1/10th scale problems
IL
Ok. so I got the 1/10 scale rc buggy tornado xp and i was racing it around in a parking lot and i lost the sinal. the buggy went into the wall at full speed and the carbuerator broke off the engine. So i got the replacement parts but when I put them back on and all was finished I took the car out to test it and it won't work. The engine starts perfectley and keeps going, but for some reason when its on the ground none of the power from the engine is rotating the wheels so it goes very very slow or just sits there. WHat would cause the loss of power to the wheels? I checked all the gears and they all spin and work fine. any ideas? thanks!
IL
I just ran it and it seems like all 4 wheels are moving, but when placed on the ground, they either barely turn or don't turn at all. Also the chasis is bent a little in front, causing the diff. box to be at a slight angle. Would this affect it?
Check the clutch! You probably smoked the shoes! Take the clutch bell off and see if the shoes look shiny and discolored. If they are, take some very fine sand paper and scuff the shoes up until they look clean and then do the same to the inside of the clutch bell.
Hope this helps!
Hope this helps!
