Reload this Page >
GROUP BUILD - Top Flite Giant Scale F4U Corsair
Old 07-16-2005, 06:49 PM
  #51
rt3232
Default RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
This is the lighting holes ha.. does any one know what (Avtive server pages error ASP0113. Script Timed out ) means if so help !
Next pic
Old 07-16-2005, 06:59 PM
  #52
rt3232
next pic
Old 07-16-2005, 07:18 PM
  #53
rt3232
JD hammer the next 4 pic's will help you with a muffler design, I did not get any over heating with this one
Bob T
Old 07-16-2005, 07:28 PM
  #54
rt3232
next pic
Old 07-16-2005, 07:38 PM
  #55
rt3232
next pic
Old 07-16-2005, 07:47 PM
  #56
rt3232
next one
Old 07-16-2005, 08:12 PM
  #57
bosssman
My Feedback: (35)
Bob,
Are these pics of your CURRENT buildup, or of your previous GS Corsair? I should be posting pics later tonight as I am in the middle of sheeting the top of the fuse. I have been using one of my smaller Forstner bits to lighten the plywood around the stab mount and the rear tailwheel area.....
randy
Old 07-17-2005, 07:18 AM
  #58
rt3232
Randy
These are pic's of my current build, I have been using my notes of thingsI did or didnot do from the first build. If you need or want more in fo on any of the pic's I will try to accomidate ..I am going to try to post the pics of the retracts located in the c/section that shows the beams to close to the lower surface. they were trimmed 1/16 befor installing , but I am going to trim another 1/16'
Old 07-17-2005, 07:30 AM
  #59
rt3232
next pic
Old 07-17-2005, 07:46 AM
  #60
rt3232
Well I finaly got all of my current pic's posted, I hope they will help those you who are in these stages. I would like to add a word of caution about this fwd part of the center section it MUST BE SQUARE particularly the l/g suport ribs. take your time, would like to see some ones else post there pic,s
Bob T
Old 07-17-2005, 08:58 AM
  #61
Rocketman612
My Feedback: (85)
Rocketman612's Avatar
Bob,
Looking good.
The wing and build look similar to the 60 size kit. I found this stage to be about the hardest part in terms of keeping everything square and getting the proper alignment and fit of the retracts. I used CJ's and they only rotate 90 deg so there is a tradeoff between how far forward you want the extended wheel in relation to the wing leading edge (to prevent nose over and proper scale look) and how well the wheel buries in the wing when retracted. I believe the Larger CJ units also only rotate 90 deg.
Considering the importance of this area it's too bad TF didn't make a jig for us to use during this part of the build.
Pete
Old 07-17-2005, 09:36 AM
  #62
D Bronk
D Bronk's Avatar
ORIGINAL: Rocketman612
The wing and build look similar to the 60 size kit. Pete
YES way too many similarites` to call the 2 sizes of T.F. CORSAIRS totaly different.Lots can be done by scaleing up or down to suit the plane,that a person is working on,,,D.B.
Old 07-17-2005, 10:36 AM
  #63
JDHammer
JDHammer's Avatar
Bob,
Pete
Rocketman- I noticed from other threads that the full scale wing incidence is actually 2 degrees positive. Maybe this would help in keeping the wheels forward while still getting full retraction into the wing?( Just guessing, haven't started yet.)
rt3232- Thanks for those muffler pictures, looks like lots of possibilities for scale exhaust and sound reduction. JD.
Old 07-17-2005, 11:59 AM
  #64
rt3232
I will add one more thing on my new build I will plug the exhust ports about 40% this will still give me more port than is on original muffler and should reduce sound a little more...
