Go Back  RCU Forums > RC Boats > Speed - Electric
 Dead Motor? >
Dead Motor?
Speed - Electric For all your electric boating needs.
Dead Motor?
Old 07-01-2007 | 06:26 AM
Default Dead Motor?
Hi guys,
Think I killed my motor, Mega 22/20/2, it got hot, now it has no power and you can spin it freely you your fingers, seems like all the magnets have gone....what gives??
Rob
Old 07-01-2007 | 10:16 AM
Quicksilver1's Avatar
Default RE: Dead Motor?
can you look inside to see the brushes and commutator? You probably melted your brushes and or glazed over the commutator. You can always try cleaning it with some alcohol and q-tips. If you're brushes are shot, you'd have to replace them, if you can on those motors.
Old 07-01-2007 | 10:19 AM
Dont know if its the same as racing cars but i guess it is, heat is the enemy of magnets and is eventually the down fall of an electric motor. Not sure if you can get em that hot to kill em in one go but it wont help, you can get magnet zappers to re do the magnets but probably cheaper to just get a new motor.
Old 07-01-2007 | 10:57 AM
I tried an experiement with zapping magnets and the magnets became strong with in a few hours of the process. How I know they became strong I tested the kv using the generator method where you connect a drill and spin the motor shaft at a give speed and then check the voltage at the terminals. The voltage at the terminal increase on all the motors I did the zapping experiement on. This is how it goes. First wrap a long piece of coil around the out side of the magnetic field on the can when you have it properly wrapped it would cover the entire lenght of the magnets. Secondly connect each side of the coil to a switch then connect a power supply ( battery pack ) on the other side of the switch. The idea is to short out the battery through the coil. Use the switch to control how long you short out the battery. Don't allow the power to flow longer than 1 second or even half a second at time. It's really quick bursts of high current through the coil. This method strengthen the magnets of two 700bb motors and a 290/30 series plettenberg.
Old 07-01-2007 | 07:23 PM
would you wrap it around kinda like a cooling coil is?
Old 07-01-2007 | 09:16 PM
yes. I did that and now my motor magnets are stronger.
Old 07-01-2007 | 09:41 PM
thanks, i didnt know that. will this help on new motors, do u get any access motor heat or anything that was unusual. thats cool, after doin this could you prop up. sorry for all the questions, im just curious.
Old 07-01-2007 | 10:59 PM
ryan_t888's Avatar
What length and gauge of magnet wire did you use?
Ryan
Old 07-02-2007 | 05:55 AM
Thanks for the feedback guys, the motor was brushless, now non magnetic.....
rob
Old 07-02-2007 | 08:58 AM
ah, brushless, I feel like an idiot
Old 07-02-2007 | 12:16 PM
I am not sure of the exact size but it might be around 26awg. I tried it on a new 700 and it increase the strenght of the magnets a bit. The only thing I am unsure of is to explain which way to flow the current through the coil. I connected the positve of the power supply to the top path of the coil that going to the top of the motor.
