KMP Stuka-build details
#453
RE: KMP Stuka-build details
Sorry it took a bit (busy weekend) but here are some pics of underneath the cockpit. I made a new servo tray for the elevator servo inline with the centre section that I did not cut out. The cockpit floor in 2mm balsa on the 1/4 square balsa rails I glued to the sides on the cockpit. I moved the throttle servo up to the side next to the fuel tank by elongating on of the pre cut lightening holes to fit a Hitec HS-81. As mentioned earlier my receiver sits in the centre box section. Nice work by the way Ty on your moulded abs cockpit. Is it suitable for the B model or just the D. Cheers,
Dave
Dave
#454
Has anyone set up their wings to be detachable? If so can you provide any details?
For those that have glued their wings, is epoxy good enough? is there any other glue that is recommended? I heard of some people using what is called Gorilla glue. On;y down side I am told is that it expands.
#456
My Feedback: (12)
SC
TD, the slots are big enough. Make sure u lay the servo on it's side with the arm installed and then glue the square mounts onto the hatch...I used 30 minute epoxy on the wings...
Anyone who has built the stabs, did you notch out the stab or the elevator for the u connecter bellcrank wire to sit in? one thing i found, install the cables onto the elevator bellcrank wire BEFORE you glue the stabs in place...
#457
Thanks for the info. I just completed putting the servos in place and bolted the hatches down with extension servo wires done also.
I also put epoxy on the servo wood braces as they tend to crack.
#458
My Feedback: (12)
SC
Cool, have you done anything with the stabs first? Make sure u install the cables onto the bellcrank then insert it first before you glue the stabs on..Also my aluminum stab tube is about 1/8 too long. Nothing my dremel didnt take care of though.. What engine you puttin in it?
#459
My Feedback: (12)
SC
Waiting on the epoxy to dry...Like I said earlier, make sure u install the elevator control bellcrank in first...
On the tailbraces, does the end with the 1 screw hole go in the stab or in the fuse? The destructions I have show it both ways....I'm not gonna use the supplied ca hinges. I dont trust them so I''m gonna get the flat pinned dubro ones...
#460
If you look at historical pictures, the one screw hole for the brace would go on the stab and the two on the fuselage. Im building the B model and it shows it correctly, but the fuse has a dimple for just the one. Actually for the D model, historical pictures show a solid brace with the wider area at the fuse and the thinner area at the stab.
I am converting mine to electric using an E-Flight 110. Also going to put in an engine sound system.
#461
My Feedback: (12)
SC
The aerovate 26 cc ready to go...I used a plane steering arm for the throttle lever. I will mount the ignition battery on top of the 2 top standoffs on a plywood plate.
#462
MA
ORIGINAL: tdbeltz
Just remembeer to keep the rubber side down when landing.
#464
The set-up I am using for electric conve3rsion is as follows:
1) Motor= Eflight Power 110
2) Battery =4 Hyperion 4s/14.8v 25c 3300mah in sets of 2(for 29.6volts 6600mah).
3) Motor mount = adjustable metal mount
4) ESC Controller = Castle Phoenix HV110
5) BEC = Castle HV CC BEC Pro
6) Prop size = ?
7) Sound System = Benedini TBS Mini sound system
6) Prop size = ?
#465
My Feedback: (12)
SC
td you wouldnt want to use gorilla glue for the wings. It is mainly used on two surfaces you can clamp together, like fuse doublers...I always use 30 minute epoxy on the wings....Hope this helps.....
#467
My Feedback: (12)
SC
So how many folks are gonna install the "dummy" flaps ? Has anyone flown with them on and then removed then and noticed different flight characteristics?
#468
My Feedback: (12)
MI
Are you talking about the dive flaps that are near the leading edge of the wing? I'm putting them on for scale effect. They will undoubtedly cause drag, but I don't think that it will be a lot.
#469
My Feedback: (12)
MI
I'm curious about the 2 degree engine thrust offset that's mentioned in the instructions. Is the offset built into the firewall or do I need to create it myself?
#470
Why are the inner flaps being called "Dummy Flaps"? My understanding is that the inner flap is functional when you insert the metal rod between the inner and outer flap. The instructions say to glue the rod in the inner flap hole and leave the inserted rod of the outer flap free to turn within the hole when you operate the flaps. Is this correct?
#472
My Feedback: (12)
SC
Yep, the ones that glue in twd the leading edge...Knowing the destructions, that 2 degrees is probably wrong too, but I didnt do anything about the thrust line of the engine.
#474
For anyone who wants to add a bomb drop, here are some pictures of some that I picked up at a few different hobby stores. Hobby King and Hobby Lobby are where I saw them available.
#475
My Feedback: (12)
SC
I like the dark colored one...does it come with a release too? My stuka came with a bomb and I'm planning on making it releasable when I get around to it...
