Speed - Electric For all your electric boating needs.
Jet
Old 07-26-2010 | 01:39 PM
Default Jet
Was looking through the "tear into" thread
Looked all the way through, but couldnt find a link to anywhere i could buy replacement impellars
Would any of them work
Not the whole unit
Just the shaft and prop
<a href="http://www.cornwallmodelboats.co.uk/acatalog/graupner_jet.html">http://www.cornwallmodelboats.co.uk/...upner_jet.html
<br type="_moz" /></a>
Old 07-26-2010 | 02:27 PM
Default RE: Jet
if you get a new coupler and drill out the drive for the shaft
Old 07-26-2010 | 10:27 PM
Default RE: Jet
ORIGINAL: Andeyking
Was looking through the ''tear into'' thread
Not the whole unit
<a href=''http://www.cornwallmodelboats.co.uk/acatalog/graupner_jet.html''>http://www.cornwallmodelboats.co.uk/...upner_jet.html
<br type=''_moz'' /></a>
ryanwilson is right. The tear into shaft is 2.3mm and the one the for mini jet is 3mm. Both are 19mm impellers. Other than buying another drive or making a new impeller by turning down one made for a 2mm shaft, It is the only option.
Old 07-27-2010 | 12:07 PM
Default RE: Jet
Turning it down? on a lathe?
Old 07-27-2010 | 02:27 PM
Default RE: Jet
ORIGINAL: damfurst
ORIGINAL: Andeyking
Not the whole unit
<a www.cornwallmodelboats.co.uk="" acatalog="" href="">http://www.cornwallmodelboats.co.uk/...upner_jet.html
<br type="" /></a>
on a lathe?
<br type="_moz" />
Old 07-27-2010 | 02:36 PM
Default RE: Jet
ORIGINAL: damfurst
ORIGINAL: Andeyking
Not the whole unit
<br type="" /></a>
on a lathe?
<br type="_moz" />
Old 07-27-2010 | 10:06 PM
Default RE: Jet
I suppose you could use a lathe, but most use a drill press with the propeller to turn mounted on a shaft and spinning. And then use a file to turn down to the right size. The best way is to put the file in a "X" "Y" vise so that you can slowly apply the file to the spinning prop. Hope I didn't confuse you too much. I think dragonfire said he used a 26mm Graupner prop for a 2mm shaft to turn down. Good luck.
