Meister 1/5 scale P-47
#1052
My Feedback: (221)
RE: Meister 1/5 scale P-47
ORIGINAL: balistc1000
Hopeful all goes well!
#1055
My Feedback: (221)
I was delighted to have the postman bring me the nicely packed and insured box from Down & Locked today. I finally got my first look at their handy work, and I must say, it looks very good. Here is the newly converted gear, and their sequencer with a handy hand held programmer.
#1058
My Feedback: (221)
This is their sequencer with it's nice hand held programmer and instructions.
You may notice that the circuit board has shifted in it's case. This is explained in the instructions. They have mounted it in dialectic foam for shock and vibration resistance. It is easy to reposition if need be.
We will get this all installed and post some video of it in operation ASAP.
Also, We will have all this at Toledo for those who may want to see this first hand, and can attend that show.
#1059
My Feedback: (221)
ORIGINAL: Icemanjr92
Set us up a video Gary!
Looking forward to seeing them in action at Top Gun. Time will test the product and so will the Top Gun crosswinds!
BTW, these gear are the first to come with a new, more powerful motor (this shortens the cycle speed). Down & Locked has been wanting to use it but availability was an issue. They have that solved and we are the first to get it. Also included with this gear are the new coated screw jacks. These have a backed on coating for wear resistance that eliminates the need for periodic user applied lubrication. Maintenance free is very nice, plus, the operation is virtually friction free.
#1061
My Feedback: (158)
ORIGINAL: ram3500-RCU
There are guys who install there skis (not on their war birds) and go fly anyway, with their backs up to the burn barrel for heat. I've never been one of those guys.
ORIGINAL: 77chickenhawk
cant fly in that crapp.....yukk?
good times
p.s.
Glad the Little Future warbird Pilot is OK
#1062
My Feedback: (221)
ORIGINAL: scale only 4 me
We had a great time last mnth out in Grafton,, you should have been there, getting stuck inthe snow, flying off Ice.. Good Chili,, touch and go landing while missing a ski
good times
p.s.
good times
p.s.
BTW, what happened to the war bird event coverage. Didn't see anything posted.
Thanks for thinking of the little guy. He is doing great now.
#1063
My Feedback: (221)
Update on the gear. IT WORKS!!!! However, seems they programed it for a P-51 instead of the P-47 (inner door closes after the mains come down). A simple phone call to Mitch, and a properly programmed sequencer is on the way. We will send this one back. I may get some video before pulling it. We'll see.
#1064
My Feedback: (158)
I'm happy for you guys out there. Would like to see video of the touch and go though.
good times
p.s.
good times
p.s.
The Club Pres bought a fancy new Vid camera,, you'll have to bring Voodoo out again ;-)
#1068
My Feedback: (221)
Here is a video of the newly converted gear in action. The P-51 configuration will be corrected.
www.youtube.com/watch?v=taAHK-F51jA
We are using Hitec digital servos on the doors, and have them programmed to 10% speed.
#1069
My Feedback: (221)
I also succumb to my obsessing over the dummy engine, and installed the lower cylinder for static display. It is retained with Velcro, and can easily be popped out leaving behind it's silhouette and exposing the fins of the gas engine behind, to allow greater cooling when flying.
#1071
My Feedback: (16)
NY
Hi Gary it's great both the gear and the addition of the cylendar. If you had not mentioned it I don't think anyone would be able to tell the differance. Do you remember what digital servos you used on the gear doors? . Starting a list of things to get for mine so It will be helpfull to know what servos to get. thanks John T.
#1072
My Feedback: (35)
LA
Gary,
Your retracts sound exactly like the ones I had installed in a pattern plane. When the motors were running to "retract" the gear, they were struggling, just like yours. Not good. They will go out. First they will get to where they'll barely lift the legs. Then, they'll get to where they won't lift the legs at all. Just a warning.
Not bashing what you're trying because I've been there just like you. My bet is that you'll be going back to air. Nobody has come out with a motor that is compact, yet strong/durable enough to stand up to the weight they have to lift. Maybe one day they'll get it right. Til then, good luck.
#1073
My Feedback: (221)
ORIGINAL: yard-dart
Gary,
Your retracts sound exactly like the ones I had installed in a pattern plane. When the motors were running to ''retract'' the gear, they were struggling, just like yours. Not good. They will go out. First they will get to where they'll barely lift the legs. Then, they'll get to where they won't lift the legs at all. Just a warning.
Gary,
Time will tell, but I am pumped about the prospect of eliminating the problematic air systems we have dealt with for decades.
I will continue to keep you guys abreast of our experiences with this new system.
#1074
My Feedback: (221)
ORIGINAL: John Taylor
