Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
volcano sv pro help
Old 10-24-2007 | 11:33 PM
  #51
Default RE: volcano sv pro help
ORIGINAL: cen123
Hey,secgenffemt what tires are those?
they are proline mashers mounted on rpm claws
Old 10-24-2007 | 11:40 PM
  #52
ORIGINAL: ehroof
sorry bro, i wasnt sure
thats okay was just checking (it was worth a shot to get rid of the single needle)
thanks again everyone for all the help .
Old 10-30-2007 | 01:06 PM
  #53
hey guys i jinxed myself, last night i emailed (all about fun) to find out the replacement spur gear for the direct drive trans upgrade. He gave me the redcat part number 05112 and guess what i stripped out the spur gear today. Anyone know what brand i can use as a replacement so i can go to lhs and get one today . its like 67 degrees here today and i really want to run more today. also the stock one is 42 tooth can i jump up in theeth and get more torque for off the line , because the infinity 18 only has the one needle screw need more off the line .
thanks again,
Scott aka Secgenffemt
Old 10-30-2007 | 01:25 PM
  #54
sorry bro, only the original spur will work with it.
Old 10-30-2007 | 01:28 PM
  #55
is there a higher tooth gear avalable from redcat, right now i have the 42 tooth
Old 10-30-2007 | 01:44 PM
  #56
05112 is a 44 tooth, 02112 is a 42 tooth.
ask clermontmotorsports.com he knows about the gears and has them in stock:
http://www.redcatracing.com/itemdeta...p?partno=02112
http://www.redcatracing.com/itemdeta...p?partno=05112
Old 10-30-2007 | 01:48 PM
  #57
ok i'll drop him an email and see what he suggests thanks again for all the help eddie
scott
Old 10-30-2007 | 01:50 PM
  #58
you got it bro, remember less teeth on the spur gives you more top end, its the opposite of the clutch bell
Old 11-06-2007 | 10:42 PM
  #59
hey guys just an update ordered the parts i needed for the stock trans and the direct drive. Put the stock trans in with the 13 tooth cb and omg this thing is nuts now, not doing wheelies yet but will spin all four tires on take off now, havent started to retune it now that it has the stock trans back in but so far i love it. was only able to get the 44 tooth for the direct drive, we will see how that works if anything happens to the stock one now
thanks for all the help everyone
scott
Old 11-15-2007 | 07:15 PM
  #60
hey does anyone know if the electric starter from redcat will fit the infinity 18 cause im tired of havin to fix the pullstart on mine (replaced the spring,cord,and rewound it about five times now).
Old 11-15-2007 | 07:19 PM
  #61
i am pretty sure they use the same backplate, i would suggest asking the support on redcat's website before you order it though, i remember a problem with someone using a pullstart from hpi, they work on the vx .18 and not the infinity.
***** i just checked the site and they sell a different backplate for the vx.18 and the infinity .18 so i think they are different, not to mention they are out of stock on the infinty backplate*************
Old 11-15-2007 | 07:24 PM
  #62
yeah that was me the first time it broke on me . now i think the plastic is wore right where the spring fit in the back cover so it keeps slipping out. thoght if i switched to the ele. start then i wouldnt have to worry then.
*********figures *******lol
( just checked it too and it seems like they sell the starter gun with the backplate for infinity .18 and .27 together for $40) is that how you see it too
Old 11-16-2007 | 09:20 AM
  #63
rclynx's Avatar
Redcat used to have the adaptor for the Infinity[&:]
Old 12-08-2007 | 11:01 PM
  #64
hey guys just wanted to give ya an update got a hold of redcat and they said that yes part# 70111j does come with the backplate for the infinity and will fit for me so i ordered it . cant wait to get it and get back (on the road) i have all this snow and it needs some tracks in it . i will let ya know how the rotostart works.
p.s. i will have to take some pics once i get it in and all back together
Old 12-09-2007 | 03:45 AM
  #65
rclynx's Avatar
hey guys was just wondering if anyone knows for sure if the vx-18 and the infinity 18 carbs are interchangeable (i am still waiting for xoutas to pm me back, been over a week and a half). any input would be greatly appreciated thanks again
You can put the VX carb onto the infinity, its a little tricky[:@] infinity is held in with screws so if you install the VX carb onto the infinity you must drill and tap both sides of the carb. You can't put the Infinity carb on the VX [:'(] because there is no bottom O-ring to seal the carb[&o]
Old 12-09-2007 | 03:07 PM
  #66
cool that doesnt sound to hard and thanks for the input i will have to keep that in mind when i get a little money againas always thanks again for all of your guys' help in here it has been a life saver
Old 01-17-2008 | 10:03 PM
  #67
hey guys i just tore out another gear in the factory trans again not the main spur gear but one of the reduction gears so it back to the direct drive . hey clermont was just wondering if you could get back to me about those higher teeth gears on your site if they would fit in the direct drive or not? thanks again
