Redcat Racing Tsunami Thread
#701
NY
RE: Redcat Racing Tsunami Thread
ORIGINAL: snowcruiser_91
thanks 4 the quick reply ehroof...! ill try that probably tomorrow, but what about the idle set screw...?
And I agree with ehoof, its sounds like the clutch spring is broken. You can bend a new end on it if it is.
#702
ORIGINAL: KeithjV
Got any pics of your MT? Im in the process of hopping up a used MT2 I picked up.
ORIGINAL: ehroof
lol, in small case letters i didnt realize what it was, i have some GPM parts on my hpi mt.
#706
NY
Yep. They use standard 12mm hexes.
These are the wheels Im using http://cgi.ebay.com/HPI-Scorch-6-Spo...713.m153.l1262
and these are the tires
http://cgi.ebay.com/HPI-2-2-Yokohama...713.m153.l1262
#709
NY
Not at all. They are the same size as the stock tires just much more durable. And the foam is stiffer so the tires dont bounce as much
#710
sweet I have the rustler wheels but I was told ther for the electric rustler so the off set is off and I cant use them without wheel extenssions
#714
TN
2.2 rims with the Tsunami arms that are bead locks wont work sad to say, I had to get rid of the ones I have because the arms are to wide
#716
NJ
ORIGINAL: ehroof
Here is a picture of my tsunami:
1. upgrade the clutch bell to this set up: http://www2.towerhobbies.com/cgi-bin...4&I=LXCLR2&P=K + http://www2.towerhobbies.com/cgi-bin...4&I=LXDHM0&P=K + http://www2.towerhobbies.com/cgi-bin...4&I=LXCLR9&P=K
2. upgrade the clutch spring to traxxas #4146x : http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
It seems to me from reading this post that the Tsunami /T. Ultrawide can be upgraded with parts from other manufacturers.
If this is correct, is there a list somewhere which cross matches parts?
#717
NY
Himoto, Redcat, Exceed RC use all the same parts. There are also compatible parts from HPI and Traxxas. Its easier to tell you if there is a specific part you are looking for a compatible replacement for.
#718
NJ
Keith... Thanks... That is good info to know.
Not sure which parts as of yet but when I do I imagine this is the place to come to finds the answers.
The ony part I may have to get outside of Redcat at this time are the front and rear dogbones. I know that Redcat is out of stock and has been for a while.
#719
NY
Anytime Sushi
You can try looking at tri-county or raidentech http://www.raidentech.com
If you run into a problem with a specific part just put a post up. You'll have an answer in no time.
You might be able to use HPI or Traxxas dog bones as long as the length is the same. I havent actually checked mine yet but I will. I have an HPI MT2 as well and a lot of the parts are about the same size.
#720
TN
Redcat does have the dogbones in stock that go to the tires, if them are the dogbones your talking about
http://www.redcatracing.com/itemdeta...p?partno=08029
#721
NJ
ORIGINAL: Macanan
http://www.redcatracing.com/itemdeta...p?partno=17713
