My new 58" apache style hull
#102
RE: My new 58
ORIGINAL: snatch-it
mart
tell me about the shed!!!! i realised it was to small when i saw your shed!!!!!!!!![img][/img]
mart
Mart
ps cue all the questions from our friends across the pond "Whats a shed" ? lol.
#103
RE: My new 58
My shed is insulated, lined and has TV, radio, Aircon & is more of a hobby room. It's split in two and the other half is full of tools, filings, carbon dust, resin & all the filth that goes with it. I need to get on that this weekend & clean it out now that & have finished most of my builds for the winter & migrated the boats from the tool side to the Hoby room side.
here's a pic of the back wall of my shed.
#105
RE: My new 58
That's the hobby room or "clean" side. It wasn't like that 2 weeks ago, the tool side won't be shown until I've cleaned that out. There's junk piled in there &^% everywhere right now.
#106
RE: My new 58
hay dicko, nice looking place for the boats....mmmm i wont post any pics of my shed yet ither..haha 9m long x 3.5m wide and its still no way big anough. clean it out and it seams big for a day and then it seems to just refill up .haha
dicko also mate what is the big black cat you have there what hull is that one..
ORIGINAL: dicko
#107
RE: My new 58
The big blue cat at the top is actually dark blue. It is one of only two built. My friend downloaded plans off the net for a fullsized cat, scaled it down & that is the result. The sponsons are too flat & id slides really bad in the corners. I may run it in offshore one day, but there's no offshore class here right now. I did a build thread on it here a while back. I'll see if I can dig up the link.
here t'is
http://www.rcuniverse.com/forum/m_90...tm.htm#9039426
here t'is
#108
RE: My new 58
mart
got the radio box done last nite.
just got to set up the throttle, fit the noodles and sort the deck cover.
final sett up and checks and then shes getting wet
might be sunday, failing that monday after work.
regards
nigel
regards
nigel
#109
RE: My new 58
Hi mate looks good,i was having problems getting a straight pull from the rudder to the servo and i dont wanna bend the rod how did you manage it ? i have the same box.Think ill need to put the rod in the outer hole on the rudder see if thats better.That little triangular part on the box in the corner is a bit in the way on these boxes to get the rod in the corner any more [:@],i also tested the box for water leaks and it does leak a little after been submerged for 10-15 mins but Gaz says he puts vaseline on the seal and it seems to work.
Mart
ps i like how you managed to hide all the wires under the plywood insert looks very neat and tidy,hope mine looks as good.
Mart
#110
RE: My new 58
thanks for the complement mart,
i have offset the box as far over as i can to the right, it was just luck realy,
the linkage is just off from the corner.
had to lift the box up about half inch off the hull, all lines up good.
not long now.
regards
nigel
not long now.
regards
nigel
#111
RE: My new 58
Hi Nigel,
yea i was also going to offset it a bit also.Simon picked his boat up today .If you run yours this weekend dont forget some video .Good luck with it and have fun.
Mart
Mart
#112
RE: My new 58
nearly there now mart
noodles to put in and holes to bore into deck cover.
not done much tonite, had to do the house dutys and the shopping!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
could be late sunday aft if i get all my jobs tomoz,
tried to ring simon but i think he must be busy, no answer!!
regards
nigel
regards
nigel
#113
RE: My new 58
Hi mate i still need to fit my radio box and all the electircs,stuffing tube,pipe and noodles.Went to pick some noodles up today and theyre all gone grrrr,looks like ill have to get some pipe insulators for up in the bow.Ill make do with red and yellow noodles down the sides ,hope to get her ready soon.
Mrat
Mrat
#114
RE: My new 58
mart!!!
shes ready to run...
no drivers yet, but shes good to go in the morning. simons bringing the camera so should get some footage,
queens park lake here we come
regards
nigel
regards
nigel
#116
RE: My new 58
mart
got to the lake an it wouldnt start!!!!!!!!!!!!!!!!!!!!!
checked it over and no spark, then there was and then there wasnt,
went back to simons and did the usual parts substitutions. found source coil knackerd.
left simons coil on it, but these coils are limited and dont run or rev the same as zenoah coils.
back to the lake to try it and by this time there was canoes all over the place!!!!!!!
waited for a clear patch when they where called in and then chucked it in for a short blast,
engine was off but put it down to the different coil. no video though, till next time when it runs good.
shows good promises though.
regards
nigel
regards
nigel
#121
RE: My new 58
Thought id share a cpl of pics of the latest build ,i did a black top and hatch .The hull has just been layed in the moulds this afternoon so no pics of that yet.The parts came out nice and havent been polished up yet just wiped with a dry cloth after trimming.My 7 year old daughter Ellie is never one to pass up a photo opportunity .
Mart
Mart
#123
RE: My new 58
mart
is yours ready yet?
not been able to get my hands on a source coil yet, no reply from prestwich. he must still be away.
going to a good freinds of mine tonite to borrow his coil for the weekend.
hopefully it will go like a goodun on sunday.
like the black, looks good, can i change mine!!!!!!!!!!!!!
regards
nigel
is yours ready yet?
regards
nigel
#124
RE: My new 58
ORIGINAL: snatch-it
mart
is yours ready yet?
going to a good freinds of mine tonite to borrow his coil for the weekend[img][/img].
regards
nigel
mart
is yours ready yet?
regards
nigel
No shes not ready yet,radio box needs sorting but ive been a bit busy,should have it sorted for a run next week then we go away to my parents for a week so might take it with me.Ill ask arround about a source coil see if a mate knows of any.
Mart
ps no you cant change it but anytime you want another lolol
#125
RE: My new 58
ORIGINAL: snatch-it
