Reload this Page >
NEW Top Flight P-40??? 1/5 scale
Old 07-02-2011, 12:49 PM
  #676
BirdofpraY
My Feedback: (31)
Default RE: NEW Top Flight P-40??? 1/5 scale
Thanks guys, I think it took me more time to decal, paneline, airbrush and clearcoat than it did to assemble airplane.
Capt G. I place the ignition switch just as permanual and the receiver switch under the cowling in front of the wing area. Ignition switch is camo well with some weathering.
Oh I did not need any ballast to balance out the plane.
Old 07-02-2011, 04:04 PM
  #677
damagedgoodes
G'day Dave,
Nice weathering on the P-40, what pilot did you use please? Also I'd like to know if you and any other modellers could tell me what your finished weight (less fuel) is please? Cheers,
Dave
Old 07-02-2011, 05:21 PM
  #678
BirdofpraY
My Feedback: (31)
the pilot I used was "Ben Cole" fullfigure pilot which I believe Dragon pilots make it. If I can remember the bird came out right at 24lbs.
http://cgi.ebay.com/RETIRED-BEN-COLE...item5643c00108
Old 07-02-2011, 11:49 PM
  #679
Kostas1
Kostas1's Avatar
Awesome....do you have a video too;
Old 07-03-2011, 12:57 PM
  #680
BirdofpraY
My Feedback: (31)
I got some video of the flight today but my wife was having a hard time following the right bird. lol here is a pic of it flying before I weathered it. I have to upload the video to youtube then I will post link here.
Old 07-03-2011, 03:47 PM
  #681
Desertlakesflying
My Feedback: (28)
Just saw one of these fly today with an Evolution 40GX and a 20X10 3 blade. It was sweeeeeeet!
Old 07-03-2011, 07:12 PM
  #682
BirdofpraY
My Feedback: (31)
the flight was going good until the two top bolts came of the engine.
[link=http://www.youtube.com/watch?v=IrIHyasc5qI]P-40 Flight[/link]
Old 07-14-2011, 07:27 PM
  #683
Desertlakesflying
My Feedback: (28)
Must be a good flying plane if this was on the maiden flight.
Old 07-15-2011, 02:31 PM
  #684
propchief
My Feedback: (65)
It is a very good flying airplane. On my maidnen I was doing some IMAC to the teasing of the other pilots at the field. It really hold a line well!
Old 07-15-2011, 05:54 PM
  #685
Maxclimb
My Feedback: (61)
Are you using all of the set up instructions i.e. CG and control throws?
Old 07-15-2011, 06:28 PM
  #686
propchief
My Feedback: (65)
I'm using the CG as per plans and the high rate on the surfaces with about 25% expo. I'm comfortable with this set-up for smooth but positive control response and still stable enough to fly a long low straight line.
Old 07-15-2011, 07:19 PM
  #687
Desertlakesflying
My Feedback: (28)
ORIGINAL: propchief
+1 here
Old 07-16-2011, 04:51 PM
  #688
Maxclimb
My Feedback: (61)
Thanks Guys!
Old 07-16-2011, 05:13 PM
  #689
Maxclimb
My Feedback: (61)
So I just opened the box from the big mail order place and took out the recommended retarcts for my P-40. Is it just me or does anybody else think these things are poorly designed and made? The after thought uplock is a joke and I don't know how it will function properly. Has anyone sucessfully installed Sierra Giant gear into this model and if so how much modification must be done to the wing?
Old 07-17-2011, 07:28 AM
  #690
92ARed1
During a preflight (after having flown the model a dozen times or so) one of the "uplocks" stuck and prevented the gear from coming down. Rather than troubleshoot them Isimply disabled both - that feature is not worth the risk of the gear not operating in flight. I would suggest taking a careful look at it.
Old 07-17-2011, 10:26 AM
  #691
dasintex
My Feedback: (10)
dasintex's Avatar
ORIGINAL: Maxclimb
So I just opened the box from the big mail order place and took out the recommended retarcts for my P-40. Is it just me or does anybody else think these things are poorly designed, poorly made junk? Not only that but they don't finish any of the edges and there are places to cut your hands on them. The after thought uplock is a joke and I don't know how it will function properly. Has anyone sucessfully installed Sierra Giant gear into this model and if so how much modification must be done to the wing?
