Reload this Page >
ESM LA-7 From VQ Warbirds
Old 05-10-2011, 10:52 AM
  #251
fw190
My Feedback: (37)
Default RE: ESM LA-7 From VQ Warbirds
I also ditched the pull pull hardware and used two elevator push rods to each half and pull pull on the rudder. I know for sure push rods wont slack over time.
Old 05-10-2011, 10:06 PM
  #252
pilotorc4
pilotorc4's Avatar
I need help finding pictures of soviet pilots during WWII, I have an LA-7 and have purchased a cockpit kit from Ty and plan on using a 12" pilot figure on it but I have not been able to find any pictures of soviet pilots and the equipment they used in order to build a pilot that would closely resemble a soviet.
I have already started to put one together using parts that I have found on several sites unfortunatelly my search for fotographs have yielded no result as to the color of the uniforms, type of oxygen mask used and type of parachute harness used.
So far I'm very pleased with the results but still want to make it as accurate as posible even if I have to scratch built some of it as I did for one of my japanese pilots.
If any of you are interested in seeing what I have come up with so far I will post some pictures later.
Thanks.
Old 05-18-2011, 12:00 PM
  #253
stoat
stoat's Avatar
Pilot - yep post some pics. Will be going down this road soon myself. Cheers. Brett.
Old 05-19-2011, 06:23 AM
  #254
pilotorc4
pilotorc4's Avatar
Stoat, this is what I had come up with so far but since then I have finally come across fotos of soviet pilots from that era.
the parachute I was using is a british one and is wrong, the soviet parachute I have seen in the fotos are more like the ones the US Navy used in those days, the flying cap is also diferent ( the helmet used looked more like the IJN helmet) the way the pilot uniform looks right now resembles more the fotos of female soviet pilots. I have been ordering accesories as I find them and as soon as everything is here I'll post some pics.
ID:	1611209   Click image for larger version
ID:	1611210   Click image for larger version
Old 05-19-2011, 06:27 AM
  #255
pilotorc4
pilotorc4's Avatar
more pics
ID:	1611214   Click image for larger version
ID:	1611215   Click image for larger version
Old 06-15-2011, 03:17 AM
  #256
miklos
My Feedback: (38)
miklos's Avatar
Here's some pics of my LA-7 with a little weathering. Engine is a Saito 220 four stroke and stock gear.
ID:	1623572   Click image for larger version
ID:	1623573   Click image for larger version
Old 06-15-2011, 07:32 AM
  #257
jmohn
The LA-7 has a lot of positive incidence in the wings and I recommend you add some down thrust to the engine (2 degrees or so). If you check you wings you will see that they are 5-6 positive. Both myself and another guy in our club have this plane and have done this and it flies much better now.
Jeff
Old 06-26-2011, 03:09 AM
  #258
Aitzolius
Hi everybody!
I am going to buy one of this beautiful WWII soviet fighter, and I am asking if the zenoah 26 that I have will have power to fly this one or shall I buy a greater engine? I just see the the saito FG-30 and FG-36 are bit large. Wicht one must I put, from the JC28cc until a 5occ gasser?
Thank you very much for your help and time!
Best regards,
Aitzol.
Old 06-26-2011, 11:19 AM
  #259
rchobbydood
The JC 28 is a great match with this airframe. The new jc30cc is out and is about 500 rpm more powerful with the same prop.
I flew one with a 50cc in it and it felt heavy in comparison
Steve
Old 06-27-2011, 10:01 AM
  #260
Chris Nicastro
Chris Nicastro's Avatar
What ever happened to the guy with the Saito 325R5 radial installed in this plane? From Australia I think...
Have you guys added nose weight in addition to the gas engine? If so how much weight and which engine are you using?
Old 06-27-2011, 01:34 PM
  #261
LA7flier
ORIGINAL: jmohn
Jeff
I agree. I am on my second LA7 and both required downthrust shimming...not surprising since they all come out of the same mold...on a different note, I am changing out my batteries from A123 to lipo's....the experiment proved that as cool as the A123 battery technology is...the capacity simply isn't enough for this airplane. I will go with a 6S2P 5000 maH. I have looked at the plane and decided that I can cut a large hatch along the established lines in front of the canopy to facilitate easy replacement of the lipo's
Old 06-27-2011, 01:52 PM
  #262
AZThud
I have one of these that I have just started, I fly electric and would be very interested in any ideas involving the creation of a battery hatch. I have an Eflite P-160 and have batteries for a 10S or 12S config, I also have a Castle ICE 120 HV controller. With my other planes, ESM Frank and H9 HellCat I opted to remove the wing to get at the batteries. As I have converted my ESM gear to electric actuators wing removal is not that much of a hardship, but a hatch is much more convienient. Anyway good luck and again any advice would be appreciated.
Cheers
Old 06-27-2011, 02:30 PM
  #263
Chad Veich
My Feedback: (60)
ORIGINAL: AZThud
Cheers
Love to see the LA-7 or your other electric warbirds perform AZThud. Might I ask where you fly? (I too live in Litchfield Park) I am relatively new to electric and still have much to learn. I have a 1/8 scale Hellcat that I am strongly considering converting if I, like you, can figure out the battery hatch dilemma.
