TFGE F4U Corsair 60 Kit Build
Bradly: I to wish you good luck on your test flights. Nothing new with my plane just waiting for some warm temps to paint with out the heat on in the shop. It will happen soon I hope, then probably two week of work and i hope to maiden in June if all goes well
here is a couple of pictures from the past weekend
Thanks for the kind comments, I'm looking forward to my maiden and as usual I'll probably have butterflies for the first 5 minutes or until I'm satisfied my corsair is flying fine. What I realy want to do is mount firepowers pylons then sling those 500 Lbs bombs and drop them over the field, to bad I won't have a zero to practice my dive bombing on. By the way Tracey, your Corsair is still looking great, post some pics when the paint job is done! By the way any one watching Bob Moore build his F-105 Thunderchief, myself and two other guy's won the paint the Thunderchief contest, I got the hat with checkerboard flames.
I can't wait to see some new pictures! Keep up the good work!
Yes tower has reversed servo's for sale all you need is to specify your brand. Another option is to buy two standard servo's and a reversing Y-harness. Finaly purchase a match box and tie your flaps into it, as usual these are only recomendations, you need to decide what fits your budgit. As for an engine, the max I would put into any 60 size bird is a .91 2S or 1.2 4S except for a spitfire.
Richard,
I'll heed your advice and have some spot the bomb drop, I'll keep my eye's on the bird.
and is a match box a servo sincronizer
i think the os 1.2 fs is nice would you recomend the pump/turbo/blower i see on some or are they overly complicated for performance gain
ours is comming together many thanks pics comming soon
john
I'm also happy to report my retracts system work flawlessly to include my gear doors, not a single door got ripped off, two thumbs up. From now on I'm going to lower my gear atleast one full cuircut before attempting to land. With my gear being sequenced, it takes a good 10 seconds from selecting gear down to the gear actually going down and locking down.
Damage report
1. Verticle stab snapped off at the base with no other damage, verticle stab is now repaired, just need to apply new fiberglass and repaint.
2. Right elevator was tweeked, the left and right were off set from each other, so I cut into the right elevator re-tweeked the rod and packed the elevator and rod with 30 min epoxy and let dry. Need to sand and touch up paint
3. Landing gear, right main twisted 90 degree's, have sent e-mail to Darrell at Sierra giant scale to find out the cost for a set of front plates with grooves for my retracts.
Take care!
my name is asaf and i am from israel
just stared tobuild the kit and i have a question :
I have a question for users who built the kit in the past
I am currently on page 20 section 14
Should be a gap like you see in the picture ?
[link=http://www.rcuniverse.com/forum/m_10755885/anchors_10756219/mpage_1/key_/anchor/tm.htm#10756219]Please Follow my build log [/link]
As to your question, yes there is suppose to be a gap. The stab base support has to be flat on the building board then glue'd to F9 and F10 to include the side formers. To achieve you will need to trim F9 and F10 until you have each support flat. F10 will have a gap, that's for the elevator control linkage and push rod. The center stringers will be cut off flush with F10 later in the build, If you have any further questions please feel free to ask.
Hi, great buy, the TFGE Corsair kit is a nice sport scale kit to build and fly. As for your choice of power plants the OS 91 FS surpass engine will provide plenty of power, just be carefull to build light. You are more than welcome to post your build progress to include any build pics, and if you have any questions please feel free to ask.
Brad
Good becauseI was worried that the 91 wouldn'thave enoughumphwith the extra weight of glass and paint. I'm worried about doing the flaps though,it looks complicated and never done flaps. I'm sure i'll have lots of questions and stillteetering on weather to go really scale on it, Never did that either..lol
Alan
Hello Bradley:
My name is Everett.
Been following your TFGE 60 Corsair build for several months now. I only today signed up with this forum. You have great talent and skills and I hope to plagiarize your build data.
I've owned my TFGE 60 Corsair since 1994. Been traveling too much to finish it, though.
However, now that I'm retired from aircraft technical writing, I started back on this model and also a Great Planes Cub 40 size in order to finish both of them.
I want to finish the Cub first in order to hone my flying skills.
I ordered Robart retracts, oleos, and an air kit shortly after purchasing the Corsair.
After following your thread, I got keenly interested in the double-sided circuit board tail wheel build. So I built one and am ready to lay it into the aft fuselage where I just tore out the standard TF fixed steerable tail wheel.
I understand how you attached the tail retract assembly into the fuselage to the former and how you added the air actuator.
However, even though I scouted your build many times, I cannot wrap my brain around how you integrated the rudder servo linkage that goes to the rudder with the pull-pull cable assembly for the tailwheel steering. I purchased a Sullivan #521 pull-pull kit to connect to the tailwheel steering arm.
Question: Do you have any other photos of the rudder linkage where it integrates with the pull-pull linkage? A picture or two will save a bunch of words.
Everett
Hi, what I had done was to use a standard pull pull system with two push rod clevas and 4/40 extended brass coupling which had a small hole drilled into the brass to allow the cable through, then clamped with a small brass tube. I used some small flexable tube cut into small sections placing them into each former, since the flex tube was small enough for the cable to run through as a cable guide. The double sided control arm I used along with a futaba 3004 servo; I attached the pull pull systen to the second hole where the control cable for my rudder went into hole number 4. Here are some pics and ask as many questions you want
Congratulations on your kit. Looks as though you're wasting no time getting going.
I've been working on my TFGE Corsair 60 since 1994. See post 294 above as to why I haven't finished yet.
Short answer to LG rails. No.
Long answer: My experience with Robart retracts would have been better had I dry attached my rails to the Robart retract rail flanges first, then fitted them to the ribs as an assembly. Robart retracts easily bind if the geometry between the two companion rails is off.
I thought that I installed the rails first as close to the instructions as possible. After I epoxied the rails, I then installed my retracts. I had to play with the retracts quite a bit for them to swing without friction. I attribute the friction to LG rail mis-alignment.
I have seen a post that talks about the rails, but I cannot locate it at this time. I can get back to you when I find it.
Other members. please chime in with your experiences on this matter.
Everett
