Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
 Modern Equivalent to Esquire >
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 04-19-2007 | 06:31 PM
Default Modern Equivalent to Esquire
I looking to scratch build a model that has the same flight characteristics as the old Midwest Esquire (rudder only), however, I want to use three channels, throttle, elevator and rudder.
The Esquire had a 50" span with 500 sq. in. of wing area and flew on a .15 .19 size engine. The Esquire weighed 3 1/2 pounds max. It was a real docile airplane with a .15 and am looking for slow and stable performance.
Any ideas?
RCfan
Old 04-19-2007 | 09:01 PM
ArmedZagi's Avatar
Default RE: Modern Equivalent to Esquire
Why not build an esquire and give it elevator control?
Old 04-19-2007 | 10:44 PM
build light's Avatar
RCfan, you should visit here:
http://www.rcuniverse.com/forum/m_5301618/tm.htm
and join our Rudder Only cookup! It started out as strictly R/O but has since been amended to include throttle and yes even elevator control if you really want to. Free plans are available for quite a few R/O planes, mostly .010..020 and .049 but some will take up to a .15 and are allowed for this impromptu ( I hate to use the word contest here) event and we would surely welcome you and others that want to attend. The more the merrier!
As for .15 size planes and engines you will (in my humble opinion) find more help and friendly advice in the HalfA forum.
As for just building an Esquire and adding an elevator I advise against that as it stands, for such a plane was designed to be flown R/O and trimmed as a freeflight plane wherin you would interfere with its inherent FF characteristics by occasionally applying some rudder to alter its flight.
If you really want to do that it would be advisable to make some other changes in its inherent stability like lessening the angle of attack of the wing in relation to the stab. Remember the FF plane was supposed to be trimmed to climb and circle slightly under power and decend gently (hopefully to a safe landing!) with power off.
Power planes with R, E and Throttle are trimmed far more to the nuetral side of things. Many of these older designs have a lifting stab and this is a no-no if you add elevator. This too you would want to neutralise for better effect of the elevator.
Come on by and tell your story and see how many would jump in to help you!
Offer is open to everyone! We're gonna have a good time! Heck! Were are also allowing electrics! Like I said, it is more of an event than a contest! Come on everyone!
Robert
Old 04-20-2007 | 08:33 AM
BruceTharpe's Avatar
I'm pretty certain Bill Northrop sells plans for the Esquire. Here's contact info:
http://www.geocities.com/aerohydro/mfm/northrop.htm
I agree with Robert, you will probably want to reduce the inherent stability by reducing the wing incidence. That way, it won't be fighting you. The Esquire is a classic!
Old 04-20-2007 | 08:57 AM
RCFan, if you want to bulid an REM plane like the Esquire, I can't see how you could beat the old Sig Kadet.
Dave
Old 04-23-2007 | 11:29 AM
My Feedback: (18)
RCFan, why not build a Tri-Squire. It was designed for rudder and elevator control and uses the Esquire wing and tail. A bit more stream lined and setup for tricycle gear also.
Bob Harris
