Reload this Page >
KMP Stuka-build details
Old 05-12-2017, 11:13 PM
  #1101
Prekin
My Feedback: (19)
Prekin's Avatar
The first test of sliding canopy.
ID:	2214754   Click image for larger version
Old 05-13-2017, 05:40 AM
  #1102
Prekin
My Feedback: (19)
Prekin's Avatar
Guys, I need your help. There is an error with the gun pods mounting. I made a template for marking the holes and it seems that one hole will be in servo area!
I looked around and found some guy with "tank buster". His Stuka has different paint scheme and location of the servo.
Is there anyone with same type of the wing as on my Stuka with cannons?
ID:	2214796   Click image for larger version
ID:	2214797   Click image for larger version
ID:	2214798   Click image for larger version
Old 05-16-2017, 03:17 AM
  #1103
ProScaleRc
Originally Posted by Prekin
The first exhaust line is done. I´m looking forward to the moment when I put the painted stubs into the cowl. You can compare the ESM exhausts and the mine.
Hello,
Are you going to sells these on your website? I would;d like to buy a pair.
Old 05-16-2017, 06:55 AM
  #1104
Prekin
My Feedback: (19)
Prekin's Avatar
PM sent.
Old 05-17-2017, 04:05 AM
  #1105
ProScaleRc
Old 05-28-2017, 06:57 AM
  #1106
Prekin
My Feedback: (19)
Prekin's Avatar
Yesterday I glued the left wing. The right wing I glued last morning. When I try to fit the wings I found out, the gap between the wing and the central fibreglass part. I try to send it, but without any big success. I put more glued on that space. The result you can see in the picture.
ID:	2217608   Click image for larger version
ID:	2217609   Click image for larger version
Old 05-31-2017, 12:22 PM
  #1107
Prekin
My Feedback: (19)
Prekin's Avatar
Some progress on the landing gear. Root covers are glued. On the other shots are the legs locks. The same aluminium plates will be on the pants. Each leg is lock by 4 srews. Plywood blocks are also glued in the pants.
ID:	2218022   Click image for larger version
ID:	2218023   Click image for larger version
ID:	2218024   Click image for larger version
ID:	2218025   Click image for larger version
Old 06-01-2017, 09:47 AM
  #1108
Prekin
My Feedback: (19)
Prekin's Avatar
Is it normal, that there is a big space between the pants and the wing?
ID:	2218323   Click image for larger version
ID:	2218324   Click image for larger version
Old 06-16-2017, 11:38 AM
  #1109
Prekin
My Feedback: (19)
Prekin's Avatar
Wing and gun pods are almost done. I will sand the wood cylinders and glue the inner flaps.
ID:	2220411   Click image for larger version
ID:	2220412   Click image for larger version
ID:	2220413   Click image for larger version
ID:	2220414   Click image for larger version
Old 07-01-2017, 07:52 AM
  #1110
Prekin
My Feedback: (19)
Prekin's Avatar
I was thinking if should I cut a hole for the exhaust stack in the cowl as I did on my Spitfire. I´m sure it would look better, but it is easier to glue the exasuts into the groove which is prepared in the cowl. I cut 9mm (0.35") of each root and fitted the stubs.
ID:	2222551   Click image for larger version
ID:	2222552   Click image for larger version
Old 07-02-2017, 12:25 AM
  #1111
Prekin
My Feedback: (19)
Prekin's Avatar
Today I will glue the exhausts on the cowl. The painting job is not done, I will add some weathering when they will be on the cowl.
ID:	2222632   Click image for larger version
ID:	2222633   Click image for larger version
ID:	2222634   Click image for larger version
ID:	2222635   Click image for larger version
Old 07-03-2017, 06:47 AM
  #1112
Prekin
My Feedback: (19)
Prekin's Avatar
Exhausts are attached to cowl. Before glueing I sanded the paint from the cowl.
ID:	2222763   Click image for larger version
ID:	2222764   Click image for larger version
ID:	2222765   Click image for larger version
ID:	2222766   Click image for larger version
Old 07-15-2017, 11:33 AM
  #1113
Prekin
My Feedback: (19)
Prekin's Avatar
The first moments on day light.
ID:	2224368   Click image for larger version
ID:	2224369   Click image for larger version
ID:	2224370   Click image for larger version
Old 07-16-2017, 07:29 AM
  #1114
Prekin
My Feedback: (19)
Prekin's Avatar
Dry weight without the batteries is 7720 grams (16.9 pounds). I started the weathering. Wings are almost done. Next weekend I will continue on the wing and fuselage.
ID:	2224444   Click image for larger version
ID:	2224445   Click image for larger version
ID:	2224446   Click image for larger version
ID:	2224447   Click image for larger version
Old 07-24-2017, 10:05 AM
  #1115
Prekin
My Feedback: (19)
Prekin's Avatar
Cowl is fitted. I wish to find some fast way how to do it. I use to attached RX switches on some hidden place. The only space I found is beside the pilot.
ID:	2225459   Click image for larger version
ID:	2225460   Click image for larger version
ID:	2225461   Click image for larger version
Old 07-26-2017, 01:13 AM
  #1116
Prekin
My Feedback: (19)
Prekin's Avatar
Antenna mast. The shape is not very scale, but the canopy looks better with it. It will removable because of transport. If I glue it, it would be broken after few transports to the airfield.
ID:	2225672   Click image for larger version
ID:	2225673   Click image for larger version
ID:	2225674   Click image for larger version
ID:	2225675   Click image for larger version
Old 07-30-2017, 06:28 AM
  #1117
Prekin
My Feedback: (19)
Prekin's Avatar
Underside of the wing and pants are done. Now I´m waiting only for the batteries.
ID:	2226200   Click image for larger version
ID:	2226201   Click image for larger version
Old 09-11-2017, 11:03 AM
  #1118
Apache06
Hi Jiri,
nice job on your Stuka !
I have a problem on mine : I just received a brand new cowl from ARF Pro in USA...it's bigger than mine !!!
My ESM Stuka is an Airex / Fiberglass version...I don't understand !
