Reload this Page >
GROUP BUILD - Top Flite Giant Scale F4U Corsair
Old 03-27-2010, 09:16 PM
  #6951
Zeeb
My Feedback: (41)
Zeeb's Avatar
Default RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
ORIGINAL: NCIS
The 3305's are rated at 124oz. at 6V and are metal gears. The Twist 150 has a 1.50 Saito glow 4 stroke in it.
Barry
The Futaba 3305 is a surface servo and Futaba does not recommend them for airplanes, according to what Bax has said over on the Futaba support forum, it has to do mostly with the large deadband.
I've got a Funtana 90 with a YS-110 still hanging around and it has the 3305's on it since I couldn't find a servo with similar specs at that price point back when I put that model together. It's mostly designed as a 3D model and I don't fly it very fast so those servos have worked out pretty well, but the slop in the deadband is really evident if you grab say an aileron and wiggle it with the model's rx turned on.
Were I to do it again, I'd look at the JR Sport 126 servos which have a similar price point, MG, similar torque and speed specs but a MUCH tighter deadband. If you've not already bought the 3305's, I'd look at the 126 JR's.
JMHO, YMMV....
Just went and looked since they can be a bit hard to find on Horizon's website but the ST126MG is a bit faster, a little more torque and $3.00 more than the 3305's.
http://www.horizonhobby.com/Products...071#quickSpecs
Old 03-27-2010, 10:46 PM
  #6952
rt3232
Barry
If you have Futaba radio's you could use hi-tec 755mg's at 199+ oz @ 6v.
Cheers Bob T
Old 03-28-2010, 08:24 AM
  #6953
devens
devens's Avatar
I'm using the JR ST126MG servos. Very tight and strong servo. Slow but thats OK on a warbird.
D
Old 03-28-2010, 11:35 AM
  #6954
NCIS
I already have the 3305's in another plane I was going to take them out of. Since yesterday I have done some thinking and am probably going to go with HS-645MG servos. I'll just have to wait to buy them.
Thanks for the help!
Barry
www.canopyrailsforwarbirds.com
Old 03-28-2010, 09:43 PM
  #6955
devens
devens's Avatar
Update on my build. Yr 3 I made a commitment on this thread to finish her this spring and I am on pace. I will throw up some pics in the next couple of days. I have finished up the fine tuning of the flaps and have the fuse glassed. I have to finish up the trim tabs, glass the stabs and she is ready for paint.
I only have the initial coat of glass on her so the weave fill is first. I am planning on using automotive primer crossfire 15200. This is thick stuff and will fill the weave and allow me to sand smooth very easy. I am still contimplating the finish coat paint type. I am wanting to use exterior house latex. My uncle is experimenting with spraying latex. I am painting it with him because I don't have the equipment. He has had bad luck trying to spray latex but we are going at it with some new tips and trying some samples. Anyone have some suggestions?
D
Old 03-29-2010, 12:09 AM
  #6956
GaryM
My Feedback: (14)
GaryM's Avatar
Devens, as soon as you get some 80 plus weather and low humidty the latex will work better for you. Takes a long time to dry otherwise. Also keep your heat gun you use on plastic coverings handy. If you get a run in latex you can put some mild heat on it and almost always shrink and dry the run to where it want show up.
Primer is your biggest culprit in making a paint job heavy. Try to sand as much off as possible leaving just enough to fill the weave.
Have you looked at Roy Vaillancourts site for tips on painting with latex www.vaillyaviation.com
Old 03-29-2010, 09:10 AM
  #6957
v6goose
v6goose's Avatar
Absolutely true and i agree NCIS!
I, however, don't have access to beautiful machinery such as yours and I am building a 1/8th scalish F4U right now and didn't see anyone offering such a small size.
Cheers
Goose
Old 03-29-2010, 08:57 PM
  #6958
ctflyboy
Devens,
Take a look at Model Master a little pricey for each bottle, but I did my whole plane with it using an airbrush and you saw the results.
If I had to do it again I would not change it.
George
CORSAIR Brotherhood # 1
Old 03-31-2010, 04:18 PM
  #6959
acerc
acerc's Avatar
Okay Guy's, I need help! I would like to put in the gun bay door's but can not seem to find anything for size reference. Does anyone know where I can beg, borrow or buy any  picture, drawing, or sketch with panel lines, hatches, rivet's etc.etc. I must not be looking in the right places so please point me there!
No I'm not there yet. Getting ready to cover the wing's and just working out the detail's beforehand. Did not do that for the canopy, now I have to make a hole to put in the opening hardware. Live and learn.
