GAS OUTBOARD guys this is our new home
#2002
RE: GAS OUTBOARD guys this is our new home
Hi Dom!!
Have you managed to get an elec motor bolted onto one of the hulls and legs yet in amongst the surfin??
All the best,
Dion.
All the best,
Dion.
#2003
Hi Dion
Unfortunately "Hobby King" are on 'back order' with the motor I have ordered. Frankly - I am enjoying the rc Surfing Development so much that I have not been fussed.
I am on my 4th development board now - I have come a long way in design and in understanding the in's and out's of the FE's - it will all ultimately add value to my eventual F1 HVFE build. ( there is no rush at the moment)
A short clip - having some fun in small surf .....can ride wave sup to 8 foot face !
[youtube]http://www.youtube.com/watch?v=OeNaYLIqMsY&feature=plcp[/youtube]
Regards
Dominic (YPC)
[email protected]
Regards
Dominic (YPC)
[email protected]
#2005
Thanks Dion - really enjoy it.....
Your parcel should be with you mid week - let me know if you need some pointers on changing the skeg over.
Regards
Dominic(YPC)
Regards
Dominic(YPC)
#2006
Cant wait to get it so I can start sharpening to get that razor blade finish on it-got to keep the weeds down in the lake somehow!!! Thanks for the offer of help, I will surely take you up on that,
Cheers,
Dion.
Cheers,
Dion.
#2007
I have come to find that a 'razor sharp' edge at the front of the skeg is not good. I have prepped you skeg already.
A small round at the leading edge is better, as it allows water flow around both sides of the skeg in the turns. ( like the leading edge on a fighter jet wing- ithas a round - not sharp)
The sharp leading edge tends to create a air pocket on the low side of the skeg in the turn which causes 'blow out'
Regards
Dominic (YPC)
Regards
Dominic (YPC)
#2012
Hi Ozzie - looks AWESOME ! - cant wait for you to get it WET...................
Regards
Dominic ( YPC)
[email protected]
Regards
Dominic ( YPC)
[email protected]
#2013
FL
Hey, anyone try one of the new DPIHobby USA outboard lowers? There at a pretty decent price, and they look pretty spiffy!
#2015
Hi Bill
Had a look at the outboard unit - very nice looking - I would like to see some one test it ( like the developers)
The transom mount looks a bit fragile.
Gear drives are also known to 'sap' power - with electric that is a no no - as with gas.
The unit will certainly appease the scale modeler - but for outright Gas Outboard racing - I reckon the Flex drives are still the way to go.
Regards
Dominic (YPC)
Regards
Dominic (YPC)
#2016
FL
ORIGINAL: YPC
Hi Bill
Regards
Dominic (YPC)
Hi Bill
Regards
Dominic (YPC)
Which drive were you looking at? Can you show us a link?
Thank you
#2018
Gday dion, i work away so i have not been able to anything on it for two weeks, got servo's mounted, just trying to sort out the push rods for the steering. what collet do u use. i didn't get one of Dom because i had a spare aeromarine collet, but its to short, apparently i need to use a bh hanson collet
oz
#2019
Hi oz,
send Al at bh hanson an email and ask for the "one piece aluminium square drive" cost me 24.95 plus shipping but that may have changed now. I used carbon tube with a length of threadedstainless rod glued inside using 30 min epoxy. i used 3 or 4 mm rod. cant remember which one as I have both but I can check if you want. I am using the aero marine collet at the moment with Doms longer flex shafts and have the hanson one for the shorter flex.
Cheers,
Dion.
Cheers,
Dion.
#2020
If you need rubber boots for your rods, go to the wreckers and look on the Hyundais under the bonnet, forget which model, but get them of the clutch I think-been a while. Just pop the bonnet and have a look around and you will see them. just need a good pair of pliers that cut cable.
#2021
Hi Dion
how are you going with your outboard is it run in now and have you got the hang of it not seen vid for a while
thanks bruce
thanks bruce
#2022
Hi Bruce,
I have not been able to get the gas tunnel out for a bit as I really need help to launch that one at my lake. the nitro tunnels I can manage by myself but the weather has either been too wet or had committments. Solution- I joined a club where I can get help to launch and have a bit more space. My partner has been working 7 days so she cant help at this point. I do get it started here and there and load it in the car waiting for the rain to stop, but have to keep swapping back to the nitro which i dont mind about. Wish I had a fellow boater in the area that could help out. I am not giving up though mate coz I love the size of the gas tunnel!!
Cheers,
Dion
Cheers,
Dion
#2023
Bruce your lakes must be near on frozen this winter-minus 9or 10 I think i saw for your overnight weather!! Way to cold for my busted up body!!
#2024
Hi Dion
yes it has been very cold here but been able to go to the lake water is very cold but the grass is forzen . Jim and i still having fun with our outboards did get a new leg for mine not on it yet it is a arrowshark leg a bit nicer then the g-monty leg .
It a shame that you dont have some one to help with your boat lucky my brother is close to me so we go together is good fun
thanks bruce
thanks bruce
#2025
Hi Bruce,
Sounds like you and Jim are doing it for the team!! I got the nitro out again this morning while the wind was still down, the rain held off until lunchtime at which point I lost a screw off my header- didn't have a spare on me so went home. You know I was keen as I had to chop up the trees that had fallen across the road and drag them out the way with the 4x4 to get to the lake!! The water was very brown and high and full of debris from the s....ty weather we have been getting, but it did not stop me,lol. Looks like the rain might stay away for a day as the sun has come out now-sort of. Dont know whether to do an engine rebuild tonight or leave it and just head back out tomorrow morn for another session. Starting to get a bit of play in the rod now. Maybe I'll just swap the power head over as I am feeling a bit lazy this arvo.
All the best,
Dion.
All the best,
Dion.
