 When 5/16" just isn't big enough...use these guys >
Old 07-03-2013 | 10:01 AM
AndyAndrews's Avatar
Default When 5/16" just isn't big enough...use these guys
Hello,
I just got some hardened steel pins (dowels) from a company called www.dixiepins.com These pins are available in exact diameters and you can order them by the each if needed. I believe they were about $18 each. This pin will be used on a Behotec nose gear pin which for some reason on my jet had a longer than usual pin (about an inch longer) than the standard Behotec pin. As a result I had to find another source as Comp Arf only offers the standard length pin.
I did find a couple of long bolts from the hardware store that were 5/16" dia. These Dixie pins are the exact diameter of what I have. .315 which is just a hair wider than 5/16 and they fit perfect.
Just a heads up in case anyone is looking. This is a good company.
Andy
Old 07-03-2013 | 10:25 AM
Meesh's Avatar
My Feedback: (135)
Default RE: When 5/16
Andy,
Those would be 8mm diameter.
Bob
Old 07-03-2013 | 11:12 AM
My Feedback: (7)
$18 bucks for a steel pin? Who-wee that seems like a lot.
I only say this because I bent the pin in my nose gear and replaced it with a piece of mild steel I had kicking around in my scrap bin. I was worried it was too soft but guess what? Ever since I went to that soft steel pin I haven't broken a nose gear trunion (which I certainly would've at least twice). It just gently bends and saves the rest of the aircraft.
Old 07-03-2013 | 11:26 AM
ORIGINAL: mitchilito
I meant 17 for the set. But yeah even at 8.50 bucks still kinda pricey. At any rate, it was nice to find a company that could give me exactly what I needed.
Old 07-03-2013 | 11:27 AM
or .315 lol..
Old 07-04-2013 | 07:40 AM
scoeroo's Avatar
My Feedback: (9)
When you fly jets....... money should be no object -
Old 07-04-2013 | 07:57 AM
ORIGINAL: scoeroo
Not when it comes to getting a specific part you can't find anywhere else, true.
Old 07-04-2013 | 10:05 AM
FalconWings's Avatar
My Feedback: (57)
ORIGINAL: scoeroo
Why do people say crap like that. I have 3 jets, 3 kids in daycare, new house to fit three kids.
Saying money is not tight is pure BS. We just learn to manage it.
David
Old 07-04-2013 | 03:33 PM
scoeroo's Avatar
My Feedback: (9)
Money is no object to me - your life your business ..... my life my business
I realy dont care what people have/say, i enjoy all my toys because i'm well off and took care of business early in life
so please refrane and keep your thoughts/coments to yourself - thankyou
Old 07-04-2013 | 03:35 PM
scoeroo's Avatar
My Feedback: (9)
Anything can be made Andy - this is america
Old 07-04-2013 | 05:02 PM
My Feedback: (67)
This is a good site as well. I have ordered some 8mm shaft from them in the past.
https://sdp-si.com/eStore/CoverPg/Index.htm
Old 07-04-2013 | 05:55 PM
My Feedback: (57)
ORIGINAL: scoeroo
What a guy!, an assett to the jet community.
Old 07-05-2013 | 01:55 AM
highhorse's Avatar
ORIGINAL: FalconWings
ORIGINAL: scoeroo
Yup, but better an asset at someone else's field than mine please !
At $5/ flt for fuel alone I agree that flying jets isn't a bargain hobby, but the attitude is just silly.
Old 07-05-2013 | 03:36 AM
RCISFUN's Avatar
My Feedback: (44)
Hey Andy I have found Ejector Pins form Amtek Tool and Supply
A 8mm (.315") diameter x 100 mm (4") long pin is $3.07 ea
http://websales.amtektool.com/viewit...in?&pagenum=11
I have bought 1/4" Axle pins which are $2.15 ea, I just grind away the extra thickness on the head
http://websales.amtektool.com/viewit...ins?&pagenum=3
Old 07-05-2013 | 06:55 AM
scoeroo's Avatar
My Feedback: (9)
ORIGINAL: scoeroo
Thankyou - you are most welcome
Old 07-05-2013 | 07:51 AM
ORIGINAL: RCISFUN
A 8mm (.315'') diameter x 100 mm (4'') long pin is $3.07 ea
I have bought 1/4'' Axle pins which are $2.15 ea, I just grind away the extra thickness on the head
Nice find. more than half the price better. Thanks!
Old 07-05-2013 | 08:44 AM
My Feedback: (66)
Why not just buy drill blanks and use them. Can get them in any size you want..
Old 07-05-2013 | 10:47 AM
Thud_Driver's Avatar
I got tired of breaking the polished hard steel pins and watching others have the same problem. I went to a softer general purpose 8mm steel rod. Bought 3 ft and just cut to size. McMaster has it @ $8.43 for 3 ft. Now, when I screw up, the pin just bends and replaces easily.</p>
</p>
<a href="http://www.mcmaster.com/#standard-metric-steel-rods/=nhq6c4">http://www.mcmaster.com/#standard-me...l-rods/=nhq6c4 (1018 carbon steel).</p>
</p>Edit: correct price.</a></p>
Old 07-05-2013 | 02:30 PM
ORIGINAL: Thud_Driver
I got tired of breaking the polished hard steel pins and watching others have the same problem. I went to a softer general purpose 8mm steel rod. Bought 3 ft and just cut to size. McMaster has it @ $6.67 for 3 ft. Now, when I screw up, the pin just bends and replaces easily.</p>
</p>
http://www.mcmaster.com/#standard-me...l-rods/=nhq6c4</p>
Good advice.
