Reload this Page >
ESM LA-7 From VQ Warbirds
Old 04-24-2014, 10:17 PM
  #776
n8622t
My Feedback: (8)
That tailwheel looks great but.... I'm with you on the mounting it needs something
Old 04-24-2014, 10:38 PM
  #777
n8622t
My Feedback: (8)
Prekin your spinner is awesome but what did you use for a back plate?
Old 04-25-2014, 04:12 AM
  #778
Prekin
My Feedback: (19)
Prekin's Avatar
As a back plate I used some aluminium plate from spinner which you can buy. You can see the kind of spinner in the picture.
Old 04-25-2014, 05:32 AM
  #779
Joespeeder
Hey Guys,
I picked up on of these for my LA-7 http://www.skysharkrc.com/item/ME109G-Scale-Spinner-103
Joe
Old 04-25-2014, 09:30 AM
  #780
Prekin
My Feedback: (19)
Prekin's Avatar
It sounds like a barbarism to use a spinner from Bf-109 on La-7 or some another Soviet aircraft..
Old 04-25-2014, 09:35 AM
  #781
Joespeeder
Hi Perkins,
lol... yea, my LA-7 is painted in captured colors and the spinner was close enough and once painted to match the yellow nose it'll look great !!
Joe
Old 04-25-2014, 09:44 AM
  #782
Prekin
My Feedback: (19)
Prekin's Avatar
Joe, I followed your intersting project, but I can´t see any shot of completed airplane. Could you show some picture please?
Old 04-25-2014, 09:50 AM
  #783
Joespeeder
Hi Prekin,
I will be maidening it in a few weeks.... The weather is just getting back to flying weather here and the LA-7 will fly soon. I have a DR-1 and a Pfalz to maiden plus a couple others to re-maiden after some changes.... All in all about 6 new projects to tune and test this spring !!
I promise I'll post photos of the LA-7 as soon as I can.
Joe
Old 04-25-2014, 09:54 AM
  #784
Prekin
My Feedback: (19)
Prekin's Avatar
6 new projects???!! How do you do it? It looks like you are without a job and your day has more than 24 hours!
Old 04-25-2014, 09:55 AM
  #785
Prekin
My Feedback: (19)
Prekin's Avatar
I´m looking forward to some picture of your La-7.
Old 05-27-2014, 05:07 PM
  #786
n8622t
My Feedback: (8)
Joe yer spinner looks pretty good....Prekin what diameter is your backplate?
Old 05-28-2014, 06:50 AM
  #787
Prekin
My Feedback: (19)
Prekin's Avatar
I´ll write you the diameter in the friday evening. But I found some pictures and compared the diameter of the spinner and space for the engine.
Old 05-29-2014, 12:21 AM
  #788
n8622t
My Feedback: (8)
That's great! Look forward to seeing that and thanks
Old 05-30-2014, 10:47 AM
  #789
Prekin
My Feedback: (19)
Prekin's Avatar
Now is Friday evening, so I´m typing. The diameter of the backplate is 105 mm.
Old 06-01-2014, 11:45 PM
  #790
n8622t
My Feedback: (8)
Thanks Prekin I have a spinner I will measure to see if I can use the backplate
Old 06-02-2014, 07:05 AM
  #791
Prekin
My Feedback: (19)
Prekin's Avatar
You´re welcome.
Old 07-12-2014, 07:03 PM
  #792
Lerch32
Anyone have retracts they want to sell for the pa-7?
Old 07-14-2014, 06:17 PM
  #793
djmoose
My LA-7 is officially ready to maiden.
The new G38 has been a handfull. First the magneto/flywheel gap was too big, then the black carb insulator was cracked and was causing tuning problems. Now everything is tightened up and ready to go.
I also thought you guys would like to see my landing gear plate I made so the LA-7 can sit in my trailer a little easier.
ID:	2014265   Click image for larger version
ID:	2014266   Click image for larger version
ID:	2014267   Click image for larger version
ID:	2014268   Click image for larger version
Name:	board installed.JPG
Old 07-16-2014, 10:50 AM
  #794
miklos
My Feedback: (38)
miklos's Avatar
OK... that is not finished..... Ya gotta skuff it up a bit. Make it look like it's been in the war like this..
Believe it or not, that's just some number 2 pencil lead rubbed into the covering and panel lines....
ID:	2014755   Click image for larger version
Old 07-16-2014, 04:58 PM
  #795
djmoose
That will all happen after it flies and I get it dialed in.
Old 07-16-2014, 06:03 PM
  #796
n8622t
My Feedback: (8)
Miklos you did a real nice job of weathering that airframe....I'd like to see what yer fingers look like
Old 10-13-2014, 06:34 PM
  #797
radfordc
My Feedback: (14)
radfordc's Avatar
Look what showed up on my doorstep today! UPS tried their best to break it, but everything inside is in good shape. This one will have an XYZ 53 and HK electric tailwheel and mains.
Old 10-13-2014, 08:16 PM
  #798
rcfan450
Heck ya Radfordc! I love the xyz 53 in mine. That motor rips and has run like a dream (since I had the ignition replaced). Just make sure you give the motor some right thrust, 1 degree of down thrust on the horizontal stabs, and whatever else has been mentioned in this forum. I didn't do those things cause I thought I would be ok without doing it. Nope. 3 crashes later I made all the adjustments (and some airbrushing) and now it flies great. It's a show stopper anywhere you take it!
ID:	2040158   Click image for larger version
Old 10-14-2014, 06:08 AM
  #799
radfordc
My Feedback: (14)
radfordc's Avatar
That smoke looks cool. I've never done a smoker....might have to think about that.
Old 10-16-2014, 08:13 PM
  #800
n8622t
My Feedback: (8)
Thanks for the tailwheel tip radfordc. I ordered two today one for the 190 D the other for the LA7