Old 06-28-2011, 07:41 AM
  #264
AZThud
I fly at AMPS, looks like we did not hook up at the One Eighth in the fall, for that event I had my BH T-28 120 on 10S (now running it on 10 and 12s)and my H9 HellCat. The Frank was in the shop, it is in the final stages of being repainted and will be flying again this weekend. The LA-7 is pretty much still in the box, I am starting with the installation of the cockpit from Ty's Planes.
Cheers
Old 06-28-2011, 09:38 AM
  #265
Chad Veich
My Feedback: (60)
ORIGINAL: AZThud
I was at the OEAF event on Saturday AZThud, sorry I missed you. AMPS is a long way to drive. If you need some place closer once in a while you might consider coming by the Aux. 6 field. Not the world's best flying site (understatement) but serviceable and not too far away. (Yuma and Airport Rd. right on the outskirts of Buckeye.) I've got a KMP Bearcat sitting in the box that I had not considered for electric but that may change if things work out well in the Hellcat. Look forward to meeting up some time and good luck with the Lavochkin.
Old 07-04-2011, 05:17 PM
  #266
stoat
stoat's Avatar
ORIGINAL: Chris Nicastro
There was a guy I know here in New Zealand (south south Australia......) with a 325R5 installed. Unfortunately it suffered a hard landing on it maiden (stalled and went in nose first) and I gather the motor is now stuffed. I heared he will be trying it with a Turnigy 30cc motor next. There is a video on youtube somewhere, from memory with the username Rcbanditnz.
PilotC4 - the pilot looks great. Will have to find one for mine. Picked up a Cotswould Collectables American pilot for the Corsair and it is impressive. Hopefully they will have something to suit.
Old 07-04-2011, 08:15 PM
  #267
pilotorc4
pilotorc4's Avatar
Stoat,
I'm working on a second one and still waiting on accesories for both, I'm trying to make it as close to the russian flight gear for that period as possible. I will post some pictures as soon as I finish it, ordered a bunch of new things for them but have not received it yet
Old 07-05-2011, 04:05 PM
  #268
stoat
stoat's Avatar
Trolled the interweb last night for hours. Cannot find any decent russian pilots in 1/6 scale. Pilotrc4, where are you ordering bits from? Might be able to mod a russian infantryman.
Old 07-05-2011, 08:41 PM
  #269
pilotorc4
pilotorc4's Avatar
Stoat, unfortunately no one makes rusian pilots in 1/6 scale.
I'm using the closest things comercialy available to try and imitate one.
this is what I have used so far.
FLYING HELMET - IJN WITH SOME MODIFICATIONS.
PARACHUTE - WWII US NAVY
BOOTS - WWII GERMAN
LEATHER JACKET- SEARCH ON E-BAY FOR 1/6 LEATHER JACKET.
UNIFORM - FOUND A 1/6 MIG PILOT (CHINESE FROM KOREAN WAR)
BELT- WWII GERMAN BELT
GUN AND HOLSTER - WWII RUSIAN INFANTRY.
I'm still finding things that would work and modifing to look like the ones used by the Rusians.
Old 07-05-2011, 08:44 PM
  #270
pilotorc4
pilotorc4's Avatar
here are the fotographs I'm going by.
ID:	1632018   Click image for larger version
ID:	1632019   Click image for larger version
ID:	1632020   Click image for larger version
ID:	1632021   Click image for larger version
Old 07-05-2011, 08:47 PM
  #271
pilotorc4
pilotorc4's Avatar
here are color re-enactments of the same fotos
ID:	1632025   Click image for larger version
ID:	1632026   Click image for larger version
ID:	1632027   Click image for larger version
ID:	1632028   Click image for larger version
Old 07-05-2011, 11:00 PM
  #272
stoat
stoat's Avatar
Cool, so sort of a cross between US and German flight gear. Thanks for the photos.
It appears the Russians had a fair number of female combat pilots - something the US and Poms didn't figure out till many years later on. I'm always amazed at the associated facts and knowledge you pick up doing this hobby, especially if you do some research into the subject you are modeling!
Got one of these for my Corsair - http://ep.yimg.com/ca/I/yhst-9451123..._2162_28843193
The parachute and head gear look close enough. Will just have to find that flight suit. Thought this my be close - http://ep.yimg.com/ca/I/yhst-9451123..._2164_13021313
Cheers
Brett
Old 07-05-2011, 11:26 PM
  #273
stoat
stoat's Avatar
Found this ...
http://www.fanasix.com/en/action-fig...-w-ii/russian/
Old 07-06-2011, 01:22 PM
  #274
Aitzolius
Hi, people!
I just received this warplane that I finally go with an DLE-30 V2. In the near future look like that you can go with electric retracts for any bird of ESM. The retract that you can see in the picture is from the P-47.
Looking to a pilot and of course to the cockpit.
Best regards,
Aitzol.
Old 07-08-2011, 02:51 PM
  #275
stoat
stoat's Avatar
This.....
[youtube]http://www.youtube.com/watch?v=FcQz2S2jAT8&feature=related[/youtube]
Then this....
[youtube]http://www.youtube.com/watch?v=vulADf7CNAQ&feature=related[/youtube]
Very sad. I gather the airframe has been fixed. Not sure about the motor.