Old 03-31-2010, 08:46 PM
  #6960
devens
devens's Avatar
ORIGINAL: GaryM
I read Roy's report. Very good info. TY
Old 03-31-2010, 11:01 PM
  #6961
nchrome
got a better one for you guys l would like to have rockets on my wings and don't know what size of tube or dowel rod to use for the proper size can anybody help on the measurments and maybe a picture of a single rocket and my corsair is the Top Flight Giant Scale F4U Corsair. l'm mounting a G-62 engine on her and also have a scaled tailwheel and hook thanks to Daddy Sam now all l have to do is get a set of mains and finish out the rest of her and hope to have her ready to test on the ground late this summer. Also does the cockpit kit fit this bird properly this is my second one and the first was pretty small for her the second does see more like the rite one though and also on the raidal engine who has a good on for this bird TFs is a little wrong as fra as the nose of the engine is l could modify it and hope to make it look rite but you know how that mite go for me that is [:'(]
Old 03-31-2010, 11:20 PM
  #6962
GaryM
My Feedback: (14)
GaryM's Avatar
ORIGINAL: nchrome
google Holy Moses HVAR Rockets This was a 5" rocket in full scale, not sure about the length. Some of the google hits might get you the info you are looking for.
Old 04-01-2010, 07:14 AM
  #6963
rt3232
nchrome
The T/F is flat enought to clear the 62 with out mods except for removing 1 cylender in front of the engine head, and from what I have read the williams brothers looks better but requires a lot of work to clear the engine. I am sure there outhers out there
cheers Bob T
Old 04-01-2010, 08:15 PM
  #6964
nchrome
than you rt3232 l like it to except for the end of the engine block it is too short for the proper engine for this bird but l think l can make due
Old 04-01-2010, 08:31 PM
  #6965
rt3232
nchrome
Way back in the thread there are pic,s I backed mine with some 3/32 ac ply and then soft foam filled and that seams to be working no cracks
Cheers Bob T
Old 04-01-2010, 08:39 PM
  #6966
Thunderbolt47
My Feedback: (8)
Thunderbolt47's Avatar
Nchrome,
Here is a Frank Tiano dummy radial in mine. I haven't seen the need to remove the center cylinder. It still gets enough air to stay cool. Also it wieghs about 12ozs so It's good for nose wieght.
However I have a ZDZ 80 in mine, so the G-62 maynot be as clean a fit.
Kelly
Old 04-01-2010, 10:14 PM
  #6967
Fly2XS
My Feedback: (65)
Fly2XS's Avatar
Nice looking installation Kelly!
How much power do you use during flight? (full throttle, 3/4 throttle, 1/2 throttle?)
Scott
Old 04-02-2010, 02:56 AM
  #6968
Thunderbolt47
My Feedback: (8)
I always use full throttle. With a 26 x10 it flys around 85 to 90 MPH and has a really nice prop arc.
No matter which engine you go with , you should always set your speed with the prop for full throttle flying. A mid-range throttle setting can be hard on an airframe. Engine resinance (sp?) is a bad thing. All engines go through this at some point in the rpm range.
Kelly
Old 04-10-2010, 11:09 PM
  #6969
Fly2XS
My Feedback: (65)
Fly2XS's Avatar
Bob,
We missed you today! I dropped by for breakfast and we had a great day at your field. Here's some pictures.
Scott
ID:	1415813   Click image for larger version
ID:	1415814   Click image for larger version
ID:	1415815   Click image for larger version
ID:	1415816   Click image for larger version
ID:	1415817   Click image for larger version
ID:	1415818   Click image for larger version
Old 04-11-2010, 09:44 AM
  #6970
JazzRC
Scott,
Great photos of a beautiful corsair!Those low pass strafing runs are the best... I was about ready to hit the deck!
Jim
Old 04-11-2010, 08:23 PM
  #6971
crashproof
First Warbird Flyin of the year. Easley SC My TFGS Corsair G62 Mezlik 20/10 3 Blade. Gonna be a good Summer. Kevin.
http://www.youtube.com/watch?v=X3wS7gidtO4
Old 04-11-2010, 08:49 PM
  #6972
DaddySam
My Feedback: (9)
Great Video. What does your Corsair weigh?
Sam
Old 04-11-2010, 08:53 PM
  #6973
crashproof
Thanks Sam, Corsair weighs 27lbs. Kevin.
Old 04-12-2010, 03:50 PM
  #6974
dabevan
dabevan's Avatar
Hi,
I'm just finishing off my TF GS Corsair and wondered where most people are setting their c of g?
...anything I should watch out for on the test flight?
Build photos are here ==> http://picasaweb.google.co.uk/dabevan/Corsair#
Many Thanks
David Bevan.
Old 04-12-2010, 08:51 PM
  #6975
devens
devens's Avatar
dabevan
I beleive it is 5-5/8" back. Don't take my word for it wait for Bob or someone to speak up. I do know that the CG in the manual is incorrect so don't use it or you will be tail heavy. What does your bird weight? What did you use for covering?
D
