Reload this Page >
COMP ARF 110" F4U ARF WITH FOLDING WING ASSEMBLY
Old 08-08-2011, 06:41 PM
  #1151
ram3500-RCU
My Feedback: (221)
ram3500-RCU's Avatar
Default RE: COMP ARF 110
ORIGINAL: luckyb001
Front Hinge from Sierra to replace the one it came with.
Is this interchangeable with the original design? Looks like it would eliminate the front hatch, even though it is on the full scale.
Old 08-08-2011, 07:04 PM
  #1152
luckyb001
My Feedback: (8)
Yes. It goes in the same way and eliminates the front flap. Saves you from having to get two flaps working.
Old 08-08-2011, 07:06 PM
  #1153
ram3500-RCU
My Feedback: (221)
ORIGINAL: luckyb001
Nice. I'll have to call Darrel I guess.
Old 09-11-2011, 07:26 AM
  #1154
constant1462
Hello Everyone
I also have a home F4U composit arf, I'm in the finishing of the aircraft.
so I am looking for info on the location of the decals on the aircraft.
I already find those "tailor" but it shows that for a few and there are many more.
thank you for your help
chris
Old 09-11-2011, 01:52 PM
  #1155
ram3500-RCU
My Feedback: (221)
ORIGINAL: luckyb001
Here is a picture of it. This is two sets, enough for two planes. You only replace the half bolted to the center section.
Old 09-11-2011, 03:53 PM
  #1156
samparfitt
My Feedback: (43)
Chris,
I used Major decal (water transfer) for the stars-n-bars:
http://www.majordecals.com/
and Taylor made for the nomenclature:
The Taylor made comes with a location diagram.
http://tailormadedecals.com/xtc2/ind...da528c5cd0b938
Old 09-11-2011, 03:55 PM
  #1157
mikefrench1
My Feedback: (28)
Disregard. could not delete this.
Old 09-11-2011, 10:11 PM
  #1158
constant1462
hello samparfit
I already buy my decals at Tailor, I also plan to Tailor for the location of the decals, but it shows that for some decals.
so I am looking for something more complete and precise position of its decals
Chris
Old 09-12-2011, 04:06 AM
  #1159
samparfitt
My Feedback: (43)
Chris,
I get most of my documentations from Squadron Signals walkaround books and other paper back manuals. They usually have a lot of close up pictures that reveal nomenclature.
http://www3.towerhobbies.com/cgi-bin...&I=LXBHRN&P=ML
Old 09-12-2011, 04:13 AM
  #1160
constant1462
thank you
but I send email to tailor and he send me update to the decal positionen.
Old 09-12-2011, 12:49 PM
  #1161
vfrank59
.m
Old 09-14-2011, 06:49 PM
  #1162
vfrank59
Well, My 3 postal scales came in today. I used the postal scales, I got 3 off Ebay, total price 100 bucks, they will handle 55 lbs each. I did the math for weight and balance.
The Sling machine, I built last week, confirmed that it works excellent.
Anyway, after all the math, it matched the 10 dollar sling machine, within 4 oz.
I still need to add 5.5 lbs of lead. but at least I feel better about it.
Time to get off the Pot and schedule the Maiden for next week!
Think i will donate the postal scales to the flying club. They can use them for something.
Vern
Old 09-19-2011, 03:38 PM
  #1163
samparfitt
My Feedback: (43)
PM.
As with my other warbirds, I'm re-enforcing the 4X40 control rods by JB welding rectangular brass tubing over the rods.
The inside flaps are completed.
The servo arm was also aligned with the control rod to reduce servo stress.
Outside flaps and ailerons still need to be done.
Depending on the weather and other commitments, I'm hoping to get her in the air in the next 3-4 weeks.
ID:	1664417   Click image for larger version
ID:	1664418   Click image for larger version
Old 09-19-2011, 07:47 PM
  #1164
onewing
My Feedback: (27)
onewing's Avatar
Sam,
I built my plug-in version using many tips you and Paul shared with everyone here. Thanks. I set my CG as specified on the manual (1/2 inches in frot of the front edge of the spar, when looking at the top of the wing), and it was good. One reminder, have you considered sending your retract back to Darrel for some modifications? I did it for the peace of mind.
Onewing
Old 09-20-2011, 05:39 PM
  #1165
samparfitt
My Feedback: (43)
Onewing,
Always glad that my threads help others.
Today, I talked to Darrell and he said to send the scissors section in for the weld.
As long as I don't 'prang' the plane on landing, the gear will hold, 'as is'.
Bouncing a 50 lb plane on the ground that's doing 30 MPH: something's going to break: I prefer a weak spot in the gear versus ripping out the gear mounts, or worse! (gear parts are easier to replace than a hole in the wing!).
My gear, with full air, does not retract when pressure is applied to the front of the wheel, so I have to assume the same for a normal landing.
Large planes fly more realistic and are easier to fly but they also have to be flown like a full size airplane: anything other than a smooth landing on a full size plane is, most likely, going to result in gear damage.
