New CMP 50-sized Corsair
#101
Location: Hamilton, Scotland & La Roche Bernard, France
RE: New CMP 50-sized Corsair
Erec11
You will have to remove a small amount from the dummy engine if you're going to use it. I chose to leave mine off the model as I would have to cut too much away.
To upload pictures, when you reply to a message look at the bottom of the text window and you'll see "Click here to upload images and files!"
That will let you add images from your source.
regards
Scott
regards
Scott
#102
Ok tanks i will arrange a way to put something nice there. Loock to my engine mount, this will give some strigh and put the eight far from the fuse.
#103
Hello i still think that something is not right because the engine is way above the line!! i aligne the top of the engine mount with the line on the right and horyzontally aligne with the line above.
#104
TX
I'm not sure I understand you engine alignment problem. Here is mine with the cowl in place and dummy radial. It is a Rossi 60 with a Pitts.
Bob
Bob
#106
Ok this is the problem: in the fuse you have two sets of lines two lines on vertical and two lines in horyzontal, and i have to aligne my engine mount , but what lines should i use? this is the problem, so can you help? I belive that i shoul aligne with those in red in the picture tell me what you think.
#107
Ok i have just now reeforced the fuse from inside. I glued two half moons from 5mm wood after i have glued from out side of the fuse also with 5mm wood. Now i think this could take my .61 FX without brake!!
#108
TX
What kind of engine are you using? I placed my engine so that the prop shaft was in the center of the firewall. I know that the CMP instructions are rediculous, but I didn't have any problem with this portion of the assembly. I pretty much lined up the mount with the lines, and the center of the shaft was on center with the lines. Unless you use a small engine (and add a ton of weight) you will be butchering the cowl.
Bob
Bob
#109
i have the OS 61 FX engine and my problem is the two set of lines so i dont know with what lines i should aligne the engine mount. Because one of the set is right centered with the fuse and the other set is abault 5mm to the left in the vertical and 5mm above the center line in horizontal. check in your fuse inside the cowl if you dont have this two set os lines. Tanks
#110
I have drilled and aligne the engine mount and put all together and it happend....! it is not centered with cowl, watch the pictures!
#111
Does anyone nows how to put those 2% down trhust?! And i just now way the two line here is the explenation in the picture.
#112
TX
Erec,
I am nt sure what to tell you on the center lines. I positioned the the engine in place before drilling to ensure the center. I did not have the wooden mount between the engine mount and the firewall. Also, the downthrust is built into the firewall. You should not need to alter this. I added a little wood for re-enforcement behind the firewall, but not in front.
Bob
Bob
#113
It dosen´t have the down thrust! Only the right thrust! I have put 2mm of washers on the engine mount that should do just fine.
#114
Ok i belive that now is just fine!! After some changes......... see the pictures! And those are the Oleo Struts that i´m gonna use on it
#117
If I remember correctly it was already done on my model.
Poke around and see if you can find pre-drilled holes
#118
My Feedback: (15)
eric , whose retracts are they , they look good , what brand and are they avaible in the states .
Also if you are trying to drill the wing mounting nubs my suggestion is as follows, set your wing in the plane with tape , measure and make sure your angles are correct and incidence .
Purchase a 12" or 15: drill bit and go in from the front bulk head if you have access . Becareful to measure everything before you drill , this works perfactly everytime
#119
To LDM : This retracts are just 90º the rotating retracts are from CMPro and you can buy them in England in this store: www.Galaxymodels.co.uk the landing struts with suspension they are made by order in every size you whant if you need ones tell me i will give you the mail of the artist who made them, and they are not expensive!! Abaut the wing that aint easy but i will try.
#120
Hello people i need a favor can you please post some pictures of the wing so i can see those aluminium pins to join the wing with the fuse. Just another one those pins they dont stay complete in vertical right?
#121
My Feedback: (15)
Thanks Eric , the gear looks good I only use sierra and CJ rotating gear but sierra is expensive !!!
Give the wing drilling idea a shot , test your skills on wood and get use to the long drill bit , when you go thru the first bulkhead , stop , look and see if you look like you dead center before you proceed to the second and into the leading edge .
I have use this method on so many ARfs , its 100% accurate if you take your time
#122
Hello can i see some pictures of yours retract servo on the wing please? Tanks
So this model has a problem with the heat, it dosent let the air to flow inside to out side of the cowl so i have this idea: remove two pieces from the cowl and put some net on it. Something like this:
#123
Do you have the movie of the corsair in action? I've just bought one with OS-70 and I cant wait for air battles with my collegs..
P.S.:Sorry if my english is bad..
Bye
Bye
#124
My English its not that good! I haven´t fly with him because at the same time i was finishing my Mustang P-51, maybe in the next month. Thats a great engine, i go for the OS 61 because a 70 four-strok is very expensive!!
#125
IL
Glad to see this forum still going. It's been a while since I logged on to it and when I did today and read the post I had put in, I got a chuckle on all the problems I had with this plane. Well, I still have my second CMP 50 Corsair and it flies great. I remember going to the flying field with this plane and not being sure if I will return with it. Now all has changed, when I look at my warbirds and I want a plane that is easy to fly for the day, I grab my Corsair. At first I was scared to land this bird, now I go inverted ten feet off the runway. No trick to flying this plane, get airspeed up before taking off and then climb out as level as you can, that both adds air speed and looks cool. IF it's balanced correctly, it will land as easy as a trainer. Experience and time is all it takes to get comfortable with this plane.
Larry
Larry
