Thunder Cat 31
#1327
RE: Thunder Cat 31
Thanks all for the speedy replies.
I am going to try and find some time to make the fixes you guys mention, and will see what happens.
I have to admit though its sort of frustrating at times, and hopefully it gets better.
#1328
RE: Thunder Cat 31
Can someone post a picture on where to place the pressure fitting. (On the fat part. Before or after the widest part?) It would be much appreciated.
#1330
My Feedback: (12)
SC
RE: Thunder Cat 31
ORIGINAL: robwest
#1332
RE: Thunder Cat 31
So would the general consensus be to put a new nipple in the fat part of the pipe rather than bothering to mess with making the current one work or stay tight etc?
#1333
IN
RE: Thunder Cat 31
ORIGINAL: Toycollector
just move it to the pipe and u'll have no probs from then....[sm=thumbup.gif]
#1334
RE: Thunder Cat 31
ORIGINAL: PCnmbr1
yes I have a clamp on my fuel cap . When I get problem like your I start at the begining! GOOD LUCK
There has been small amounts of fuel under the tank that have nearly stopped completely since I tie wrapped them, but I have not seen anything on the top of the tank at all. Would this lead to the cap being OK?
Another thing that is a real pain is how the gel and glass layup on the proboats is so easilly eaten up by nitro. I have not had problems with mine, but have made reapairs to a friends SW36 hull where the nitro turned a good couple inches into jelly. I have tried a couple different paints with poor results, and am currently experimenting with a waterproof fiberglass filler that I use for repairs etc by just laying it down very thin and sanding it, but its a real pain in the buttt.
Has anyone found something that works and is easy to apply?
#1335
RE: Thunder Cat 31
Toycollector
Chuck that tank man. It picksup a leak on the seam line. I replaced mine with a DuBro tank which I mounted in the cavity next to the motor. No more leaks.
#1337
RE: Thunder Cat 31
I just painted my boat, used tamia paints they are not nitro proof just dont spill nitro on it.
had it on the water this weekend sorted my problems with the motor and she is running sweet.
#1338
RE: Thunder Cat 31
Hello,
I need to cool the mainfold of my boat, he warm up very much after run. I don't know to do for cool it. I have seen a coil, but I don't know how make it, and I'm looking for other system.
Thanks very much!!
Thanks very much!!
#1339
RE: Thunder Cat 31
ORIGINAL: muvoxt
Hello,
Thanks very much!!
Hello,
Thanks very much!!
go to harware store and get small cooper tubing.
then take the water OUTLET fromt he engine head and attach it to the copper tubbing, then takt the copper tubbing then wrap it around like a yo-yo around the manifold, afte about 4 times of wrapping it cut the excess off and attach the water line tot hat then run it tot he side of the boat where the water exits.
thats it, shouldnt cost more then a few $'s
#1340
RE: Thunder Cat 31
Well i just ordered a O.S. .30 EB modded engine for my revo truck and the axial .28 in there is going in a new home.......my TC31
ill post some pics of it when im done, shouldnt be real hard to do really, just cut the SG crank down i have a nice flywheel for it and the collet will be able to screw on it just fine.
im going to have to do a few test runs to see if the engine head stays cool, i think it will because the axial is a cool running engine in general, but i will probably widden the 2 holes in the top out a bit and also cut an exit hole in the rear, that will help air flow alot. i will also rig up a little copper tubing to go inbetween the fins of the engine.
should be a good improvement over the dynamite .32
#1342
IN
RE: Thunder Cat 31
ORIGINAL: 4wheelinrevo
looking forward to see the mod[8D]...
i will consider it a good mod if boat will run mid 40's up to 50's easily coz stock dynamite .32 push low 40's...but we don't know yet until u've done it.
#1343
RE: Thunder Cat 31
Howdy All,
Just got a used 1 yr old TC31 yesterday...less than a gallon run through it. I worked the bugs out of the motor and ran it today....Man! What a blast this boat is! I did however have a good scare though...the boat took a small jet ski wake and decided to get it's hair wet. It completely submerged and popped back up. To my surprise, the motor was still running and it was able to plow it's way back to shore with the nose pointing up about 30deg. I would guess that there was about 1.5 to 2 quarts of water inside the hull. Has anyone sealed up their hatch intakes to prevent the torrent of water entering the hull in the case of a submersion?
I also read somewhere in this thread that you guys are putting fuel tanks in the sponsons to bring the COG closer to the transom. Anyone have pics of these mods or any info on what tanks you are using? I briefly looked for some but i go cross-eyed trying to browse through 54 pages of this thread.
And one more thing...my motor is not very responsive to low rpm throttle movements. The motor will maintain rpms for a second after the throttle servo returns to it's neutral position, and I have to give it slow throttle increase from idle to keep the motor running. My HSN is about 1-1.5 turns lean from stock recommendations and my LSN is about .5 to 1 turn from completely closed...if they go any richer, the boat will show a decrease in performance or will flood and not start. The boat runs great at speed but these needle settings seem pretty lean to me...but the motor acts as if it is running rich on the LSN...Any thoughts?
#1344
NY
RE: Thunder Cat 31
Well I ran 2 tanks through my TC31 today. First time I ran it. it now has a total of 5 tanks through it. It ran fine after a bit of tuning and cleaning the carb. Was not as fast as I hoped it would be but I still have alot of things I can do to it.
So which prop is the best one ( the conscensus here ). The flex shaft held up just fine and I beat it a little bit to see if it was going to hold up. I need more speed for sure out of it.
#1346
NY
RE: Thunder Cat 31
ORIGINAL: gooycheese
I am using a M445 prop, there are some other props people use I am not exactly sure what they are
Paul
Paul
What prop balancer are you guys using ?
#1347
IL
RE: Thunder Cat 31
Yes the 230 is too big, I am using a dubro balancer there are alot better but its pretty basic principal and it seams to work for me. Be prepared to spend a few hours sharpening and balancing your prop.
Paul
Paul
#1348
NY
RE: Thunder Cat 31
Paul
Paul
#1349
WI
RE: Thunder Cat 31
I use the top flight balancer, works good! I just got back from trying out my modded x440 (tongue removal) and it REALLY improved that prop for me. I didnt use that prop all that much because it just didnt seem to hook up all that well, but it is now my favorite!
