CMP BF109F BUILDING THREAD
#1801
RE: CMP BF109F BUILDING THREAD
ORIGINAL: messer
Thanks. What's the size of the Platt spinner.... Are the slots cut for the prop? Is it close to the one in the Bf-109 kit?,
Messer
Messer
Slots are NOT cut for a prop. However, if you emailed him and ask if he'd do it for you, he might, I dont know. I had a friend do it for mine. The Platt spinner is a true to scale shape.
#1804
Hi all, I have a question about gasoline engine for this bird, can the DLA30 fit in the cowl and that engine enough power?
Thanks, Tom
Thanks, Tom
#1805
The DLE 30 has more then enough power for this plane. will it fit in the cowl completely? Well....probably not.
Experten is doing a bash on this plane and hes using a DLE20 and got it to fit completely, however, the DLE30 may not.
See his thread here for pics showing the motor clreanance:
http://www.rcuniverse.com/forum/fb.asp?m=10410391
#1807
My Feedback: (-1)
ORIGINAL: kahloq
#1810
ORIGINAL: Experten109/40
thanks, I'll look into the plat spinner.. as long as there's a 3-blade available.
#1812
Here is a youtube video of a custom 1/5 scale me-109 designed and built in Finland. There is a shaft extention on the motor allowing the head of the motor to be in the lower chin scoop. The designer built a 1/5 scale version and a 1/4 scale. I believe if my eyes are correct this is the 1/5 scale. I owned one of his handful of kits way back in the 90's but due to work never got to finish it and sold it( much regrets) . Anyhow I have two cmp's on the go in the shop. Tero T in Toronto http://www.youtube.com/watch?v=XXT9-eNbivo
#1814
My Feedback: (-1)
very nice. one of the nicest 109's i've seen in while. looks like I'll have to
raise the bar on mine a few notches. too bad the vid quality sucked.. but
thanks for posting it!
#1820
You can use any paint, testors, krylon, it doesn't matter. Coat over the paint with minwax matte finish polyurethane (in the spray can, NOT the water based). I also used the minwax to put a coating over the decals I added, it matches the stock finish very well and holds up better than anything in glow fuel. For Gas power, I can't say how it would do.
#1821
VA
Looks great. What type of engine are you using? I'm thinking about using a OS 1.60 2 stroke. Also, are the throws correct in the manual? Are you mixing in any elevator when deploying the flaps?,
Thanks, Messer
Thanks, Messer
#1822
OS 1.60 with an APC 17X10 prop. It's been a few years, so I'm not sure about the throws. I believe the recommended throws are OK as a starting point. I don't mix any elevator in with the flaps. Once I go above half flaps they function as air brakes to help slow the plane, something it needs with a 10 pitch prop. The high pitch prop allows me to cruse around at half throttle (over 100 mph) to save fuel because I have the stock fuel tank.
