htm
Cheers,
Roger
Cheers,
Roger
#2265
Thanks Roger,
It's this kind that are similar to the instruction manual I was looking for.
http://www.sonictronics.com/xcart/home.php?cat=321
and here's another source of the micro piano hinge http://www.nelsonhobby.com/miniature_piano_hinges.php
Hi Lucky,
Cheers,
Roger
Cheers,
Roger
#2268
Question for those who went the pull pull method actually shown in the manual and put a season or so of flights on the plane. Is the pull pull method holding up and how much rudder deflection can you get on 'high rates'? I ask as my gut tells me to make a direct link connection similar to what one guy did in the picture below to get all the throw I think I'll want for a good hammerhead, better rudder authority for long knife edge pass and just overall a more reliable long term design. Then again, maybe the pull pull as they show in the manual is good enough for what I want...
#2269
MA
Hi...yeah that's my bird...... I put 2 servos in tail, one for direct rudder and one for sierra retract. I built a shelf in the front of the removable cowl and put one battery there and all balanced well with no extra lead. I have done pull pull on my ziroli mustang, but I went with my gut too...this just seemed easier and works well, and is totally hidden.
https://www.youtube.com/watch?v=f-5AWJiNu6M
#2271
Hi guys, it's been a long time since I posted .............. I had the maiden flight on my P51 a couple of weeks ago.
The model depicts P-51D-10 44-14660 'LITTLE DUCKFOOT' of Lt Gerald Tyler 364th fighter squadron.
There is a video of the maiden flight here https://www.youtube.com/watch?v=fnuGkpvidAY
The gear wasn't raised this flight to check the air system for leaks, upon landing everything air wise was fine, it will 'go up' next time !
She flew like she was on rails ........... even on full flap, going slowly for landing ............... unfortunately, a broken steering cable on the tailwheel prevented another flight. All fixed up now and ready to go again.
#2272
#2274
LtMash1A,
I made the canopy rails and am on the downside of finishing a CNC set, consisting of Canopy frame, 3 canopy trucks/with rails which are modeled after the full size. Will post new pics when completed.
Sorry I didn't get back with you sooner, thread has been dead and I just visited it.
Charlie
Charlie
