Go Back  RCU Forums > RC Boats > Speed - Electric
 2 decade old toy conversion to full RC >
Speed - Electric For all your electric boating needs.
Old 04-09-2007 | 05:08 PM
Default 2 decade old toy conversion to full RC
Hey guys,
I'm pretty new to RC's and my "boating" experience besides toys involves a couple of hydro "flyers" i've built from kits.
What I have is a 20+ year old V-hull toy boat that I had as a kid - I know what I need to do concerning my current transmitter and receivers, but I need some help in choosing a motor (and mounting it) as well as some details concerning the current driveshaft/rudder, servos etc.
Basically it's a plastic v-hull about 22 inches in length by 8-10 inches wide. It has a single engine/propeller and originally was set up for a large battery pack with 2 servos and mechanical speed control - it never worked very well originally (mostly due to it being made in 1988).
Thanks in advance,
Stephen Foster
Old 04-09-2007 | 06:13 PM
Quicksilver1's Avatar
Default RE: 2 decade old toy conversion to full RC
hey could you take a pic of the bottom, just wondering how suitable this is. My opinion, I think a EP1 outboard motor would look best on that boat. Would also simplify the conversion process.
whatever you do, I think when said and done, minus batteries and a good charger, your looking at about $200. Motor, drive, esc and radio. $150 if you went very basic with a stock 540 motor and some sort of home made drive system.
Old 04-09-2007 | 07:10 PM
not 150. prolly only 80 -90 if that.
10-shaft
22-esc
13.99- electrifly 600 motor
10 coupler
8-infinity for batterydepends on what you want x2 cause you will want two.
Old 04-09-2007 | 07:11 PM
oo rudder
9-30 around that.
more if you get a flex shaft- then quicksilver is right
Old 04-09-2007 | 07:21 PM
well, my high figure was for an outboard. guess my problem is I've never made a single 540 setup, was just a rough estimate. really depends on ability and how far he wants to go, but yeah it could be cheaper. I'm wondering though if the hull can handle any speed, I did up a nikko boat thinking the hull was okay, nope couldnt even turn. well turned well one way and hardly turned the other.
Old 04-09-2007 | 07:50 PM
Okay, here is some specifics on the stock motor size 27 x 38 mm with a 2mm shaft. I'm wanting to go as cheap as possible - realize I'm not working to build a super speed demon, just something mucho faster than stock. Basically I want to go with brushless and a nice little LIPO. I've got the transmitter/ESC/receiver part down - it's the specifics on a motor/how to mount it if i can't fit in stock config, as well as finding a rudder servo that would drop right in or if not find a way to mount it.
Back in 1988 when I got this thing new it was lucky to run 5 mins (if at all) and it would lose range within a few seconds. Was also pathetic on power, i doubt 5 mph.
Here is a picture of the bottom...
Old 04-11-2007 | 11:48 AM
Banned
Old 04-13-2007 | 07:26 PM
The internals are ordered, so far I've recieved the new battery and the rubber switch cover replacement, still awaiting my receiver, servo, motor/drive, and esc...
I got bored waiting and decided to work on the body - I did a base coat of Krylon H20, then testers red with gold pinstriping...
My first post shows the before pics of the hull here are the after:
Old 04-13-2007 | 10:07 PM
ORIGINAL: retaobcr
why do you do this?
