PDA
View Full Version : RC On Road Nitro Cars
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45
  1. web page
  2. Which steering servo for NTC3+?
  3. OnRoad Help
  4. Mugen
  5. Bash your RS4?
  6. Yokomo wheels - any experience?
  7. what car is this???
  8. starter box conversion
  9. Nitro TC3 clutch nut
  10. Good High Surface Temp Tire?
  11. Pullstart Problem
  12. boost bottle
  13. need help really fast!!
  14. Where?
  15. bogging problem
  16. Help! My .12R SS is conking out!
  17. ntc3 help
  18. Build your ultimate RC car!!!
  19. Run time
  20. Kyosho GX12
  21. NTC3 unidrive and CVD - what is difference
  22. any suggesttion on yokomo.......................
  23. help me start my car
  24. winter
  25. Looking for tracks in Mass
  26. Road Domes!
  27. Engine bogging own at low end
  28. Are Onroad r/c expensive??
  29. Which is the better car??
  30. Heli fuel
  31. Plexiglass Chassis???
  32. Almost Done With My Peemp NTC3
  33. quick performance
  34. RS4 3 SS Chassis Dimensions?
  35. '05 FANTOM ENGINES
  36. Engine info
  37. got my RTR RS4 evo 3 today! picz
  38. supercharger
  39. is it ok to run 10% fuel now and 20% later?
  40. Newbie new car question. Evo vs. SS?
  41. upgrades for hpi
  42. ok now this sounds bad......
  43. Hpi Nitro Rs4-3
  44. £400????
  45. MTX3 prospec...super nice car
  46. Nitro fuel question..newbie!!
  47. New to Onroad.. need tips on MTX-3 Prospec
  48. Weird Radio Glitches?
  49. Will X fit X?
  50. plz help ID this car
  51. Maybe Someone in tis forim can help
  52. OK Maybe SOmeone in this Forum Can help.
  53. Top speed of RS43 SS?
  54. Old OFNA Z10 parts request
  55. Newbie 4-tec Story.
  56. best touring car?
  57. NTC3 receiver pack and servos connector type?
  58. Light Kit....
  59. New, and Need help
  60. traction help
  61. I got my car, pics now here, yay!
  62. Where to buy K-Factory product online?
  63. Smartech needle settings
  64. NTC3 RTR servos – looking for ethnical specs
  65. HELP! Grease all over my Car!
  66. FOAM TIRES NTC3!!!
  67. PRIMER NO GOOD!!!!???
  68. Temp gun – which one would you recommend
  69. nitro touring car w/ reverse
  70. Brakes on the NTC3+
  71. is there a nitro touring car that goes 50mph + and has reverse
  72. does nitro tc3 go reverse....top speed....max horsepower....????
  73. Upgrade?
  74. Finally finished my Escudo shell
  75. NTC3 - question about differentials
  76. bought my very first nitro car..
  77. NO BUDGET LIMIT!
  78. My Wasp .26 powered RS4 3 project w/pics!
  79. OS .12 TR, hard start
  80. spinning wheels
  81. Are these the correct hex wheel hub clamps for HPI RS4?
  82. anyone know where this Hotbodies part goes on the HPI RS4?
  83. Tamiya body on HPI RS4 SS? Anyone ever done it?
  84. What engines do you have
  85. escalade body 4 sale NEVER USED
  86. cleaning pull starter when slipping.
  87. shock oil and springs
  88. For Sale!!!
  89. rs4 2
  90. Question about engine rebuilding
  91. HPI T15 vs. .15FE for my RS4 3
  92. Breaking In
  93. whats your oppinion?
  94. Starter box for NTC3 RTR
  95. NTC3 and RS4....Compatible Flywheels?
  96. Official Smartech Thread
  97. should i buy .......
  98. Where can I get a new CHEAP HPI .15FE
  99. need help for a rear exhaust engine on the rs4 3 !!
  100. Ron Parris Racing Inventory blow out
  101. Kyosho Landmax
  102. Best Pipe For.........
  103. Whats a recoil starter assembly?
  104. Foam Tires
  105. NTC3 With OS .15CV-X, Need Clutch Opinions
  106. Ofna CD3 or AE NTC3
  107. Where can I get an engine sleeve for an HPI .12R SS?
  108. Fuel, Oil, Tires???
  109. Craziness!!!... but will it work???
  110. O.S. .12 CV-RX w/10C crankshaft
  111. Seal Ball Bearings
  112. Which engine for my NTC3
  113. problems to start the car
  114. Which Ofna 1/8th?, there all different.
  115. long wheelbase rs4-3 ss
  116. FYI
  117. Need bigger wheels for Landmax2
  118. dual engine rs4 3 ss
  119. SPEED CAMERA CHALENGE!
  120. Warped Wheels
  121. hi torque steering servo for ntc3
  122. If an engine is improperly broken in, can it be fixed?
  123. 3-speed
  124. Cars and their top speeds
  125. Which Car
  126. T2M What do i have
  127. WHICH FUEL to buy?
  128. What alternate engine will work in an RS4 3 Type SS?
  129. Guys from Canada: where do you buy parts?
  130. O.S. .18 Rear exhaust
  131. Clutch problems?
  132. NTC3 upgrades suggestins and "fix" question
  133. MY MTX-3
  134. Venom Speed Meter and Fail Safe...
  135. How do i tune my engine???
  136. what does it do?
