- Finally...I got it!!! Vantage's extended chassis for my Revo!!!
- O.S. 18 TM pipe combo.
- O.S. .30 VG
- newb gettin a new t-maxx/revo
- T maxx problem
- Quick Question about tuning
- Suspension question for you Revo guys!
- t maxx vs s maxx
- has anyone ever done this
- T-maxx race pictures...
- New to racing... need help
- wheel & tire????
- Tight Steering
- is this a rear exhaust or side.
- Come across to a fullscale monster truck
- check it out i jumped a car
- clutch bell and spur combo
- Revo Bogs when it hits 2nd
- Nomadio Sensor
- REVO CHARGER QUESTION
- Will this work on my truck.
- traxxas
- Compilation vid of my E-Maxx
- Carb problems!
- Best pipe for my Revo with a O.S. .18TZ Turbo Engine??
- need help 2.5 keeps stalling
- Spektrum DX3
- I think my steering servo is toast.....vid
- DOES ANYONE know how to make a quickturn
- REVO RACIN' THREAD
- my tmaxx is having problems
- how do you know if your front bulkhead is cracked/bent
- New Motor in Tmaxx Need Help!!!
- .28 cxp?
- Painted Exhust
- Newbie needing alot of engine help
- upgrading .15 maxx
- HELP!!!Revo Transmission Problem...
- wouldn't mind having one of these trucks.
- Got a Fantom Tuned Pipe. Qoncepts kit????
- 3.3 sleeve problem.
- 3.3 engine
- Changing Glo Plugs
- i`m newbie help me please
- wasp 28 on maxx
- picco
- Pics of 1/8 Buggy wheels on E-Maxx
- how to make E-Maxx bigger?? Help
- 3.3 chassis question
- trx 2.5&2.5R crank
- New Ver. Of PICCO 27
- standard crank shaft?
- shock oil
- wasp 28 clutch
- DELRIN OR STOCK PLASTIC FOR SPUR GEAR?
- TMAXX cutting out! NEED HELP ASAP
- 4 stroke
- weird problem with hitech 645 steering servo
- Custom Paint Jobs, Lets see some pics ppl!
- bogging!!
- Long travel rockers + RPM carriers?
- Called OFNA support today.
- Tmaxx 2.5 to a revo?
- How to get oil off?
- BRUSHLESS REVO??????!!!!!!!!!
- guys trying to scam me on deal for a revo
- Best All Around Rockers!
- how should the lsn be set in 90 degree weather
- auto cad
- GET RID of your UGLY BEAT UP Revo 3.3 body!
- Revo 3.3 warranty
- my revo
- my OS .18 break in review
- t maxx 3.3 brakes
- red plug in blue thunder fuel jugs
- my revo before & after
- Wanting to run a single steering servo..
- Help! Sirio .18 engine should I buy it??!! Auction ending in 1 hour!!!!
- Revo Radio Antenna?
- t-maxx 3.3
- os.18 idle problems
- Poll: 2.5 Chassis vs The 3.3
- revo engines o.s.
- Is this a common upgrade for Revo?
- racers wing....
- jsto fuel tank
- Poll for 3.3 owners (tuning)
- O.S. 18 TM EB Modified with a Nova O.S.18 TM Cooling Head
- how wet
- servos
- Will this work.
- -=OFFICIAL REVO 2.5 3.3 AND E-REVO THREAD=-
- GAS PROBLEMS.........
- Looking For kliff.
- Maxx A-Arms: Aluminum or RPM Plastic?
- Revo, Aftershock, or Savy
- New Jato
- To modify, or not to modify; that is the question....
- side exhaust on revo
- Revo Radio Questions... PLEASE Help
- break-in info?
- 40 series or MAXX
- reverse problem
- Foams for the Revo
- A Large Thank You.
- Wheelie bar help
- What do you think about his motor
- 2.5R or 3.3 transmission
- LT Springs
- i need some advice
- 2.5 hot start probs
- Upgrading .15 T-Maxx
- T maxx driveline
- Pimpin Out My New REVO
- T maxx 2.5 Question
- is this motor any good?
- My new truck.
