NEW Top Flight P-40??? 1/5 scale
#780
My Feedback: (65)
NC
RE: NEW Top Flight P-40??? 1/5 scale
The stock tank would be plenty for a DA60. Plus, the DA60 is such a beast of an engine I doubt that you will be flying the bird at full throttle all that much ... very powerful!!
#786
My Feedback: (65)
NC
ORIGINAL: n8622t
Thanks Pro....are you running this combo as well?
#788
My Feedback: (8)
I got a late start today and didnt accomplish as much as I had desired...BUT, I did get the choke and throttle linkages completed and the holes drilled for the carb line and ignition spark cap Tomorrow I will try to get the engine completely installed and begin cutting the cowl for mounting to the fuse
#790
My Feedback: (8)
Ok, got the cowl rough mounted and discovered the muffler pipes wont even make it out of the cowl[X(] I also found one of the header bolts will crush the header if tightened too much. This is the Jtec muffler for the DA60 made to fit the TF P-40. The Jtec that went on my AW P-51 had the same problem but I have a fix for it to accomplish tomorrow...Il post pic Here she is SNARLING!!!
#792
My Feedback: (65)
NC
ORIGINAL: n8622t
Hey Pro, any issue with the muffler getting loose like the 50 will sometimes do?
#798
My Feedback: (8)
Hey Lifer...last P-40 we discussed was a Skyshark Give Brad a call at http://www.badbradgraphics.com/index.html
He mainly does 3D birds but fully capable of doing warbirds as well...you just need to talk to him and describe what you want...he has great pricing Tell him Jimmy Davis sent ya What power are you going with on your P-40...you should have it ready in ample time for the next Warbirds over Tulsa. I can see you and me flying sorties with the P-40s[X(]