Pranging a non-rotating gear will probably be a little more forgiving but, the complexity of a rotating gear makes them more vulnerable to damage.
PM (cont)
Today, I finished the outer wings flap and aileron control horn re-enforcements.
All flaps were checked and adjusted for equal deflection.
I had hs-5645 servos on the ailerons and switched them to HS-7955's to insure no flutter occurs.
ID:	1664870   Click image for larger version
Old 09-21-2011, 03:13 AM
  #1166
JamF4U
Wow looks awesome. Mine should be in the air early next year, quick teaser below.
ORIGINAL: luckyb001
Here are a few more shots. Love this plane.
ID:	1665011   Click image for larger version
Old 09-21-2011, 04:17 AM
  #1167
samparfitt
My Feedback: (43)
Jamf4u,
Nice paint job.
Where'd you get the stars-n-bars with the red outline as I haven't seen those type for sale for large planes?
Old 09-21-2011, 04:41 AM
  #1168
JamF4U
ORIGINAL: samparfitt
Jamf4u,
Nice paint job.
Tailormade Decals, the star's and bars are masks. Tricky to apply, but work well as you can see. Took us the whole day to do the stars and bars it was a three stage process.
Ralf at Tailomade does a great job if you need the masks.
Old 09-21-2011, 04:50 AM
  #1169
ram3500-RCU
My Feedback: (221)
ORIGINAL: JamF4U
ORIGINAL: luckyb001
I'm doing the same scheme on mine. Just can't decide if the red outline is correct as done on many of these. In Sept. of 1943, the standards changed and they omitted the red outline. These guys flew from Oct. to I think Feb. of 1944. The VF-17 started with new planes that probably had the red, but was it painted over when the standard changed, by the time they went into action? Very hard to tell from black and white pictures. I've seen artists renditions both ways.
Old 09-21-2011, 07:17 AM
  #1170
samparfitt
My Feedback: (43)
What an IDIOT!
I broke my oil fluid bag for the hydraulic system.
There was a 4" air bubble going to the pump so I used the kit supplied syringe to put more oil into the fluid bag and it worked great.
Only, when I tested it the second time, there was a small air bubble in the fluid bag and got back into the line leading to the pump.
I thought that if I squeezed the bag, it would force the fluid into the pump: WRONG!: the edge seal between the two pieces that make up the bag, broke.
I emailed MTH in Austria, who provides the bags.
I ordered one back in 2010, wish that I would have bought two!
ID:	1665073   Click image for larger version
Old 09-21-2011, 08:31 AM
  #1171
vfrank59
What an IDIOT!
There was a 4'' air bubble going to the pump so I used the kit supplied syringe to put more oil into the fluid bag and it worked great.
I had a pin hole in my bag and tried to get a new bag from comp arf with no luck. My solution was to find an IV medical bag. Fat chance of that, as we tried several medical stores and they would not sell us one! So, Me and my buddy, went to a local fire dept. and explained the situation. They gave us a Saline bag! We dumped the saline out and flushed it with oil and it has been working great!
Vern
Old 09-21-2011, 01:23 PM
  #1172
ram3500-RCU
My Feedback: (221)
What an IDIOT!
Don't feel like the Lone Ranger. We are on #2 as well.
Old 09-22-2011, 05:38 AM
  #1173
samparfitt
My Feedback: (43)
Gary,
thanks for the tip for getting the fluid bag from US dealers (they didn't stock them last year: must be a 'need' for them!).
All FIXED!
I used my old fluid bag.
Initially, the bag had some grey matter in it but I must have cleaned it out after I got the replacement back in 2010.
Anyway, I installed it and filled it with baby oil.
There are now two extra tubes going to the fluid bag.
The input tube (top yellow tube in picture) is for putting baby oil into the fluid bag.
The second one (bottom yellow tube in picture) was added, with a T fitting, just before going into the pump: this allows me to remove air from the tube that goes from the fluid bag to the pump. I was having trouble removing the air in this area, hence, the broken fluid bag!
Now I connect an extension tube to the bottom tube and leave it open so fluid/air can go into a jar. As I fill up the fluid bag, the air goes out the second tube as the fluid bag fills up. There was about a 3/4" bubble left but I rotated the fluid bag so the air bubble was at the end of the tube going to the pump and I was able to remove the last remaining air from the system. This works out well as, before, I always had a small bubble left in the bag, which, could move and get into the pump line and render the system, inoperative. After the bag is free of air, I remove the extension tube and cap off the short tube connected to the T.
I still have to put the wings on to give the system the 'real' test.
2nd picture:
When the bag broke, baby oil got on the left side of the wing: I used 409 to remove it but all it did, was make a nice, even shinny surface on the wing. Hopefully, dust will get it dull, again!
ID:	1665319   Click image for larger version
Old 09-22-2011, 06:03 AM
  #1174
vfrank59
What US dealer has the fluid bags?
Old 09-22-2011, 07:01 AM
  #1175
samparfitt
My Feedback: (43)
Andy Kane:
[email protected]
