Redcat Racing Tornado Thread
#3226
AL
RE: Redcat Racing Tornado Thread
All the spring does is regulate when the arm swings out and engages 2nd gear. If you tighten it all it will do is not swing the arm out. Just order another one, or contact redcat and see if they'll send you a replacement. If your gonna pull the tranny, you might as well wait for a replacement and just change it out while you have the tanny pulled.
#3228
ON, CANADA
hey guys i have a tremor buggy have a throtle problem it like to stick open a little and strugle to get back to its originl posision any ideas
#3231
NJ
yeah they may act a little slow but shouldn't have any effect to where they wouldnt go full left or full right. Have you tried swapping the steering and throttle servo to see if it does the same thing?
#3234
CA
Tremor has a lot smaller servo that the Tornado, If you change it out use the Hitech HS65MG for the steering and the HS65HB for throttle brake.........the truck will be gone before those servos [:-]
#3235
Im looking to upgrade my clutchbell and was wondering if i could use [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=001698082&I=LXBMJ9&P=K]this[/link] instead of [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=001698082&I=LXCLR2&P=K]this[/link]. any help would be appreciated.
#3236
ON, CANADA
hi the servos i have are from a spectrum 2.0 for my tornado but have not used them yet are they ok to put in my tremor buggy?
#3239
Hope you can help I am looking for info on HSP Atomic Warhead 1/10 scale 4wd buggy can any one point me in the right direction .Looking for 2 speed gear not engageing and stripping
Cheers
Cheers
#3241
TX
i got my tornado out after a few months and the pull start would not budge on it. If any one has any ideas on it i sure would apprecaite it.
#3242
First see if you can turn the flywheel by hand. If not then it might be the piston is seized. It's not a huge deal to disassemble & reassemble a nitro engine if you pay attention to how things came apart. Clean everything and see how you go
When you remove the pull start, don't let the spring uncoil or the pull start cord to come out - it's a pain to reassemble.
#3244
Can anyone suggest me a engine torquey enough to do wheelies with the red cat?? someone said a traxxas 3.3 will work but if i could find a powerful enough .18 small block possibly with screw carb that would be cool ....... i just don't think there is a small block strong enough to get a wheelie
#3245
AZ
Well these werent really mean for wheelies, A sh 18 would be an upgrade. then next would be a os crv, then a os 18 tz. but wheelies are over-rated, they are only fun for a while. i would smoke you in a race if we had the same exact car, but you wheelied and i had a wheelie bar
#3247
NJ
How cool would that be if the Traxxas 2.5 or 3.3 can drop right in these bad boys. Has anyone done this or know if it can be done? Thanks, Joe
#3248
ORIGINAL: joeyhatch11
#3249
sweeeet well a new skid/mounting plate is on order along with single speed differential and trx 3.3 engine!! so it'll be an all aluminum build with trx 3.3 and jato suspension with my trx bandit anaconda wheels/tires
#3250
this is a really dumb question but. I just recently melted/stripped my tranny gears, is this becouse i had my brake on during idle?