- Revo Turnbuckles
- aluminum
- Piggyback Shocks
- well my 2.5r problems
- Revo 3.3 Chassis?
- revo and engine question???
- diff spool! do u suggest it?
- bummer
- So I went and got a new 3.3
- Big Block Revo Clutch reccomendations needed
- stampede
- t-maxx 2.5
- question
- my revo stops as the rpms increase
- Newb needs help....
- clutch shoes
- how to shim flywheel?
- engine bearings in clutch bell?
- Air leak at glow plug?
- drake 30??
- Spektrum
- some advice plz
- New Starter.
- Servo horns
- Makings of a lhs ?
- how do i get crankshaft out of engine?
- Better Value: T- Maxx 3.3, or Revo 2.5R?
- jato 3.3
- pede or rusty.
- starter problem
- servo help...
- tmaxx 2.5 conversion template needed
- do u guys think this will work
- T-Maxx Problem?
- Would a low battery cause the servo to open the carb less?
- Check it out!
- NEED HELP.
- Were can i buy
- what foams for revo racing?
- Batteries
- Sheesh!! That's a lot of parts.
- Proline badlands tires or your reco?????
- tyres for traxxas revo
- My REVO 3.3
- Revo 3 Speed Transmission
- What are the best Clutch bell bearings????
- New Break In.
- New OS.18...pics and one question
- ez start is clicking won't start
- Clutch issue?
- is there a diffrence in cooling heads
- Picco 26 Max Pull Start Question
- Were can i get one ?
- 2.5R Stuttering/Stalling at full throttle after a couple circuits
- Haha a joke.
- need help flipped truck
- Help removing fly wheel
- ????how to make a revo 3.3 race ready???
- Help, I'm trying to make a decision.
- whats the easiest way to remove the flywheel
- Uh-Oh! Help!
- Revo tmaxx body
- tmaxx clutch
- Bug block mounting problem
- emaxx
- stripped spur
- Can anyone help me? (OS .18TM)
- which drop in engine?
- blue thunder race formula %20
- Q about an EB .18tm
- B-day coming what hop ups to get.
- Which tuned pipe for Axial .28 Spec BB?
- Revo Big Block Mount
- Cant make a new thread for the ball end
- wabash MT wheels?
- will an os 18 cvr work
- What brakes first. revo 3.3
- HPI engine on TMaxx
- alignment
- how much does your truck weigh?
- Spur Gear!
- Picco 26 max exhaust combo reccomendations
- Radio Question
- my tmaxx motor has no compression when it warms up
- Air in fuel line
- Tr4xX and Ru$hEv0's revo vids
- 3230 glowplug in Revo 3.3
- fue line ?
- dust cover bellow
- REVO QUESTIONS: Filling the Front/Center/Rear Differentials!!!
- Nova Rossi 528xr
- how does this come off
- Mamba Monster Maxx is waterproof????
- glow plug that comes with the OS.18
- revo upgrades
- What is good?
- Best engine for revo 2.5
- Fuelmans break in.
- Which Revo 2.5 Body should I get?
- OS Revo wheelies with ease.
- Labor Day vid...
- Think my OS .18 is running rich?! Must see vid.
- Revo Wing?
- ezstart problem
- Do I need to worry?
- smaxx clicking when i brake
- tmaxx steering part 2...
- Almost done upgrading the E-Maxx (5 pics)
- Getting Tires Off Of Rims?
- tmaxx clutch spring
- ? from savvy owner
- who works or owns a lhs?
- flywheel, clutch, clutchbell alignment help please
- NEW BLOODY LAW !
- anyone good with traxxas .15 tuning?
- T-Maxx 2.5 Diagram
- one quick question
- I have a question
- 2.5R air leak test
- Bodies for a Revo 2.5?
- STS .28 in revo
- Clutch Spring and Shoes question.
- .26 Picco Max vs. O.S. 18tm
- Clutch Nut.
- twisted axles
- New 3.3 Engine.
- Center Diff
- os max tm VS sirio .23 for revo?
- Axial 28 Spec 1s in a revo?
- Revo 3.3 Not Shifting
- Are Jatos tough and reliable??
- novarossi 528xr revo video
- Idle? NEED help
