Will it work?
My Feedback: (7)
FL
I got a question on building my p40.I want this to be as scale as possible I want to know if Ill have any problems if I make the fuel line kind of behind the cockpit will I have problems with bubles in my fuel line?because of the lenth of the line?
GA
Why have the fuel line way back there ?
You can hide the fill connection in the bottom of the cowl or in the bottom of the fuse and avoid the whole issue of line length.
And yes, you may have fuel starvation problems with a too-long fuel line, even if you use muffler pressure.
OK why not just use a fueler only to fill the tank from there but use a direct feed line from the tank?
that way you can fuel from the scale location but still not have leaning problems. simply plug the line that would lead from the fueler to the engine. use it as a 3rd line
Consider that your fuel tubing is not scale, for starters. You will have a large, round, clear, tube running through the cockpit. If you are using a Gas engine it will draw fuel a long ways with out much problems. The Gas engine carburator has a built in fuel pump.
You can have the fuel filler cap where it is on the full scale and still fuel your plane another way. One way is to hide the fill line inside an exaust stack that you can retrieve with a pair of hemostats or needle nose pliers. Just a few things to think about.. good luck.
