Source for floats
CA
Hello, I have the Taylorcraft 450 made by E-Flite and I would like to put it on floats. I was told the proper size float would be 24". Where can I get floats for it, and has anyone put this plane on floats yet?
Ken
Ken
FL
Hi,
Actually this funny that i came across this post, i am looking for set of floats for 8' Unionville Turbo Beaver, if anyone know where i can a set or set of plans let me know. Thanks
Mrbassman, Herr Engineering Mini Floats would also work for you. They are built up balsa 23 3/4" long, very lite weight, build quick, and are fairly inexpensive.
My Feedback: (93)
MI
Try this gentleman, he makes floats in several sizes. They are foam and you can get them balsa finished or plain foam. I have a set on a small e-cub and thay are well made and work well.
[email protected]
[email protected]
SC
I just got a set of floats from [email protected] . A nice pair of "slim" 42" beauties for my Saito FA-82a powered LT-40 ARF.
I took the advice of some on this forum & used "Minwax Polycrylic" water based to glass over 3/4 oz. cloth. Cleans up w/ water, goes on easy, dries fast [use a hair dryer].
Painted using "Ace Hardware's" spray primer. then their premium enamel [dries fast], then a coat of "Minwax Spar Urethane" spray [clear] for fuel proofing.
Did all this in one day.
Shack
Shack