  137. epic .18 in my car
  138. **ATTENTION RACERS**
  139. Took me CEN TR-4 for a drive
  140. HPI 200mm Bodies?
  141. HOT BODIES TORNADO RTR
  142. Nitro tc3 or v one rr
  143. Stock Gear ratio fo nitro tc3 rtr
  144. break in AGAIN?
  145. Tamiya TG10 Mk1
  146. New forum for kyosho and others
  147. Will a .18 fit in the FT ntc3
  148. ops .15
  149. Noobie =)
  150. NEO SABER PARTS???
  151. 2speed
  152. is this normal?
  153. fuel
  154. price
  155. clutch
  156. ntc3 ver2 rear end is it worth it?
  157. ntc3 or rtr3
  158. ????
  159. default needle settings for tc3 .12 engine
  160. What is the part that you replace the most
  161. Best on-road nitro car?
  162. Some Newbie Questions
  163. super ntiro RS4??
  164. HPI Nitro RS4 3 Centax (Center Force) Clutch Set
  165. help
  166. Z-Speed Nitro RS4 Hoppup Chassis?
  167. gas
  168. gas servos
  169. Nitro % Upgrade Problem
  170. fantom .12 pipe or cvec .12 tuneable pipe?
  171. whats your ss's 2 speed shift point?
  172. Help please before I commit suicide :(
  173. inaly got a new engine!!!!
  174. Help whit my 2-speed NTC3
  175. some help with Rs4 SS
  176. 1 piece side exhaust pipe for under 50 bucks for my tc3 .12
  177. NTC3 Suspension tuneing
  178. Cheap 1/8 th scale street cars
  179. new novarossi engine
  180. rs4 3 ss clutch options
  181. Upgraded Header for RS4 SS?
  182. Better HPI steering servo-saver suggestions
  183. NTC3 Fuel Tank?
  184. Serpent 835
  185. Got a stripped screw on cooling head!!!!
  186. Help Removing Pinion Gears
  187. Clutch engagement
  188. is this a good deal???help!!
  189. how much horsepowers
  190. Newb to onroad looking for good kit
  191. anyone heard of this?
  192. Do you reuse your rims?
  193. Nova rossi
  194. new (old) rs4 3 SS
  195. trade*****
  196. looking for k factory parts
  197. fusion 21 owners please advice.
  198. Ofna LD3 Pro w/ engine ???
  199. any free mod's i can do?
  200. mugen mtx-2 gears
  201. mt-12 factory settings
  202. 4TEC and Tire Combo
  203. My car won't start
  204. tc3 not hooking up?
  205. Piston pin.
  206. HPI 12r ss over heating
  207. NitroTC3 Help!!! please Help!!
  208. Got a problem with the flywheel.
  209. Blew my rear driveline on my HPI RS4 SS
  210. Blew my rear driveline on my HPI RS4 SS
  211. R40 Peace of crap.
  212. *** need help jr racing xr3
  213. new bashing motor what to get?
  214. Nitro Dragsters
  215. Ofna lx comp to gtp??? help
  216. Ths Pipe problem
  217. daratrax street force
  218. New engine
  219. ROAR 2004 NITRO ON-ROAD STATE CHAMPIONSHIP
  220. Looking for Lola...
  221. smartech nitro
  222. Foam settings for NTC3
  223. HPI RTR Nitro RS4 3 Evo engine conversion
  224. STREET FORCE GP2..IS IT WORTH IT?????
  225. ***mugen mtx-2 hoped up for off road stuff rtr
  226. Dual Exhaust??
  227. Need Nitro TC3 Tuning Help
  228. perfect steering servo for NTC3
  229. Pipe and header
  230. RCdriver
  231. Enigne Pull Start Screws
  232. Torque Steer Problem (Newbie Help)??
  233. HPI rs4 RTR 3 Evo vs. Team Associated NTC3 RTR
  234. RCU Magazine Review - Schumacher Mi2
  235. Got my CEN CT-4S and was wondering...
  236. Custom light kit
  237. loll this sux
  238. what could cause my kyosho pureten to overheat (i think it is)?
  239. time for a new motor
  240. Nos?
  241. On-Road in San Jose
  242. Help
  243. NEW to 1/10 on road nitro MTX-3 vs TC3 s RS4
  244. How do I increase my top speed?
  245. nitro rs4 3 evo
  246. What do your tracks look like??
  247. top speed gearing
  248. which motor mounts ??
  249. aluminum diff pulleys
  250. my impulse
