cmp p47 thunderbolt
#51
NJ
RE: cmp p47 thunderbolt
With a .91fx. it certainly moves..I usually fly at 1/2 to 3/4 throttle. I love it! This plane is also very stable in the wind. Total weight came out to 7.5lbs. This plane is very tail heavy. The 91 balanced it out nicely!
#53
It is fairly easy to install mechanical retract in the precut position, the problem is that this position puts the wheels to close to the center of gravity. I have not flown the plane that much and I've destroyed 5 props by nosing over on landings. A prop everytime you land get very expensive.
#54
NJ
I have Hobbico retracts in the P47. Yes nosing over is a problem on landing. I use 100% throw in elevator with 50% expo. What I do is before touch down is to kill the engine and ease up on the elevator.
I just clocked my P47 with a O.S .91 Fx running a 14/6 prop...this plane moves at 83mph...I think I can get to over 90mph with a 13/8 prop.
Thanks Benny for clocking the plane. Big shout to John and Joe who stood by..in case I need to put the plane in a DOA bag..
#55
I am in the process of building this plane for a customer. What model # are the retracts.
I am going to install a Saito 72. Maybe an inverted pitts so I can mount the engine upside down and not have to cut the cowl. I installed a 150 with an inverted pitts on the CMP Hellcat and it worked great. We'll see........
If you are interested you can check out some of the warbirds I have built. www.zaprcproducts.com
James
James
#57
Great thanks. This is a really nice plane. It is screaming for detail. Here are some current photos and some progress soon to come. [link=http://www.houstonrc.com/forum/viewtopic.php?t=133&sid=4b7c0181c6dcc1171afd1e06b0996b41]P-47 Pics on HoustonRC[/link]
#58
I have done some more work on the P-47. I am really lovin' this plane.
More pics here [link=http://www.houstonrc.com/forum/viewtopic.php?p=765&sid=a9e503a0e5d6b27aff553a70f37baeda#765]P-47 Thunderbolt[/link]
#59
I shimmed the retracts forward to put the wheels just in front of the leading edge. They come up and down fine, the tires are at a slight angle in the pockets. While in flight it is very hard to notice that though. I didnt get any more nose overs after that. This idea was suggested to me by a Rep for Robarts at warbirds over Indiana last year. I used Hobbico mechanical retracts with a Hitec servo, worked just fine.
#61
Here is some more progress on my P-47 build. I found a flex pipe by Saito and routed it on the botom. No more big ugly muffler sticking out. I also got the cowl all cut and fitted.
More pics [link=http://www.houstonrc.com/forum/viewtopic.php?t=133&sid=6b581c44e8661aa27a9585773362ab1b]HERE[/link]
#62
Zap, the bigger the diameter of the prop the better your plane will fly. I would go with a two blade prop if it will clear the ground. My tower .46 would pull my aerobatic planes at probably 60-70mph, with the big radial cowl on this plane I was lucky to get 40mph.
#63
Makes sense. You gotta get the prop over the cowl. That prop I am using is a 14X7 three blade, though is is in the specs for the Saito 72, I think it will be to big. I really want to use a three blade on this plane. I will see how many RPMs I get with the 14X7 3 blade before she flys.
#64
Some more progress !!!! Almost done. Just have the receiver to install. (and make it all work) She ballances out at the recommended 90mm with a weighted prop nut and the battery mounted under the fuel tank. I am very cautious about the recommend CG, though. I will add a few ounces in the nose along with the receiver to get 85mm and she will fly. More pics can be found [link=http://168.144.201.183/airplanes_we_have_built_pg4.htm]HERE[/link]
The first pic is before DETAIL !
#66
Not yet....I am still ballancing everything. Once it is ballanced then I will see how "tipsy" the nose is. I did, however take your advise and shimmed my 40 size P-51 landing gear. It seemed to help, but running on asphalt I never had any tip overs. Just when I skidded off on the grass and tried to taxi back. dohhh
#69
The landings were a little rough. When the engine is cut the plane drops like a rock. We lost the elevator feel at low speeds and it landed hard. The Robart struts and Robart rubber tires all held up fine......just a nose over.
A couple of things that need to be adjusted:
1. The retracts need to be shimed forward (just as I was advised) It is a little tipsy.
2. Need much more elevator than recommended 15mm. I had it set at 15mm with 40% expo and at low speeds the elevator got REAL mushy. When landing the elevator response was lost altogether. Increasing the elevator and keeping the 40% expo should fix the problem. On my P-51 I land with full up elevator just before touchdown and it settles down nice and soft.
#70
NJ
You are not alone....Mine lands the same. I actually have 100% elevator throw with 50-60% expo. This plane you must fly in....learned it the hard way...A lot of nose overs...but with a little power an almost full elevator it landed like a champ.
I also added a piece of plastic under the cowl's chin...just for the nose overs. But this plane is very strong. I know this with at least 10 hard landings before figuing out how to land this bird.
But once in the air, the plane flys great...I have an OS .91fx with a three bladed 13 x8 prop.
All the best!
All the best!
#72
NJ
On mine, I actually used two servos for the elevator. (just more insurance for when I pull out of the scale manuvers)
especially the high dives.............
#74
Thanks for the advise. I just knew a lot more elevator on landings would help.
BDREW, I like the chin guard idea.
Scienceiscool, That is Alvin RC. We call it the country club. They just re-paved the runway (like it needed it) They also have an air conditioned clubhouse and a full kitchen. Oh yea the BBQ PIT ! We bring lots a food to grill and fly till dark.