Bob T
Old 07-17-2005, 01:36 PM
  #65
timothy thompson
is the first one unrepairable. fuse looks ok firewall unattached and rt wing damage. i bet you could fix it. If you loose power keep nose down and belly in do not drop gear or flap. less damage. that rough plowed field probably did more damage than if it was grass. good luck on the new build
TIM
Old 07-17-2005, 04:41 PM
  #66
madibav8
madibav8's Avatar
Sam,
I might be able to help on the pilot front, check out www.scaleaircrewsupplies.co.uk.
regards
Mark
Old 07-17-2005, 04:54 PM
  #67
rt3232
Tim
Looks are realy deciving, as I took keep it light approch, and just covered with ultracoat. On the fuse from the fire wall back to cockpit it was balsa in bag, the wing was in better shape but in the post mortom the main spar was a total loss, a bit of history 7 flights and it was flying buetifuly came across field for a pic shoot at about 5' 1/2 throutlejust started a clime and left turn away from the field at about 30' altitude the engine qiut the rest is history
In my research on corsairs, the first hand comments on engine failure was GET OUT as thr real bird had the glide angle of a rock even if you maintained air speed your rate of decent was extremly hi.
So its build a new one.
Bob T
Old 07-17-2005, 06:23 PM
  #68
timothy thompson
glassing what method
Old 07-18-2005, 06:28 PM
  #69
rt3232
Tim
I my limited experiance most finishing epoxy's work well, and from reading between the lines in the threads it is the weight of cloth that is the bad guy. I have used some 1/2 oz to the yard, vary difficult to handle but once you get the hang of it it is do able. Don't khnow if this helps, but thought Iwould offer it any way.
Bob T
Old 07-18-2005, 10:25 PM
  #70
Peter_OZ
Banned
I have read a few articles on this bird and of the need to beef up the gull centre section in a few places. You may want to think aBOUT THIS AND GET SOME ADVICe
cheers
Peter
Old 07-19-2005, 07:45 AM
  #71
Rocketman612
My Feedback: (85)
ORIGINAL: Peter_OZ
cheers
Peter
The center section builds like a brick "S" house except for the need to add doublers to the spar where you notch them for the retracts.
Pete
Old 07-19-2005, 08:13 AM
  #72
D Bronk
D Bronk's Avatar
YEAH once ,you laminate(no less than 30 min.epoxy),clamp and let cure.It`s a very strong structure.I Bet, that a person can stand on it!!!The only way that will fail is a serious crash(but I doubt it),or builder error by not using the proper procedure,or bonding agents (more likely)......D.B.
Old 07-19-2005, 09:08 PM
  #73
Peter_OZ
Banned
no worries, just read an article in the TF website on the build, the writer stressed there were several sections that required reinforement.
cheers
PEter
Old 07-21-2005, 03:12 PM
  #74
sfsjkid
sfsjkid's Avatar
ORIGINAL: mirwin
I lust for a TF / GS F4U but, having just finished my newest plane this week, there's no way I can swing it until after the 1st of the year. I'm content to wait, but I'm concerned that TF will pull this off of the market before I get mine.
Has anybody heard any rumors about TF running this GS kit for only a short time?
Thanks much,
Mike
Mirwin, I too felt the same way about buying the Corsair, but I found out that Tower is doing an easy pay event (ie cost is divided into 3 payments, NO interest charged!!!!). Missed it once so this was too good to pass up, especially with $30 if you order other stuff to hit $300. So to make a long story short, Bossman, thanks for starting this thread, I'm sure I'll be refering to it when I start mine around next year or so?
Old 07-21-2005, 07:13 PM
  #75
rt3232
Dave & all
I did limited test sampling on glue strength elmers, tight bond, gorilla and epoxy 5min and 30 min, I used the same size pcs of lite ply with a 1inch square of glued surface, all samples were let dry 48 hous. I wont give all the details . But the results were in shier they all were with in 10% 0f one another, Oh one outher thing all samples were weighted. elmers and tight bound failed at the loest settings, gorilla glue and the epoxie's were with a breath of being the same but the gorilla turned out to be the lightest buy about 20%. I did this just to convince my self that gorilla glue was a use able glue in my building process. so I have used it in all laminates in this new build
Bob T
When my computer H/D crashed I lost the detailed report with all the numbers, so don't ask
