My new 58" apache style hull
#76
RE: My new 58
Heres a short clip of Gaz,s boat from Sunday clocked at 50 mph with a 470 2 blade prop i believe,should pick up quite a bit of speed with his new 7015/3 when he gets chance to try her out but i think 50 is very respectable for theis size hull.
Mart
http://www.youtube.com/user/riptigary
Mart
#77
FL
RE: My new 58
Mart, Why would you choose music over the sweet sound that baby is making[sm=confused.gif][sm=disappointed.gif][sm=disappointed.gif] Looks fast and stable.
I have been looking to try a 7015/3 on mine, from what I have been told it's the choice prop for my setups. I'm running a 6717/3 to push my two Apaches into the low 50's, 51-54mph.
Cheers,
Leo
Cheers,
Leo
#78
RE: My new 58
ORIGINAL: cheesewizz69
Cheers,
Leo
Cheers,
Leo
Mart
#80
RE: My new 58
I forgot to say good the hear your using the 6717/3 and getting 50+ mph thats the prop i have on mine which im hoping to get wet next week,ill be sure to post a vid when it happens and i promise no music .
Mart
Oh yes we need to talk soon,will send you an email later after our visitors have left
Mart
#82
FL
RE: My new 58
Hey, not sure what you have available in Italy. Check your kitchen or bath cabinet section in your local hardware store. I guess we have it pretty easy here in the states with Home Depot and Lowes on every corner....
Leo
Leo
#83
RE: My new 58
Leo
Leo
Mart
#85
RE: My new 58
ORIGINAL: isola_d_elba2007
Yes, we have the same handle here in italy but i need a stainless version.Running in salt water the normal one it will rust in a week....
Mart
#86
FL
RE: My new 58
Leo
#87
RE: My new 58
Hey martno1fan,
Don't know if you have finally decided names for your hulls...but maybe you can call one of them Comanche. Which is another type of Indian if you don't want to name them Apache's!
#88
RE: My new 58
ORIGINAL: bermy100plus
Hey martno1fan,
Hey martno1fan,
Mart
#89
RE: My new 58
mart
builds coming on well, just need to make up radio box now, which i have all the bits for.
got to find a reliable way to fix the deck down and then this puppies going to get moist!!!!!!!!!
regards
nigel
regards
nigel
#90
RE: My new 58
Hi Nige,
good to hear, im going to install plywood tounges to the front and ill dremmela cpl of slots for them you can also use ali round bar or dowels etc, the rear will get a cpl of niodym magnets and ill see how they work out,if they dont ill get some cowl locks,might go with o ring types as they release in a flip and dont damage the hatch.Post a few pics of your build id like to see it ,Simons picking his up tomorrow so you might have someone to play with .
Mart
Mart
#94
RE: My new 58
Looks good to me Nige just be aware steel pipes get hotter than ali so you will want plenty of air cooling in and out usually ratios 1 in 3 out.
Scott why does he need more support he has a t bar at the motor end and the other end goes into the strut and i asume he will seal the hole at the trasom with silicone more than enough support.
Mart
ps spoke to Simon last night all his bits came so hes hoping to get her built this weekend ,no doubt with your help lol
Mart
#95
RE: My new 58
Just seems like a lot of brass after the T-bar that could potentially sling around. It will probably be good enough, however Iwould add another support somewhere in the middle for peace of mind, but hey... not my build. Overall looks the beginning of a good build.
#96
RE: My new 58
the bend isint that sharp, its the way the pictures are taken,
i only have an 8 foot by 6 foot shed to build in and its full of planes!!!!!!!!!!!!!
the shaft rotates quite freely and it ait greased up yet!!
regards
nigel
regards
nigel
#97
RE: My new 58
ORIGINAL: Dreamin Hemi
Just seems like a lot of brass after the T-bar that could potentially sling around. It will probably be good enough, however I would add another support somewhere in the middle for peace of mind, but hey... not my build. Overall looks the beginning of a good build.
id say theres maybe 16" of tube there maybe less ,not that much when you consider how much hydros have hanging underneath ,mine had arround 24" maybe more unsupported under the hull so im sure it will be just fine.
Mart
#99
RE: My new 58
I only support my stuffing tube by the T-bar on my race monos, never been an Issue. I know plenty of racers that do the same thing, it makes it easy to adjust the stinger height up & down without having to worry about stuffing tube alignment. My cats & Hydros are supported at the exit of the hull & in the strut, but they are a lot longer.
#100
RE: My new 58
ORIGINAL: dicko
Mart
ps everyone has his her way of doing things and thats fine im just saying how i do it,but do whatever works for you .If more support makes you happier then do it all id do is get some ply cut a slot at the bottom of the vee that slips over the tube so it cant move side to side,just be sure to cut a cpl of tiny slots for any water to get through to the transom for drainage to the bailers if your using any,i normally drill a cpl of holes just bellow deck level so i can upend the boat to drain any water out .
