PDA
View Full Version : RC On Road Nitro Cars
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. rs4 hop ups
  2. Beginner NEED HELP!!!!
  3. tuned pipe ?
  4. NTC3 +
  5. First Gear on a NTC3
  6. Need a FAST car
  7. engine
  8. what starter box for...
  9. Best fuel for a 4-tech
  10. opinions welcome
  11. whats the biggest spurgear do they make for a nitro rs4 2?
  12. Ntc3 speed
  13. Just a question about street cars
  14. Is this what the hobby's come to?
  15. Need a new air cleaner.....
  16. pinions for NtC3
  17. 1/8 scale foam tires
  18. what car has most tunable gear ratios?
  19. so i ordered my..............
  20. Cars suggestion
  21. hump pack or flat pack?????
  22. NTC3+ A-arms
  23. ntc3 gears
  24. a typical newbie question (first car)
  25. engine output shaft
  26. boggin down when shifting
  27. Cleaning the car......
  28. motor for ntc3
  29. starter box
  30. Questions on NTC3
  31. hpi nitro star .15fe clutch problem
  32. first nitro car....
  33. which On road car
  34. what shocks for schumacher fusion?
  35. wheel nut wrench/size
  36. anyone got a FR 18 in their rs4?
  37. i really need it!!!!
  38. where can you get a 3 or 4 shoe clutch at for a nitro rs4 2?
  39. duratrax street force break problem
  40. Sirio .12 SE Adam Drake
  41. belt drive vs shaft
  42. looking for touring kit that will take t-maxx engine
  43. Need help with cars
  44. Venom Racing rims and tires
  45. what tire
  46. Upgrade Engine on RS4 3SS
  47. Venom 1200 nimh connector to receiver ?
  48. what is the best engine can you get for a stock nitro rs4 2?
  49. looking for a cheap street car
  50. any on road nitro racers in new rochelle ny
  51. What I saw at the track today. Questions about some cars.
  52. LRP .12 "Team" & "Race"
  53. batteries
  54. ntc3 worth or not?
  55. Newbie help...Keep stripping spur gears
  56. Improving Handling
  57. Ofna LD3 ???
  58. S.H. .28 in Hot Bodies Tornado
  59. NTC3 and Starterbox
  60. Replacement of the stock T-15 HPI RS4 3 engine?
  61. opinion
  62. Age old ?
  63. Failsafe Problems
  64. Question about the NTC3 flywheel
  65. Idle Problems! Please Help?
  66. high speed needle O-ring replacement
  67. LD3
  68. HELP ON PIPE FOR .12 ON ROAD
  69. tires for ofna ultra gtp
  70. Serpent 835 Re Build
  71. high speed needle screw turns easy
  72. Switch Good Or Bad
  73. fit? Kyosho Pure 10
  74. Receiver battery pack question….
  75. Newbie tire question…..
  76. top speed rs4 3 evo
  77. .18 TZ my review.
  78. What car should i get ?
  79. Smartech Engine Upgrade:)
  80. i need to know every thing there is on a megatech razor
  81. has any one put a RS43 on the track
  82. I took off the clutch bell and now this happens, What do I do?
  83. besides tower hobbies......
  84. help with gear ratio
  85. clutch not engaging
  86. belt or shaft driven?
  87. pls help with my R40
  88. does any body know any thing about an rx-10
  89. NEED NEW ENGINE
  90. Newbie with TC3+
  91. Suggestions?
  92. new 1:8 or 1:10 ?¿
  93. Tire and wheel confusion, please help!
  94. novarossi turbo plugs?
  95. fuel spits out of glowplug
  96. bumper and body posts.....
  97. is a school parkin lot a good place to race with frineds?
  98. Smartech Commando Toyota Celica - Help
  99. Foam and Rubber tires
  100. 2 speed???
  101. NX-15 Lighting on a NTC3
  102. WASP.26 TC3 HELP!!
  103. CAR WONT
  104. Brakeage?
  105. NTC3 dialing in suspension - what's the order?
  106. help newbie
  107. Car wont go into 2nd Gear
  108. looking to get first on road nitro car
  109. Ofna Delta Force .21 P8 racing motor
  110. Novarossi Pich Bolt Help
  111. battery for rs4-3
  112. HPI
  113. New Duratrax Streetforce gp2 noob questions
  114. Resize or new piston/sleeve????
  115. nitro engine
  116. NTC3 RTR + Gearing
  117. Idle Help!!
  118. Idle Help!!
  119. Cen ct4s vs kyosho fw-05 r
  120. starting car after winter
  121. how fast is 4-tec stock?