What Retracts are you talking about? Sierra?
Old 07-17-2011, 10:30 AM
  #692
dasintex
My Feedback: (10)
dasintex's Avatar
ORIGINAL: 92ARed1
During a preflight (after having flown the model a dozen times or so) one of the ''uplocks'' stuck and prevented the gear from coming down. Rather than troubleshoot them I simply disabled both - that feature is not worth the risk of the gear not operating in flight. I would suggest taking a careful look at it.
Are you using Robarts retracts? 'Up Locks' you talking about those small 'Latches/Hooks' that lock the gear in place when retracted, if so, I was having trouble with them when I was putting the wing together and bench testing them, I ground some of the inside of the hook down a bit and them seem to work now without any problems.
Old 07-17-2011, 10:47 AM
  #693
92ARed1
Yes to both questions.  The small latches worked well until they didn't .
Old 07-17-2011, 04:32 PM
  #694
propchief
My Feedback: (65)
I had to sand a small groove for the up locking mechanism to move freely. Also did some very minor shimming on one side if the gear mounts on one of the gear to make sure it centered in the wheel well. No problems with the locks either up or down.
Old 07-17-2011, 05:09 PM
  #695
Maxclimb
My Feedback: (61)
Thanks again for the inputs. Another question: are you guys slowing the gear down and sequencing them (scale like) operation? I wondered if that will have an effect on positive locking up/down?
Old 07-17-2011, 06:15 PM
  #696
propchief
My Feedback: (65)
I slowed both up and down sequence. Not so slow as to be scale, but enough to keep them from slamming either direction ... about 1.5 to 2 seconds either way.
Old 07-27-2011, 04:35 PM
  #697
Maxclimb
My Feedback: (61)
The kit and all of the accessories arrived from Tower. The box looks good, no damage in shipping. However there is a ding on the fuse right on top of the nose just aft of the cowl. Some kind of impact damge that cracked the sheeting. Tower quickly sent a replacement. This was left at the front door by the shipper we all know (the one that loves Brown) and the box looked like it was in a fight! There was a large hole punched through one of the FRAGILE stickers and other wrinkles in the box. The only damage to the fuse was at the corner of the wing/ fuse fillet. The balsa is chipped and Monocote torn. So I will decide which of the two I want to fix and send the other back. Overall Top Flite has really done a great job on this ARF. As expected there are some wrinkles in the covering but I will be able to get it shrunk down. I was suprised to see a decent instrument panel, not just a decal. As previously mentioned I bought the Robarts and will use them as well as the DLE 55. Just like everyone else I wish we could get a 3 bladed spinner/prop combination.
Old 07-29-2011, 08:18 PM
  #698
kochj
Bolts loosening on muffler...
Have you considered trying different HIGH quality bolts??
Some of the China bolts are horrible...
And sometimes the American metric size can differ from the rest of the NORMAL "metric" world....
I would pick up some run of mull lock nuts.... They bite VERY well in ALum....
I remember when evolution engines had the same issue with there 45gx engine, and the Evolution muffler bolts....
The would keep loosening, untill a replacent set was used, and you guessed it,,, NO more loosening.. Problem solved..
Keep us informed...
Old 07-31-2011, 07:54 AM
  #699
ace1726
Another great day of flying in Fl... This is around the 30th flight for me with the P40. I think it's time for a pilot, just doesn't look right. right???
ID:	1642359   Click image for larger version
Old 07-31-2011, 05:08 PM
  #700
Maxclimb
My Feedback: (61)
Looks like a great flying site. Which one do you use? I lived in Orlando for some time at a place called RC World where we had a fantastic field. I am in WA state now and really miss the long flying season there in FL. I hope to retire and move back some day. Be sure to stop into Bob's Hobby Center and say hello to Steve Thomas. It is the best shop in Central FL and Steve is very helpful.
Regards,
Mike
