KMP Stuka-build details
#526
My Feedback: (12)
SC
RE: KMP Stuka-build details
How much more do you have to do ? Im gonna try to fly mine again on saturday. Im still waiting on a replacement canopy to come in. I shifted some batteries around to get more weight up front...
#528
My Feedback: (8)
I happen to know where there is a rare Full Composite Stuka available at a obscure town in Oregon if anyone is interested. Just PM me for the number and location.
#529
I tried out the quanum bomb system last weekend on a test plane and it worked really well (once). The release system is good but the bomb itself broke into a bunch ofparts even though it landed on dirt.
The bomb has too hard a plastic, so there is no give. I mainly bought it for the release system anyway. Plan on attaching to my Stuka.
#530
My Feedback: (12)
SC
OUCH ! ! I have an old vortec release unit. I made a small box out of balsa and mounted a mini servo inside it. Painted it black and glued it to the bottom of the center of the wing. I used the bomb that came with the plane. It worked great.
#531
I have the vortec systems as well. I used them on an old Royal kit Stuka I built. I put them on the wings and they worked great. Unfortunately Vortec is no longer around.
I have som orange bombs that are more flexible and work well. I just need to cut out some slots on the bomb, as the hooks are on the drop system instead of the reverse like the vortecs.
#532
My Feedback: (12)
SC
Td, here is my elevator set up..It's a 4-40 rod, ball link on the threaded end and a threaded solder coupler on the other end screwed into a ball link attached to the servo....
#533
ORIGINAL: tdbeltz
I tried out the quanum bomb system last weekend on a test plane and it worked really well (once). The release system is good but the bomb itself broke into a bunch of parts even though it landed on dirt.
#535
My Feedback: (12)
SC
yup it's a solid metal rod..I didnt put it in a sleeve. I have it running thru the former where the stock plastic sleeve was for the pull pull, just had to drill it out slightly, and I have it thru another former at the tail end that I made out of a thin piece of plywood.
#537
My Feedback: (12)
SC
Well, if one of the cables ever broke, how in the heck would you get back there to repair it? Also what they sent, well I hung a 15 pound weight suspended from one end of the cable, had the other end tied to a rafter in my shed, and it popped.....
#538
I see your point on if it broke,however,now that I have already installed the cable, how many pounds do you think the elevator willput on thecable when it is flying?
#539
I used pull-pull but used dubro cable and links. You can get to the assembly installed in the aircraft, but have a spare afternoon and no small children within earshot when you try to get them off/on. It can be done however...Cheers,
Dave
Dave
#540
My Feedback: (12)
MI
Here's a link to the pics of my scratch build cockpit and pilot.
http://www.rcuniverse.com/forum/fb.asp?m=9619341
#541
My Feedback: (12)
SC
Iroc, the cockpit looks good....So what about the servo section. Did you have to cut it all out and move everything? Love that pilot too....Have you flown it yet?
#543
My Feedback: (12)
SC
Flew it today with the batteries up front. MUCH BETTER ! ! ! It didn't want to climb and all in all the plane just felt better. I haven't used the flaps yet..I did have to make a deadstick landing but the plane did just fine... I switched to a from a 17-10 to a 18-8 prop and the engine didn't seem to like it very much though.
#544
My Feedback: (12)
MI
Good job on the deadstick recovery. So I guess in the end it was a bit tail heavy. Interesting. Sounds like the factory recommended cg might be too far aft.
#545
My Feedback: (12)
SC
Thanks....Now you know that there is nothing wrong with the specs in the manual.. I didnt try much with the plane, just boring holes in the sky. I did try some high g turns and it did not want to snap out which is good.. Something is going on with my spinner. When I tighten the nose cone down, the back plate warps in one spot..I will see if Tomas sells one for it...
#546
I believe Thomas and TBM will be getting spinners for the Stuka soon. However, you can also use a parabolic spinner like a P-51 because most stuks had a spinner pretty close to the same shape. I ordered one from Dave Brown and had it cut for 3 blade 16x10 prop.
#548
My Feedback: (13)
IA
Andrew S:
I did get a 4-40 solid and sleeve at the LHS...does have one end threaded,and on the other end,will solder a 4-40 push rod connecter...also will try and put a plywood brace between the two connecting points..(Halfway down the back of the fuse).....right now,will finish the wing..then do, the fuse when I get to that point........
#549
Andrew,
How were you able to drill a hole on the inside brace of the fuselage for the the 4-40 pushrod? Obviously there is no room to get a drill in. What was the secret?
#550
My Feedback: (12)
SC
I could get a drill inside the fuse to drill the factory forward brace where the plastic tube is for the pull pull and at the back I made another one, drilled it and glued it in place to the rear factory brace...