  122. car out of control
  123. car out of control
  124. NTC3+ Question (Starter box)
  125. new nitro car
  126. advice for my rs4 sport 2
  127. high frequency noise at low rpm
  128. Foam Inserts.
  129. new body, rims, tires
  130. a great tip for every body
  131. Suggest a reliable car for former RCer
  132. 2-speed.Spur.Gear
  133. On road rcing sucks off road I love it
  134. .15 AE engine fun!
  135. rtr3 nitro
  136. Im never using rubbers again!!
  137. associated NDS qualifer series
  138. Problem with n00b's engine
  139. hpi pirelli tires
  140. Anybody ever use these tires?
  141. rustler electronics cooked.
  142. Picking Up a Serpent 710
  143. newbie 190mm bodies
  144. Radial VS. Slick
  145. rotary to slide carb conversion?
  146. NTC3 Exhaust
  147. I'm upgrading on a buget, heres my christmas list:
  148. Final Questions (for now)
  149. NEED TIRE HELP
  150. Complete noob question
  151. NTC3+ Tidbits 4newbies
  152. Engine for serpent impulse 1/10?
  153. OFFICIAL OFNA THREAD
  154. K&N AIR FILTERS
  155. NiMH battery (Venom) charging questions
  156. Hi All - Just to say Hi
  157. which rims??
  158. best gearing 4 quickness on tc3
  159. Hpi SF-1 steering servo in a RS4 3 Evo RTR?
  160. would these work!???
  161. SERPENT 950R
  162. DTX radials... what a joke LOL
  163. OS 15 or 18 engine?
  164. Rs4 engine mod
  165. Hpi servo's...
  166. Spur gear for RS4 3 RTR?
  167. Is the Street force GP2 durable?Yes it is!
  168. Brake lock-up
  169. PRP XR/80 is this 2 good 2B true ?
  170. Nitro Trucker wants RTR street machine. Help me decide!
  171. A barrage of question regarding engines.
  172. fusion 21
  173. NTC3 RTR and Airtronics 94102 servo problem
  174. how fast does your ntc3+ go?
  175. what happened?- wont run after 5mo. sitting!
  176. NTC3 TIRES
  177. how much???
  178. NTC3+ question
  179. Best engine + pipe combination.
  180. THS Pipe on RS4 3 Type SS??
  181. Body Size for Fusion?
  182. BODY SHELLS
  183. I NEED A .15 OR .18 MOTER THAT RUNS
  184. Batterio
  185. newbie w/RS4 RTR??
  186. Tire question.
  187. TC3RTR vs TC3RTR+
  188. Messed up differentials?
  189. 2 speed not engaging...
  190. racing rule
  191. One for the HPI Guys
  192. What are some good engines I should look for to put in my RS4 RTR?
  193. Thinking of going the O.S .18TZ, but fuel economy - anyone ??
  194. will a .18tz..........
  195. guys i need help
  196. Liteweight Pipes for a .12?
  197. Dud engine off ebay.
  198. New lid fro my n4tecpro
  199. Ntc3 gearing - Help!
  200. ANYONE WANNA SELL?
  201. ntc2 throttle/brake ?
  202. help with new 18ss rs43
  203. NTC3-Nitro 4 tec where from $
  204. dont get these tires, they suck
  205. Begginer in street
  206. Glue for tyre
  207. TC3 Engine Question
  208. how to drift my nitro 4wd rc
  209. CV-rX Needle settings, and VSM settings
  210. ANYBODY GOT A OFNA Z10
  211. I'm really Pi$$ed of - anyone know where I can get...
  212. Mystery?
  213. NTC3+ Transmission issue?????
  214. car shell?
  215. NTC3+ Help
  216. broken spur gear on 1/8th proceed
  217. Help with gear ratio's
  218. large foam tire selection online?
  219. Need help choosing pipe for R40
  220. slightly different discussion: front 1-way or ball diff.?
  221. looking for a car
  222. Some new high-traction tyres
  223. Gotta Get me these bodyshells!!!
  224. New on-road nitro car choice.
  225. Foam Tire setup for TC3+
  226. Some quick help please
  227. NTC3 shifting or not?
  228. Failsafe mounting for NTC3+
  229. .15 pipe on a .18 engine?
  230. Nitro RS4 and Nitro RS4 Racer2 - same parts?
  231. Mugen MSX-3
  232. more power
  233. Best 1/10th Nitro Engine
  234. engine stalls... too rich?
  235. New shell for racing.
  236. NTC3 RTR Plus radio question.
  237. hi
  238. Anybody ever use these wheels...
  239. my best RC day experience
  240. Please help me w/ tires.
  241. 190mm or 200mm???
  242. houston sedan roll call
  243. Cant Decide on NTC3 Engine
  244. ok ..... wierd tire question ???????
  245. newbie question # 3 - car tends to run at idle
  246. Convert
  247. best and fastest motor for my tC3
  248. .25 stock Savage motor into RS4-3 ???
  249. more newbie questions...
  250. silicon lubricant applications?
