Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Electronics Problem
Old 04-04-2007, 06:43 PM
TannerReagan
Default RE: Electronics Problem
What do you mean the order # where could i find it?????????????????????????[&o]
Old 04-05-2007, 03:25 PM
TannerReagan
Today was a sad day, my beautiful baby isn't so beautiful anymore. Me and some of my friends took it off some ramps. I broke the wing, The 4wd, now its only 2 for some reason but now i can do donuts. The plastic body is cracked. Today was not a good day.......[]
Oh yeah and i accidentally bent the front shocks.
Old 04-05-2007, 04:45 PM
ehroof
nice bro, nice bashing, lol. no problem you can fix it.
Old 04-05-2007, 08:30 PM
TannerReagan
Do you know how i can fix my problem with only 2 wheels moving and the front to just steering now?
Old 04-05-2007, 08:32 PM
ehroof
make sure the drive shaft is there, the cups holding the dogbone in are there, the grub screws in them tight?
Old 04-05-2007, 08:35 PM
  #31
TannerReagan
yes they are all there i am pretty sure, but where are the grub screws, and i tried taking off the upper deck piece so i could get a better look but it was very hard to get everything unhooked.
Old 04-05-2007, 08:39 PM
  #32
ehroof
if you look where the dogbone goes to the front and center diff, you will see drive cups, where the dog bone goes into, these are help on by a recessed grub screw, you could see it if you get the top plate off, there are screws, the handle and a small nut that hold the top plate on.
Old 04-06-2007, 09:22 AM
  #33
TannerReagan
Yeah i checked and the grub screw is gone! Do you know where i can buy a new set of them? For pretty cheep?
Old 04-06-2007, 09:24 AM
  #34
ehroof
check out clermontmotorsports.com, i dont know exactly which one it is, but he has them, and he has the drive cups too, i just ordered some, should get them today. email him about the one that you need.
Old 04-06-2007, 09:28 AM
  #35
TannerReagan
would it be the m3 or m4? Oh yeah and by the way, my 2 speed isn't working and it never has but don't you udjust a spring or something???
Old 04-06-2007, 03:29 PM
  #36
TannerReagan
I find my manual it is m4.4
Old 04-06-2007, 06:10 PM
  #37
ehroof
ORIGINAL: TannerReagan
you adjust the grub screw, there is one that holds the 2 speed in place and one that adjusts shift rpm's. clockwise it shifts at higher rpm's and counterclockwise it shifts at lower rpm's. be careful not to over tighten or over loosen the nut since it will crush the spring of the grub scew will fall out. do 1/2 turns at a time and try it out.
Old 04-06-2007, 06:20 PM
  #38
TannerReagan
I now have it shifting into second but it is very cold outside and now it won't start. The engine will fire but won't start. Is there anyway to make it start better in the cold?
Old 04-06-2007, 06:22 PM
  #39
ehroof
warm the engine with a hair dryer then start.
Old 04-07-2007, 09:04 AM
  #40
TannerReagan
I tried it but that isn't the problem, I guess i will just try again later or when its nicer out.
Old 04-07-2007, 09:09 AM
  #41
ehroof
try setting your tuning needles up to their stock setting and try 2 1/2 on the high and flush with the low, make sure the carb is open a little like 1mm. try giving it a little throttle when your starting it
Old 04-12-2007, 05:55 PM
  #42
TannerReagan
I got it running and my new failsafe came. But the failsafe kicks on whenever i start to drive it? What it the problem and can i set it diffentley or something.
Old 04-12-2007, 06:00 PM
  #43
ehroof
most likely your batteries in the car are going dead. The failsafes kick in when the voltage drops below a certain point or the radio loses its signal. what failsafe do you have?
Old 04-12-2007, 07:21 PM
  #44
TannerReagan
I have a glow hobby failsafe the one you showed me on ebay. It goes onto the red light once u take off in it. but if it is sitting still and you gas it on a stand it won't.
Old 04-12-2007, 07:50 PM
  #45
ehroof
i really dont know, you may need to adjust it, see what the instructions say
Old 04-13-2007, 07:50 AM
  #46
MiniCwik
MiniCwik's Avatar
I had battery issues with mine and it was driving me nuts, when I connected my failsafe and started driving it would just engage the failsafe to full brake and start sounding the audible alert. Man I almost through that thing as far as I could but then I removed it and had similar issues with it steering on its own and acting weird, replaced batteries in the receiver box and all was fine.
Old 04-15-2007, 08:01 PM
  #47
TannerReagan
I got new batteries in the reciever everthing works great thanks MiniCwik.
Old 04-15-2007, 08:28 PM
  #48
TannerReagan
Do you know where i can get some pretty good tires for my tornado bb i have already worn the back tires down a lot because of donuts.
